Can anyone step up for an AA/2AA only BLF budget flashlight?
I dont like that crap looking reflector protrusion ;)!
Spark done away with much better design in their reflector-capable lights where you can buy reflector and scew it in :)!
Consider that the trust fire is dirt cheap.
Also (crazy huh) if this design was mixed with Reys Ti light we could have the creation of the first Daleks’ :wink:
I can see it now when we put a bettery in they say ILLUMINATE! , ILLUMINATE!! :slight_smile:
I would like a AA version of the x5 in the limited edition version Blf group buy ally not copper
Oops already covers in post 152
So there at least two people want one!
Yeah, a tiny little memory chip and micro-speaker …
Is the AA powered X5 available to buy on its own?
Not yet. As I understand it, it’s a new design created entirely for that X6v2/X5 group buy and it supposed to go away afterwards, at least as far as blf is concerned. But if the X5 proves popular I wouldn’t be surprised to see it live on after the buy, although probably with cheapened guts.
And the X5 is not AA powered, it is 14500 powered.
And the X5 is not AA powered, it runs on 14500’s.
Does anyone still have this BLF edition light?
The interesting point is that the driver uses a PAM2803 boost converter and is controlled by ATtiny13A. It can be driven by AA or 14500.
A picture of the driver can be found in post 88 in this thread.
Bumping this a bit…. Each time I see a group buy I cannot help but wonder when will a great Aa/AAs BLF flashlight + driver come to life ….
Here’s a 1-2 AA Boost Driver at IOS.
Single mode :frowning:
Intl-Outdoors used to have some EOSlamp 3-mode drivers that are pretty good. They seem to tolerate all of 2.4 v., but less than 3.0 v.; they go single mode with 2 alkies, but give 3-modes with 2 Eneloops. Maybe Hank could get his hands on some more of those drivers. They were advertised as 3-mode plus strobe, and always start on low. Mine always start on low, but none of them had a strobe as a 4th mode.
I’ve converted three of my old Fenix L1Ps to the EOS drivers and XP-G2 emitters, and I really like them with a single Lithium primary. Using the old L2P bodies, I have the option of running 2 Eneloops for some really lengthy run times.
EOSlamp offers a rather pricey “Van 32” 1xAA that appears to be the equivalent to my modified Fenix’s in both output and physical dimensions. A group buy on the Van 32’s might be an option.
Thorfire TG06 with a 219C or XP-G2 2C, better driver for those who are bothered by PWM and who like me want mode memory. ML/L/M/H mode order as the default. I would be one happy clam. :)
Hmm that sounds lovely
I never saw the EOSlamp driver from Intl-Outdoor but not really interested in a single mode driver. They may have been the LD-20 or LD-30, which have a lot of variations.
I did get a couple of single mode NiMH drivers from RMM recently to try that out again, with the 4/3AF NiMH cells I’ve been swapping into my last year’s 18650-size lights.
RMM said in his thread he’s had a multiple mode driver in the works, nothing ready yet.
The LD-30 drivers I’ve tried are tolerable with two NiMH cells, but with a white emitter (think it’s a DX Nichia B, I forget) the voltage drops really fast and the light gets really hot.
After maybe 20 minutes of runtime at high, the white emitter light drops to moonlight and won’t recover for more than a few seconds of mid or high level. I’d think most of the energy went into heat, not light. Not long enough to walk the dog or pick up groceries from the market nearby.
This is one variation: Test of LD-30 Boost 1-2 AA cell
Strangely enough perhaps, I set another one up with an amber XP-E2 (from RMM) (also using two 4/3AF) and it has a low mode that’s not quite moon-low but will last at least a week or more continuously on. Wonderful nightlight. Haven’t yet run it long enough to have the light go out, I get impatient to check the voltage and recharge the cells. Patience.
These are both using a Solarforce 2x body and dropins wrapped up in copper foil).
Sounds like someone needs to step up and make this happen.
(Make it in copper!)
Seems like no love for the AA lights any more…
I must say… I have acquired an Orcatorch T11 and like it! It has mode issues, disco modes not hidden but other than that it is pretty good. I would like to see a lower low, but Turbo is good on it. It also has about an 18mm smooth reflector, it will throw for a single AA light. It is glued tight, and I do not know if they would work with us on any of the nit picky issues… I can ask!
Matt
