Plenty of 22 mm adapters available. The production cost of this board might make it hard to keep affordable in several sizes.
I would like to ask when it will be available again?
Thanks!
1-2 weeks.
Order placed for 5 more drivers, 4 full resistor sets and 2 moonlights+tracking.
Thanks for making these drivers and lowering the min order amount, they are awesome so nice to not have a turbo timer !
2xLi-ion(“6V”,2S) support parts are back in stock,also I added options for 3S and 4S cells support.
Is it possible to order 1 or 2 of these to the UK fully setup to go with moonlight mode and 6V support, all soldering done?
Yes,min. order for EU is 1pc.
Update 15.12.2015.
*Added LD-M2.
*Shipping price is now separated,no minimum orders for EU,25$ minimum for rest of the World(excluding shipping).
Hey folks— brand new to BLF, joined because of this thread actually (awesome work here led4power).
Question— how do I actually place an order for these drivers? I PM’d led4power but I’m not sure if that’s the preferred method here.
Hi skandocious,PM sent.
I’d be in for a pair as well, if there is an Australian group buy going - I’m in NSW.
? You can buy drivers without group buy.
Yeah, I am a dumbarse
I’ll take one LD-M2 6A version. That’s 22$ shipped to EU, right?
Hi Kazik,that’s correct.
Hi led4power,
I’d like to get one of the LD-M2 boards. I see there is a $25 minimum. Can I just pay extra for the one board? I really don’t need a second.
<25$ is ok,I will remove that from OP.
Awesome. Before I pay I want to make sure I have my ducks in a row. I am going to use this in a skyray king. Its an E switch light running 3 XML2 in parallel off 4x 18650s in parallel.
I am expecting about 9-12 amps of current so the driver I should get is the LD-M2 6Amps - optimized for 4-12Amp range correct?
For this setup all that is needed is to attach the wires correct? No sense resistor change etc?
Matt - if he holds u to the $25 I'll buy the other driver off u buddy.
-Myron
There are two main current sets for LD-M2 :6Amps and 12Amps. by changing current set resistors you can set current in 4-12Amps range for 6Amp version,and 12-20Amps for 12Amps version(actually some members use it for ~35Amps if I remember correctly).Lower current than 4Amps is possible ofc,2.5Amps is used often for xhp35.
Just tell me current you want,and I will set driver for that current,if you want to change current,I can send you different resistors for experimenting.
