Sorry to disappoint you there short stroke... but that light was made to fit ME. I'll tell Daniel... he will make sure it gets to me!! Ha!
Send it right on up here Steve!!! TL
Hah, you’re much too late off the mark guys.
No prob. ;)
You're going to love it here, MRsDNF!
The current driver is going south and RMM's driver is being given the mantle. I believe RMM's drivers name is James. I just hope he fits in and doesn't cause any trouble.
Thanks rc I felt all tingly for half a second and then felt something warm pouring from my neck. Is that Ninja Milla?
TL, I'm not sure I want to know why Dale is named short stroke and something was made to fit you. It all sounds a bit kinky to me. Maybe thirty or so years ago. The duck is looking good, on my dinner plate.
no, No, No, ... it doesn't even get dark where the duck lives!! TL
Rufus, This light is meant for TEXAS!!! ... AMARILLO TEXAS!!! TL
You’re probably right. Were in the thick of fire season here and it would most likely get confiscated.
Most people seem to connect CA with earthquakes but fire is the big destroyer here, more than 1200 homes and buildings in just two of the major ones this year. One got started july 31 and is still going. Yeah, some places are bright even at night. Please think of those people in your prayers.
Better do a background check on James, he might have ties to Jacks cohorts.
As long as it's James, & not Jakob, you should be OK.
Awesome build Steve !
Yes, we watch those fires on the news and it will almost make your eyes wet every time. I cannot understand why we haven't called in enough military planes to at least slow down the ...butte fire... is that the right name? Middle Town sure got it bad as well. You folks have sure been through it between the danged drought and fires. I have a lot of customers out there and several have had to run... and a couple lost everything. Just sad.
You ALL are in our prayers and thoughts here. TL
The scope of a fire that burns over a hundred square miles is beyond comprehension. There isn’t enough water or retardant to stop it, the terrain is too rugged to line up on it, and the fuel is too dry. The weather makes a huge difference, as soon as it cools off and the onshore breeze brings up the humidity they can make headway(about 10% more containment per day) but otherwise they just hope to save what they can when they can and stay out of the way. Some are started by accidents and some by dry lightening strikes but when it’s hot and dry something’s gonna burn. Many of the people displaced moved there because land is cheaper but the areas are remote and virtually impossible to protect when airborn embers can start a blaze a mile away or more. Probably need to see a shift in how homes are built(reduce the damage) rather than think it can be stopped once it’s going. I’d think rammed earth would be a better candidate than stick framed houses. In any case a lot of generous people are stepping up and volunteering to help these folks out without waiting for the Red Cross to sort itself out. No matter where you live it’s always something.
Wouldn’t they consider blowing it out? I’d think if they could drop a few well placed blasts and blow out the fire then the properties saved would be worth the destruction of the blast. AsifIknowanythingaboutthatkindofthing
Very nice work, I’m always impressed by your skills when it comes to making lights.
Blowing it out works great on single source burns were you can consume all the oxygen and snuff it out but these forest fires burn along fire lines ten, 20, thirty miles long in ragged, uneven lines that jump over streams and canyons creating huge up drafts that sweep the flames up 1000 foot tall ridges in minutes leaving hot spots behind that burn for hours and smoulder for days, a real holocaust. Sometimes if the wind is right they can set a back fire to burn the fuel ahead of the main blaze but that doesn’t always work. You have to remember that the crews need a way out and winding dirt roads don’t make for fast getaways. I can’t imagine a more hot, dangerous, dirty job.
We went to Carlsbad Caverns a few years ago and the area had been ravaged by fire. Everything was so rugged you could plainly see there was just no way for a firefighter to get to it to fight it. And a lot was barren looking rocky land with cactus, stuff that didn’t look like it would burn, made the mind wonder where the fuel came from, but a massive area was blackened and scorched nonetheless.
For the mountainous/craggy forest fire type that’s going on over there, like you said, no access, no water. A nightmare scenario to be sure.
Hey, I’m in Aus, you can send me that gorgeous light, the postage is cheaper locally.
Excellent build MRsDNF, your lathing skills are impeccable.
Another really sweet one Steve. How was the light mounted when you cut the slots? It looks like it’s in the lathe jaws and center.
Amazing. Just Amazing. I can’t get over the talent here.
Thanks again guys.
The old part of the bezel was held in a three jaw chuck on a rotary table with a modified center on the tailstock centered in the battery holder where the rubber switch boot sits in. The slot was machined and the rotary table turned manually thirty degrees for the next slot. The tear drops were added later as the battery holder looked unfinished with a plain tail section on it. The small groove around the outer diameter at the end is just to make the tail of the battery holder look like it is held on with the cap screws.
I've modified the battery holder slightly by adding a small piece of heat shrink around the positive button so that if the holder is placed downwards on a metal surface with batteries in it there will be no short.
