17mm/22mm MTN-MAXlp - Low-Profile 1A-4A Programmable Buck Driver + 22mm MTN-MAX
Remember if you order the parts kit it isnā€™t an SOIC8 Attiny, so itā€™s a little harder to flash. I made the mistake of ordering the mcu bare
What would oneā€™s ā€œIdeal buildā€ be with this driver? Host? LED? Battery config? Looking for some ideaā€™s?
UF 1405. That light rocks with a good driver in it. 5A constant current until the two 26650s are dead.
Thanks Richard, sounds like a winner!! :wink:
This driver is awesome in the 1405. I've been playing with one of RMM's four layer buck drivers set at five amps in a 1405 for a couple months now and the driver has held up flawlessly. The four layer MTN MAX combined with a dedomed XM-L2 in the 1405 lights up the treeline out back of my house at 500 yards easily. I'm guessing it will do twice that range but I haven't confirmed that. I've also put one of RMM's two layer MTN MAX drivers at 3.5 amps into a mini mag running triple XP-Ls. That was a cool little light.
SOLD! :wink: Got one on the way! :bigsmile: Tend to dig lights that ROCK!!! 8) Oh it should really ROCK with the XP-G2 S4 2B de-domed!!!
You should see about 480kcd out of a 1405 with an S4 2B at 5 amps. Ask me how I know. :wink:
Thatā€™s cool! I am waiting for my parts from Richard to arrive but I am going to push the dedomed S4 2B at ā€œonlyā€ 4.5A for reliability concern. How much candela would you expect at 4.5A?
I donā€™t know, maybe 425-450kcd.
could you take some long distance beamshots of that white laser ??? I would love to see what this driver can do in a 1405!
Iā€™m using a different, lesser quality 5A buck driver. I have yet to do one of the MTN-MAX drivers, but performance should be the same/similar.
Iā€™m building my kit now. I think Iā€™ve figured it out by process of elimination, but ā€œCMAXā€ is the Buck IC bypass, right?
Correct. Make sure you get the thermal pad on the buck IC reflowed fully.
ohā€¦
lol wish I had read this before I just soldered the thing into the pill
I think Iā€™ve got it working, but next time Iā€™ll just order the completed driver. I can deal with all the caps and tiny resistors, but I hate these components that have the pins under them.
I have the c682 coilcraft inductor. At the bottom it has 2 contact plates on each side and a black pad in the centre. I presume the black pad is the termal pad? Richard mentions one has to reflow the thermal pad? On the pcb underneath the black/thermal pad theres silkscreen, no place for reflowing? What is meant by reflowing the thermal pad of the inductor to the pcb?
Mmm, I realize now the thermal pad is that of the buck IC, not the inductor. Apologies! Please ignore my comment.
Some SMD parts have solder pads not exposed or visible with the part in place and these canā€™t be soldered using an iron but need a hot air reflow system, a reflow oven, or some way to heat the entire thing up to the solder melting temp. For some things you can use a hot plate and carefully monitor it but two sided pcbā€™s can get tricky if it has such parts on both sides. Otherwise you could reflow the difficult part first and then solder the remaining parts with an iron.
Iā€™ve been struggling for some time now (2-3 weeks) to get my MTN-MAXlp HP build stable. I have already communicated directly with Richard around my issue, but I still donā€™t have a solution. It seems like Richard has had great success with this driver up to now. So, Iā€™m taking a chance here, maybe somebody had a related issue.
My first driver build was fine. The only problem I had was that the mode switching was too slow, so I changed PLDN 19.1k to 4.7k. After this, the driver was great. Iā€™ve configured it for 5.5 amps output running XM-L2 U4 - 4 modes, starting on Turbo. All was great, including the 478kcd!
I then built my 2nd driver, EXACTLY the way Iā€™ve built the 1st one (including the same program). The issue now arose -> I could not switch/change modes. I only had max output, no matter how fast or slow I tried to change modes, no go. Just max output.
I then decided to build a 3rd driver. Once again, exactly the same build, the same program, the same issue! I then took this driver, reprogrammed it a few times setting a lower turbo mode, just to see if the driver will turn on at a lower amperage, which it did. The problem seems to be mode switching only, its start off at the correct mode. Iā€™ve probably reflowed the MMU around 15 times during the diagnostic process, every time the same symptoms. Iā€™ve replaced that MMU at the end with a fresh / new one (Iā€™m so paranoid at the moment) - still the same issue.
Iā€™ve fiddled around with the PLDN resistor going up & down with the resistance - did not help.
Has anybody experienced what Iā€™m experiencing now? Iā€™d very much appreciated any help.
Could there be a short in the traces of the board that means that it just goes into DD?
