No time for a complete reply ,,, [ school ]
But several miss quotes , and errors to reply to as time permits ..
Ok the spaces have been lost in my post... (added spaces another way, formatting issue/quirk happened there due to a little glitch in the automatic spacing after playing around with dot points etc...)
Anyway, What I disagree with in particular are the arguments in the OP describing the "stressing" of a cell during charge, and "normalisation" of a cell.?? Discharging a cell imparts stress as does charging , this stress then manifests itself as cell degradation ,
as for normalization , think of it as the battery at rest , and at the voltage its going to maintain [ not accounting for self discharge ]
Normalisation as I understand your description to mean, is describing how the resting voltage of the cell is able to stay at 4.20V following a charge. I.e. the difference between the charging voltage and the resting voltage is minimised. It was also mentioned that this will take an hour.
Your proof of "stressing" a cell argues that a cell that rests at 4.20V following a charge on the budget charger is proof that there is no voltage drop and therefore the lower charge current has been more gentle on the cell.
I haven't fully read the following posts, but I Disagree with the OP on several points Hmm didn't read it , but felt the need = Nice !
If your budget charger that terminates at 50mA, gives a resting voltage of 4.20V, it must have terminated at 4.22V. Lets start here ....
First , 4.22v is nothing , insignificant voltage to worry about , and is often touted as something for people to worry about . [ Why do people bring this up ? I dont know ]
If its something about stressing older cells , ?? . Most of the chargers I have are sensitive to the internal resistance of the battery , so when nearing completion , a cell with higher internal resistance will terminate at a lower voltage , [ Tr003 , WF-139 , WF-188 , Xtar to name a few ] and there are some charger that will try very hard to bring the battery to 4.2v such as the Soshine and TR-001 , but this is and will be about buyers knowing or educating themselves .
So rather than trying to scare people , we should be trying to educate them .
Also dont forget , @ 50mA , its a very gentle charge rate , gentle = low stress , and yes it takes a while .
[ Im out of time this morning - so maybe 8 hours from now ]
Cheap charger behavior , now most cheap chargers do the pulse charge method ..
What that is it , charges , stops charging to check the battery then continues to charge .
Now when it stops to check the batt , the charger than is able to adjust voltage [ of the charger and charge current ] ..
Now while the charger does indeed have a higher charge voltage [ lets say 4.22v near termination ] it does not mean that this is the voltage of the battery [ one needs to understand this ], and because it stops and starts , when the battery reaches 4.2v , it should [ should ] stop charging .
Now as to the termination voltage of the battery , two factors are involved , the charger [ obviously ] as well the battery ..
Depending on the internal resistance , and the sensitivity of the charger to such , can have a contributing effect on termination voltage ..
A battery in rerally good condition may terminate 4.22v or 4.21v and hold said voltage .. Because its a good quality battery ..
A battery in not so good shape may terminate 4.17v in the very same charger , and a cell on its last legs could very well go 4.2v ...and hold the voltage .
Its important to understand there are so many variables involved .
Clearly that's too much to read ..
Can you guys just meet at Cutter and have it out in the parking lot ..?
Bring your lights with you ...Winner take all
need to subscribe to this thread
Having a bad day ?
Banter is good , when people take pot shots , gives you a chance to plug the holes !
Hehe, more fun!
Agreed here, the process of charging applies a stress to the cell.
Ok, so as described below - referring to the voltage the cell is able to maintain following a charge. 4.20V is possible after a charge that tapers to 0mA at 4.20v, so that we have managed to maximise energy put into the cell for a given voltage, defined as true equalisation of the voltage between the charger and the battery.
Yes, I did not want to say I had read the other members posts yet, but I did read your post, you need to read that sentence again.
Sort of agree here, 4.22 v isn't a huge amount to be worried about in the short term.
If its something about stressing older cells , ?? . Most of the chargers I have are sensitive to the internal resistance of the battery , so when nearing completion , a cell with higher internal resistance will terminate at a lower voltage , (yes, because the cells have a high floating voltage due to the internal resistance, and because the measuring time is no longer than a fraction of a second, the cell voltage is not allowed to "normalise" which you also said earlier could take up to half an hour. It is reasonable to say that high internal resistance cells here do terminate early due to the higher charge load cell voltage.
[ Tr003 , WF-139 , WF-188 , Xtar to name a few ] and there are some charger that will try very hard to bring the battery to 4.2v such as the Soshine and TR-001 , but this is and will be about buyers knowing or educating themselves . Because these cells don't over-charge past 4.20V as much as the other chargers.
