Review: 150 Million Candlepower Militay Xenon Arc Battlefield Illuminator (AN/VSS-3A)
45 posts / 0 new
FlashPilot
FlashPilot's picture
Last seen: 1 day 2 hours ago
Haha, thanks for the laughs. The project was initially an exercise in futility while trying to adapt it for marine use. Once completed, the light made an amazing boat that much more fun & useful. We were the only ones on the California Delta able to power ahead at full throttle after dark without having to worry about smashing into anything... especially partially submerged debris, such as logs, etc. Interestingly, it also did a great job at illuminating deep submerged objects through murky water. You could actually see at least 10 feet into the murky water way out in front while the boat was at speed. If anything, that was actually more impressive than the sheer beam distance through night air.
I used to work in San Rafael and had a large sail boat at Pier 39 in San Fransisco.
Kindle
Kindle's picture
Last seen: 1 week 2 days ago
FlashPilot wrote:
It was designed for one thing in mind and that was for putting a 120mm shell directly on target during night hunting.
Late to the party pedantry...
105mm projectile...remember we're talking about an M-60 series with an M68 main gun. The 120mm gun didn't enter the picture until the M1A1 in the mid 80's.
FlashPilot
Thank you, and corrected. As I wrote this, I was still wishing I had thermal imaging instead of a xenon arc. I have a friend thats a tank platoon leader for the M1A2 bunch. I get to pop off a few night time practice rounds in Feb. Im hoping the range has some descent fun targets when I get my try.
ryansoh3
ryansoh3's picture
Can’t believe I missed this awesome thread, here’s a nerco bump. Party
BLF ≠ B-grade Flashlight Forum
FlashPilot
Im just glad you never got one. The darn thing would be turned into a 1kW laser and make the folks at Lawrence Livermore green with envy. Big Smile
Nikki
Last seen: 6 years 6 months ago
Hi..
i am looking for a battelfield search light ..something very similar to what u have posted. please chat with me on nafees.iaf@gmail.com and help me buy this light. i am looking for a long range spot like which can make a spot covering the distance of 3 Kilometers.
Request to give your mail id so that i can communicate with you regarding the same.
Thank you…
Nikki Smile
FlashPilot
Hi Nikki. Welcome to BLF! These are the only reasonably priced 1kW military searchlights that I am aware of at this time. You can contact the seller if you questions. Good luck!
http://www.ebay.com/itm/271606524719?_trksid=p2055119.m1438.l2649&ssPage...
edward22
Last seen: 6 years 5 months ago
Kind of impressive.
dsiddens
dsiddens's picture
Last seen: 7 months 4 days ago
Everybody needs a hobby. Yours is interdiction on the Sac waterways!
FlashPilot
Xenon arc is about the only thing that illuminates semi submerged objects while at speed. Maybe that’s why we were usually the only boat “on plane” after the sun went down. Nice sail boat. Is that yours? I used to own a Morgan Islander 51’ in SF Bay.
southland
southland's picture
Last seen: 1 month 1 week ago
Next time your out at night, get us a couple of beamshots.
FlashPilot
Sorry I didn’t update this till now. The boat was sold with all hardware onboard to an illumination lunatic afflicted with “the sickness”. Big Smile
xevious
xevious's picture
Last seen: 23 hours 47 min ago
Fascinating project! And an interesting end. I’m glad it all worked out and that enabled this boat to have the most killer illumination for a civilian craft. I imagine a naval destroyer would be the only thing to outshine it. Wink
Considering 10 years ago… I wonder what spotlight designs have been fashioned today in order to harness the brightest emitters that would put out even more lumens. What would be a good candidate LED, or is an HID system be more feasible in this application?
FlashPilot
I’ve been lucky to enjoy several hours playing with aviation, military and marine arc lamps. On the high end and by their very nature, arc lamps remain several magnitudes more powerful and versatile, with far longer range than LED offerings. I suspect that will remain true until a different technology (possibly laser) can some day be utilized to surpass Arc in these applications. As it is, each has its pro’s and cons. A few commercial arc lamp searchlights are now augmented with LED arrays to provide wide area lighting support while employing the main arc for long range illumination. Arc lamps aren’t designed to be cycled on and off and require time to heat up and cool down, which gives LED an advantage. Feasibility all depends on your budget, space available for installation and properly rated equipment necessary to support it. A complete commercial installation to match the light I reviewed can easily exceed $40k, so it can add up quickly.
