72%. Off to bed so I'll stop boring you with updates till the morning when a runtime graph will appear. Assuming it has decided to turn off by then. I reckon another 3-5 hours should see it.
Long enough Mr. Admin? Or do I need to get some higher capacity cells?
Steamed....lol......with a little bbq sauce for good tasting. Thanks for doing the runtime....the light is still doing a good job at lighting up, have you tried turning the light off to see if it will come back on.
Came home to see to the hound - it is still lit. Now down to 2% after 28hr 20 minutes. It is about as bright as a sick glow-worm but it is still shining. Now 20,385 data points. This is impressive, I'd have thought the cell protection would have cut in by now.
That's a very impressive light then. And it sounds like most of the time the light was actually strong enough to be usable. But are you sure it has cell protection?