Absolutely, 50mA is pretty low already, and at this rate as calculated before, with a 500mOhm cell, will only give a 0.02V difference between charge load, and resting voltage. Higher current cells with 50mOhm internal resistance will by now only have a 0.002v difference, effectively "maintaining" 4.20V due to measurement accuracy
here your saying that the battery voltage under charge is 4.22V. This is what I've been saying.
As stated earlier, internal resistance of battery -> high floating voltage under charge load + short measuring time not allowing voltage to settle --> cuts off before energy has actually been put into cell, therefore once "terminated", the cell hasn't actually taken on charge, and the resting voltage is lower
But yes, absolutely, there are many variables involved here.
I think we both agree on the idea that higher currents --> more damage.
And we both agree that with a hobby charger comes the need for the user to be aware of what their doing, and set charging currents accordingly.
If no one wants to read above, this is my summary, I think i finally understand where the problem was. (a difference in definitions)
1) My only problem with your OP is the way you used the concept of cell resting voltage to argue that the true CC/CV charging of hobby chargers is not as good for cells, however there is no relationship between these under the criteria of the standard charging protocols offered with the chargers in question.
2) Also, the comparison is wrong because of your difference in the definition in what cell charge voltage vs cell resting voltage should be, and the way each charger uses each in relation to the understanding of how hobby chargers use this voltage, vs how budget chargers reference 4.20V according to the way you described it.
What I'm now understanding, is that you see cell charging voltage (at 4.22) as irrelevant, and that the resulting cell resting voltage of 4.20V is good (at 50mA termination). Because the budget chargers measures resting voltage in the "off" time.
We must remember that the hobby charger will charge to a max cell charging voltage of 4.20v, and will accordingly have a resting voltage of 4.18. (at the same 50mA)
SOOOOO - This is the 0.02v discrepancy that you are describing, due to the difference in the way each charger defines how it wants to use termination voltage. NOT how it was charging the cell in the CC phase.
Now was that a long post or what... Sorry guys.
Meant to be studying for exams... mmm so what kind of antibiotic should be prescribed prophylactically in the event that a patient has had a history of rheumatic fever, amoxicillin 2g, 1 hour before treatment such as periodontal debridement?
Some charger data:
WF-188, charges with 300-350 mA until the cell has reached 4.2 volt without current, the actual voltage on the cell can easily be 4.25 volt.
WF-139, charges with 350 mA but does sometimes reduce the charge rate, I have seen up to 4.35 volt on the cell.
Both charges will stop when the cell measures 4.2 volt without current. I.e. when the cell is removed it will not read more than 4.2 volt on a DMM (there are some tolereances).
A hobby charger charging with 1A will only have 100 mA current when it terminates the charge at 4.2 volt and will not go above 4.2 volt.
Darn cant reply , page wont show .. Must get back to school work
Now I have a problem with this , I dont remember saying any such thing ..
So if your going to make stuff up , how can I reply or argue against some thing I didnt say ?
I think this discussion has de railed , because your talking about things I havent said or intended ?
Why would you do that ?
I certainly remember reading it just as quoted, I thought it quite strange at the time, the OP has obviously been edited.
The OP certainly seems to abound with misunderstandings and lack of real hard facts.
??????????????? WTF - Are you guys trolling ... hmmm
The op was edited just as I made a basic posted and has been edited many times since, a cheap basic charger with no cc/cv can not be better then a good hobby charger with cc/cv since Li-on,s are ment to be charged with it, also a cheap charger that will only charge at 1 amp is not good for all batteries, this has been an interesting thread
My intention is talk about the error in your argument, and to correct this for the benefit of everyone, there is nothing against you. Your one of the highly valued members of this forum, and its great having you around. I'm not going out on a limb to try to make stuff up, its not what I'm trying to achieve at all.
My only concerns are just in the theory side of things
1) The argument was based on a "proof" that is not causally linked to the main argument.
2) The small print - the inconsistencies in the definition of your "proof" (voltage at cutoff), which once corrected, render your "proof" invalid.
Do you agree with the following quotes, I am trying not to take them out of context, but my understanding is this is your take on the topic.
The hobby charger maintains its charge rate longer , there by charging faster ,
But with the Hobby charger , it will stress the battery more , how do we know , because it [the resting voltage] sags !
