aw man thats sad I guess I’ll have to dispose it then
At least you’re not loosing a fully charged battery…….if that helps!
NOT AT ALL HAHAHA It was first use
Now i feel sad for it, only one use. At least it died a proud death, powering a flashlight! Last Post anyone? :_(
You’re nitecore may bring it back. I had two separate lap top pulls and the ones that only read 1 volt are holding voltage better than the others that read 3.7. And it’s an excuse to get a voltmeter.
From everything I’ve read lithium cells suffer internal damage when discharged to very low levels (such as internal shorts). Maybe nothing will ever happen but for me it’s not worth the $10 or so to take the chance of experiencing an exciting, and dangerous, event
dudunphy:You’re nitecore may bring it back. I had two separate lap top pulls and the ones that only read 1 volt are holding voltage better than the others that read 3.7. And it’s an excuse to get a voltmeter.
Yes I suppose it’s not worth a mini explosion in your house. I thought I had read that you could bring them back if you had the right charger. I probably need to do some more research. Thanks Sig!
SIGShooter: dudunphy:You’re nitecore may bring it back. I had two separate lap top pulls and the ones that only read 1 volt are holding voltage better than the others that read 3.7. And it’s an excuse to get a voltmeter.
The xtar vc4 claims to be able to rescue your over discharged batteries.
dudunphy: SIGShooter: dudunphy:You’re nitecore may bring it back. I had two separate lap top pulls and the ones that only read 1 volt are holding voltage better than the others that read 3.7. And it’s an excuse to get a voltmeter.
From reading their marketing stuff all that means is that it can reset protected batteries. See this
I doubt any charger can undo internal shorts.
mongoose: dudunphy: SIGShooter: dudunphy:You’re nitecore may bring it back. I had two separate lap top pulls and the ones that only read 1 volt are holding voltage better than the others that read 3.7. And it’s an excuse to get a voltmeter.
I read the link and i don’t think thats what they mean. They claim their chargers can detect the battery voltage when it has been over discharged, which, correct me if i am wrong, would be impossible if a pcb had tripped. Seems to me that what d10ten posted earlier about the charger confusing the li-ion battery for a ni-mh battery is what’s happened, the voltage dropping so low. The good thing is that Wrathbringer never came to any harm, assuming the batteries were imbalanced
SIGShooter: mongoose: dudunphy: SIGShooter: dudunphy:You’re nitecore may bring it back. I had two separate lap top pulls and the ones that only read 1 volt are holding voltage better than the others that read 3.7. And it’s an excuse to get a voltmeter.
I read it more carefully and they’re probably talking about reduce level charging the cells until they’re somewhere around 2.5volts and then charging them normally. But the my point still stands that I’d toss the cell because “rescuing it” by no means eliminates any damage to it.
All I know is when I stuck those really drained batteries in my d4 it brought them back to 3. something volts really quick and got them charged with very little heat coming from them. So maybe I lucked out.
When I placed the battery in the vc4 it shows as NiMH and then shows 0V. Tries charging but will always return to null.
toasted
I wonder if it is protected. Because I might rip the protection off and see if the cell is still in healthy voltage.
if not just throw it away
No protection. i don’t like pcb. my sis was using the light. thats why that happened…
You really should find a multimeter and test the voltage, just in case it’s fine and for some reason the charger has a problem.
Throw away nothing until you verify that its faulty.
It’s a lesson you have to pay: “Don’t give any tech that you care about to a woman”
Or it might be that your K40M is faulty!
nah its got nothing to do with the light. i accidentally mixed up 2 NCR18650B with a single NCR18650PF… I would replace the batteries every half hour of use. but since my sisters were using it till the higher high output were low i guess thats where the fault is…
Nothing has been dispose of as of yet…. I don’t own a multimeter, and the charger is fine…
