I think you’re saying one thing that makes sense to you, that I’m not exactly following to the fullest extent. There’s all kinds of diffraction occurring in there, not just wavelength restriction at angular problem areas like groove transitions. Each valley is “spraying” photons all over the place into the next grooves begin, and on and on it goes. 5% loss? OKAY, when NASA is building one, maybe.
A fresnel lens suffers from higher losses because of the obvious I would say; you have hundreds or potentially thousands of plastic grooves molded and the area cannot be used with the same average resolution (not even close). Due to the size of the grooves, things like arc centering highly change per groove peak and valley; not to even highlight on arc centering like that’s its primary downfall, but it’s now like 1000s of little tiny lenses are managing the light diffraction, not one smooth ground surface. It’s much harder to make a high resolution lens that is 0.5mm diameter (times a few million of them like a bug eye) than to make one lens at 200mm diameter that’s ground by CNC from a glass type. I think that’s the part I see sticking out as obvious to me with fresnel lenses.
For a point source, it is possible, and not hard with fairly simple software, to design a Fresnel lens that is perfect, to a geometric optics approximation. The Wikipedia “Fresnel lens” article shows ray diagrams. The finite size of the LED causes some shadowing of off axis rays that don’t line up with the steps, but I think that is a small effect. The precision needed is similar to that needed for an aspheric, but the process of making the mold may be more difficult.
But light is a wave and does not go exactly in straight lines, as shown here.
Diffraction pattern from a slit of width equal to five times the wavelength of an incident plane wave. From Wikipedia “Diffraction”.
But the light that is lost to the main beam is only that which comes through within a wave length or so of the edge of the step.
Same here, i subscribe to interesting threads like this but if i can’t add anything of value i often don’t post.
But i have to say good work djozz It looks great both the beam & box.
I wish i had the willpower to keep modding when the world is so beautiful outside :bigsmile: but i haven’t modded a single light since may, It is just too bright & nice outside in summer here, and so few dark hours at night i hardly get to use them at all
I can’t wait until the darker months so i can find time to mod again
Makes perfect sense, go modding when the light's out. Looking forward to the new batch this winter :-)
About me saying 'smart' things, as a biologist and not into physics I only know some basic optics (unlike a few here on BLF who are way more knowledgable than me), but I'm fairly good in thinking those basics through and find a practical use for it in this hobby. And I can not help myself boring the BLF community with that. (As long as it comes with beamshots I think I can get away with that ;-) )
Djozz, I think you have a lot more fans than you think. Like others have said, sometimes I very much enjoy a post, but fail to comment. Usually because I can’t think of something constructive (or witty) to say — other than maybe the overused “awesome.”
So……. “Awesome”, it is.
Oh wait. I just thought of something almost constructive. Did you know almost everybody mispronounces “Fresnel”?
“Augustin-Jean Fresnel (French pronunciation: [ɔgystɛ̃ ʒɑ̃ fʁɛnɛl]; pronounced freɪˈnɛl fray-NELL in English) (10 May 1788 – 14 July 1827), was a French physicist who contributed significantly to the establishment of the theory of wave optics. Fresnel studied the behaviour of light both theoretically and experimentally.”
BTW he was born at Broglie. Not many french people know how to pronounce correctly “Broglie”
Why was I snoozing on this thread? My perspective on making throwers or search lights completely changed upon reading this. I have to admit though that there are a lot of things I don’t understand also.
I think I’ll copy this concept shamelessly when I try to build a ‘portable’ ultra long range search light for our rescue team. :bigsmile:
A few tips: measure the focal length of the lens carefully, at a distance as large as possible, and then very carefully make the box with the corect dimensions. My box allows a focal correction of a cm, but that appeared only just enough, more focal travel than that is not a luxury. I was surprised about the focal difference between 20 meter and infinity. Mount the lens as flat as possible (a rigid frame) and stress-free. The finning on the back appeared completely unneccessary for an XM-L2 at 5A.