The Point that is being made:
It was stated that charging cells at a higher current, for longer can cause more stress for the battery
The issue was , folks buy hobby chargers to be safer , and to charge cells so as not to damage them , and then turn around and charge @ higher current rates that [ my opinion ] stress the batteries more than the cheap chargers they are avoiding
I definitely agree here, charging at a higher average rate results in more cumulative damage, This is fine by me. Its the way you prove this that is what I'm on about.
The Proof that was used:
That a cell off a hobby charger will sag to 4.15v while a cell off a budget charger will rest at 4.20v
If you charged your 18650 to 4.2v with the hobby charger and it sags to 4.15v , then it had to be under enough load/stress to sag back to a unstressed state , and the Cheap charger terminates at 4.2v and the battery holds 4.2v , does that tell you that the battery was under far less stress ?
The Problem:
1) Using cell resting voltage to prove battery cell stress when both chargers terminate at the same current threshold. In a CC/CV charger with the same termination current, charge current in the CC phase has NO relationship to the voltage of the cell after the CV phase. (within normal charging circumstances)
2) Definition of "termination voltage" -
But with the Hobby charger , it will stress the battery more , how do we know , because it sags !
You have stated here that your hobby charger charges to 4.2v.
You also stated that the cheap charger will Terminate at 4.2v
This may sound the same, but its in the details of what you mean by each.
With the cheaper charger, you define the "4.2v termination" as one where the resting voltage is 4.20v, but the cell charge voltage CAN be above by 0.02v. 4.22 for example.
(okwchin)If your budget charger that terminates at 50mA, gives a resting voltage of 4.20V, it must have terminated at 4.22V.
(old4570) Well the charger voltage may be 4.22 , this does not mean that the battery voltage is the same , as these chargers usually run 2 tenths above batt voltage . So if it terminates at 4.22 , then the actual charger voltage would have been more like 4.24 4.25v
On the other hand, The hobby charger we know when we set to charge to 4.20v, will never exceed a cell charge voltage of 4.20v. As you indicated, the charge voltage can be 2 tenths above the battery voltage, so the battery voltage must be 4.18.
We need to be comparing apples to apples! The following are the True Cell Charge voltages at termination based on the information provided.
Hobby charger - Cell Charge voltage of 4.20V
Cheaper charger - Cell Charge voltage of 4.22-4.23V
And given that we expect a 0.02v drop following removal of a 50mA charge current on a cell with 500mOhm internal resistance, we can expect that the cells with have the following resting voltage
Hobby charger -> 4.20 - 0.02 = 4.18v
Cheaper charger -> 4.22 - 0.02 = 4.20v
What I'm trying to say is, the difference is actually just a result of having a different charge voltages at termination, and cannot be used as proof of cell loading because both chargers taper off to the same termination current
The OP still carries its main idea. I wouldn't go accusing anyone yet.
Im after an educated and conducted discussion here about the definition of charge termination and how this has may have been accidentally used as an proof that one charger is not as good as another. I would love to get some feedback from other members who are comfortable to discuss this topic to chip in.
Maybe I'm wrong, but I'm currently 99.9% sure that this has just been an oversight in the way charge termination has been understood in the OP
Original Post changed How ?
If mem serves additions were made , but nothing was changed or removed ..
In an attempt to improve explanation .
Which has obviously failed .
What part of [ Im talking about charge current ] dont folks understand ? Im not faulting the Hobby charger , only the way its used .
And questioning how much better can it possibly be ? Than the humble cheap charger ...
I almost feel like ive stepped on the toes of Surefire fans .
And I have never mentioned CC/CV or how I feel about it , merely questioned whether CC/CV being best is opinion or fact [ established rather than opinionated to such status , and in a later post ]
So if we cant stick to what was said in the OP .
Obviously things have been taken out of context and assumptions made , and I have failed in creating a clear and precise explanation free from interpretation by the reader , my bad .
Hmmm ...
How to explain things so they cant be interpreted in any shape or form ...
18650 - Only talking about charging the 18650 , not other battery is being considered , in any shape or form , to interpret so is to be in error !
Cheap nasty charger = Soshine SC-S2 , this will be our cheap example as it starts charging around 1A
By the time you get to 3.8v [ batt voltage ] it has slowed to 900mAh or so
and by the time you get to 4.05v [ batt V ] it has slowed to 400mAh
and 200mAh @ 4.15v
@ 4.18v [batt V ] it has slowed to 40mA
@ 4.19v [batt V ] it has slowed to 29mA
@ 4.2v [batt V ] it has slowed to 25mA
This charger does not terminate charging but simply continues to lower the charge current
@4.23v [ batt V ] it is charging at 4mA
The Soshine is a notorious over charger if you dont pull the cells on the green light , and I would not recommend this charger to inexperienced users
It does how ever give the green light when the battery is 4.2v , and it does push cells to 4.2v , and if you want to get your cells to 4.2v , then the Soshine is the tool for the job .
[ Another charger to use to get cells up to 4.2v = Trustfire TR-001 ] for reference only - will not be talking about this charger !
Ok so we have our cheap charger ....
Now lets talk batteries :
As examples , I will be talking about top shelf batteries , Samsung - Panasonic - Sanyo
Its important to understand batteries , and that no matter what brand you buy , there will be variation , even if they came from the same production run , though it would be nice to think that they would be closely matched , for capacity and discharge capability , but never count on this as a rule .
These are unprotected cells , and as soon as you add something to the equation , you add another variable . [ in this case the protection circuit ] Another important part is the quality of the cell , and as before , there will be variation from one cell to another even in the same production run .
Now in a quality laptop battery pack , which most likely has balance charging , and the manufacturer may or may not have matched the cells [ probably not ] , but would have passed some sort of quality test , and may or may not have been graded according to quality or test results ...
Now this brings to question ? What cells are we getting ? Top shelf laptop cells , or ???? anyhow , getting of the track here ...
Lets talk discharge for a moment , [ Sanyo 2600 ] I have two purchased about 6 months apart .. One discharged @ 3.5A and the other 3.6A , that is very close performance in the same light for 2 batteries purchased from two different vendors at two different times .. [ Just an example of Sanyo 2600 ]
Also the Sanyo 2600 is my second best highest discharge capable battery [ New Panasonic 2250 from Carllie's is my best ] as well as the Samsung 30A [ 4.35v ]
Anyhow , quality cells behave a little different to the cheaper variety . [ This is important to understand ]
Everyone wants value for money , which is quite understandable , I feel the same way .
My only issue with some batteries is that while they may test well to begin with , they may not last the distance .
And more user input is required here ...
Ok the point , there are some really good batteries out there .
Battery charger relationship :
The battery is designed to store energy , discharge energy , and have the energy it stores replaced [ re-charged ]
The slower you charge a battery , the more current/energy it can store
As mentioned , the faster [ higher current ] the battery is charged at , the greater the resistance to being charged ..
More current also = more heat , so energy that was going into the battery , is meeting enough resistance to generate heat , this heat = lost energy and can also be expressed as stress [ at least I will ] , and by stress I mean the battery is resisting being charged ..
So the higher the charge rate , the greater the Resistance = greater stress [ I have explained this well enough ? ]
Now whether you use the battery or not , the Li-ion degrades [ new tech may improve this ] , but ATM , ....
Now this is very dependent on the quality of the cell in the first place , and I dont think you can put a hard or fast figure on this ....
Ok , now to the point I was trying to make ...
I see people using Hobby Chargers to charge there 18650's at around 0.8A to 1A , and do so because the Hobby Charger is safer [ Which it may very well be ] , and they think they are being gentle on the battery ... [ Now my issue here is Charge Current ] shall I repeat my issue ?
Now I see a lot of folks who who are following this lead [ buying hobby chargers to charge 18650 cells ] and using high current [ around 1A ] and then wondering why the battery sags to 4.15v or lower ... [ Some folks have blamed the battery for the sag ] And experienced people who should know better , have then also backed up the battery theory ...
Yes Im departing from the OP a little , but I dont want to leave room for interpretation .
Now it is true !!!!! That cheaper batteries will most likely [ Those variables again ] have more internal resistance and there for sag more , but when someone is using a new quality cell , this becomes less likely [ those variables again ] but not 100% without further testing to verify [ that it is indeed a bad cell , which is why direct comparison becomes important to establish a base line ]
Adding = Blaming the battery , when they should consider there charge rate !
Now to my comparing a Hobby Charger @ 1A and a cheap Charger [ In this case , the Soshine mentioned earlier ] Sorry This statement may confuse and agitate
I should have been even more clear = They start charging at 1A - Charge algorithms or charger behavior will be as per factory product [ I have quoted Soshine behavior , not Hobby Charger , as I dont use such for charging ]
Im in no way questioning the CC/CV of the hobby charger [ was I clear on that ] but the charge current . [ used by folks - and chosen by them of there free will ]
So the higher the charge current = the greater the resistance = more stress on battery = takes longer to normalize [ reach stable voltage that will be retained for some time - not taking self discharge into account ]
Now when charging at [ lets call it @ 1A ] with the hobby charger , the charger completes the charge cycle before the battery has had a chance to normalize , the higher the current , the longer it takes [ to normalize ] = the greater the sag after charge ? [ was that clear ]
/\ /\ /\ /\ /\ /\ /\ /\ /\ /\ /\ /\ /\ /\ /\ /\ /\ /\ ....... Edited [ obviously not clear ] I dont know how better to explain it ?
Now Comparing to the Cheap charger [ Soshine mentioned earlier ] , even though it starts charging at 1A , it begins to tapper off the charge current long before 4.2v [ is this clear ]
Thus allowing the battery time to begin to normalize whilst being charged [ is this clear ]
and by the time it approaches 4.2v , the battery has had time to normalize [ there is less internal resistance , less heat , less stress ]
And the lower the terminating current [ near completion ] , the less stress on the battery [ when it will have the most resistance to charging ]
Now I havent talked about CC/CV [ hobby charger ] or the Cheap chargers charge method etc ! [ are we clear on that ? ] + Edit = [ Pulse Charge ]
And Im not taking time into consideration either , the Soshine is touted as a fast charger , but it really isn't , because of the low terminating current , its not fast at all
Now what I will touch on ....
Battery termination .... [ what ever charger ]
[ still talking about charge current , that hasn't changed , so dont read more than Im writing ]
Higher charge current = higher battery voltage [ under load of being charged ] it takes time for this to lower [ its not instant ] and I have noted up to 1 hour for this ..
So as the charger reaches 4.2v , and terminates the charge , the battery under greater load will sag more than the battery under less load [ internal resistance ] as well the battery under less load will have a voltage closer to normal [ resting voltage ]
So if the battery is trickle charged to 4.2v at 25mA , it is more likely to hold voltage on completion [ can you understand this ]
I really didnt think any of this was rocket science . And I hope I have explained my thoughts more clearly ...
This has been about Charge Current , and nothing else , if you have read more into it , I just dont know how better to explain .
really old and tired old4570
Edit = Ooops , and when I say EDIT - I mean I have added , not changed or taken away ....
EDIT = obviously failed again
I do not dis agree at all ..
Cheap charger - yes to get the battery to 4.2v the charge voltage is higher [ usually 0.02v higher than battery voltage at completion ]
At the start of charging , depending on batt voltage , I have noted up to 0.05 voltage above battery voltage [ But this was not what I was talking about ]
Anyhow , electricity flows much like water , highest to lowest , [ which is why its important to match cells in multi cell lights ] , flame outs happen when one cell fails or depletes to the point it begins to draw power from other cell(s) [ reverse charge ]
Or some one puts in a full cell and empty cell = very bad !
Pudding break !
Ok - now the best I understand it , the cheap charger maintains a current above the battery voltage , to facilitate charging ..
And does so until the battery reaches 4.2v [ I am not talking about chargers that over charge - some do - and some under charge - something to bear in mind ]
I mentioned pulse charging before - charger stops charging to monitor battery state , then continues to charge and repeat this process until finished .
So how can a battery terminate @ 4.2v and maintain 4.2v ...
The best I can explain it , is that the internal resistance is lowered due to the lower charge current and the artificial voltage increase from the load put on the battery [ from the current used ] has also become lower to the point where it trickle charges to 4.2v and due to the time [ time for battery to normalize as much as it can under charge ] taken , there is little stress on the battery [ to manifest as sag ] .
Now as to whether the battery terminates @ 4.209v or 4.205v or something my MM cant pick up beyond 4.20v ???? [ I cant say ]
It could be terminating @ 4.205v and sagging to 4.196v [ >? My MM isnt good enough to know for sure ] I get 4.2v and 4.2v after one hour with quality batteries ..
Got some holiday time coming , is it Melb Cup ? so might run some tests to see how much current affects battery Voltage on discharge and charge ... and how long it takes for the battery to return to normal [ resting voltage ]
Ok the other thing , the charger voltage may be 4.22v , but that does not mean the battery is 4.22v , as the charger needs to maintain a higher voltage to charge the battery , and the charger behavior [ charge method ] of turning on and of as it checks the battery voltage , means as the battery reaches 4.2v [ some part of 4.2v ] it stops charging .
As to how much the battery sags at this point is variable [ depending on charger and quality of the battery ] and I can only speak for my own personal experience .
Now Im going to go watch some tv ...
I think we have both spent too much time on this already.... :(
Your thought process is clear. You say were not talking about charging profiles, cc/cv etc.. and this is where the key information is missing.
But...
and 200mAh @ 4.15v
Here you have explained the charging profile of the cheapest charger
And this is where the profile of the cheaper charger is being described as allowing a cell to "normalise", which the hobby charger's true CC/CV is said to not be able to provide.
The difference in opinion here maybe is that I see a normal CV phase of charging as being able to "normalise" a cell equally as well following a reasonable charge current in the CC phase.
My iCharger takes over an hour in the CV phase due to the IR or the cells, and cells off my charger are at 4.20V while connected, drop to 4.18 immediately after disconnection and stay at that voltage for the next couple hours.
Essentially, I need clarification to your definition of termination. At what current does your comparison hobby charger terminate.
If the termination occurred at 0.5A 4.20V, I would expect a 500mOhm battery to have a resting voltage of 3.95V!
Im going to try to take a break from this thread, as much fun as it has been, its seriously sapping our time, and Im going to go study how porcelain is bonded to the underlying non-precious metal core
This is not according the guidelines from the LiIon manufacturers, they specify a minimum charge current, when you get below this current the charger must stop charging.
Lol, this never ends
This is where my whole argument points towards - Definitions!
A voltage differential MUST exist between the charger and the cell for a current to flow - Correct!
But the voltage at the terminals of the battery while your charging are EQUAL. i.e. A charger voltage of 4.22 Means, a cell voltage of 4.22 as current is flowing.
If charger voltage was not equal to battery voltage then if we applied/removed a charging current, why do we see a temporary rise and fall in the voltage of the cell?
The only time the voltage can be different is in practice due to the resistance of the wires connecting the output of the charger, and the battery terminals.
In a theoretical parallel circuit, the voltage present at the terminals of the charger EQUAL the voltage at the terminals of the battery. During charge, the voltage at the terminals of the battery will rise to the voltage of the charger - floating voltage.
SO, this is where the water analogy fails... The voltage of the battery terminals during a transfer of charge (i.e. in a charger circuit) is EQUAL to the voltage output of the charger. this doesn't work in the water analogy.
Once this has been established, maybe you can see this from the way I see it?
Its just understanding the Definition and differences between - battery resting voltage vs floating battery voltage under charge
Battery resting voltage = the voltage the cell will be happy to maintain at its level of charge (the "normalised voltage" to ouse your terminology
Floating voltage = the voltage of the cell while your applying a charging current (which as explained earlier, MUST be higher than resting voltage for a current to flow)
I think its the definition above, combined with the following 2 that gave us so much to discuss...........
Max voltage reached = the peak voltage the charger gets to
1) cheaper charger = 4.23 - 2.25
2) hobby charger = 4.20
Cutoff voltage = I this this is where 2 different definitions have been applied in your example (inadvertently?)
1) Cutoff voltage cheap charger = you defined as the resting voltage of the cell (4.20v)
2) Cutoff voltage hobby charger = a floating voltage of (4.20v)
(quote box because it looks cool)
Overall.. what I'm trying to say is.
1) I am disagreeing with the use of a difference in cell resting voltage as proof to explain why a charger may be kinder on cells when both chargers terminate at the same current.
2) and I am disagreeing with the differences in cell resting voltages quoted for the cheap vs hobby charger because they were not equal comparisons due to a missing/unaccounted/different definition of what the cutoff criteria was.
Yes , its not that I dis agree , its that , I was not talking about it , or going there , as it over complicates a simple explanation ..
And you keep going places that I wasnt ?
And as for terminal voltage , again , 4.22v is not an issue for me , and yes I call it insignificant , you obviously have issue with 4.22v and I just dont know what else to say about it .
I have measure terminal voltage , and when doing so you are measuring the voltage from the charger , does this artificially raise the voltage of the battery ? I dont have the scientific equipment to say one way or the other , only that when I pull the battery it reads 2 tenths less . [ Within seconds ]
This is what I have experienced and nothing is going to change that , until I see first hand .
Again I dont see why you need to complicate this or add stuff Im not talking about ...
BAtt Voltage in charger [ cheap chinese ]
So how do you measure 2 voltages at the same time ?
How do you differentiate between the two , as the MM would read the highest voltage ?
If the charger maintains a higher voltage than the battery so that current can flow to the battery , how can the battery be the same voltage ?
So you would need some way to read the internal voltage of the battery whilst monitoring the charger voltage [ I cant do this ]
So what I have done is measure the voltage under charge , + - terminals with the battery in place ...
Then pull the battery and measure the internal voltage , and they were not the same ...
This is my experience ... and you cant change that ...
