Ooops sorry didn't see this. Definitely Nyogel 760G. The difference is minor but varied radically from light to light, all depending. I've probably seen high as of 20 lumens, so for 600'ish lights, that's 3.3%. I'd say 0-4% in a range.
You probably won’t see much difference with a NCR18650B.
As for a solid post… not much explanation is needed. Just solder a chunk of metal to one end or the other. Or even just put a solder blob on where a spring would normally go. For parts, check http://www.mtnelectronics.com/ , under Components -> Springs / Brass Buttons.
This is surely not how that works, when 'on', a switch only 'sees' the voltage over itself and in principle only the current determines how much it can take. But voltages in the circuit are not irrelevant, during the switching on and off, arcing can occur that damages the switch, this effect does increase with voltage. So in the end voltage does matter but not in the way you reason.
That that small Omten can take 21A is nothing less than a small miracle, in principle the building design is good, but with its thin metal strips in a fairly soft plastic housing I would not have given it more than 3A, until it happily survived 16 in my test, and now 21A in your triple .
I doubt it would handle 48A because AC, measured at RMS and not peak voltage, “sees” less resistance in a conductor (or switch assembly) at a given voltage than DC does, so there is not a direct correlation between the two. IIRC (and it’s been a long time ago since I was in it this deep) the DC capacity of a conductor (switch) is roughly calculated at 62% of an equal AC voltage and current level.
Ohm’s law is far more complex with AC than DC- AC and Ohm’s Law explains it better than I can.
You are correct. I unsurprisingly noticed no gain from the spring bypass using NCR18650B. I have some Sanyo NCR18650GA’s on the way so hopefully I may see a difference using those.
In hindsight I feel silly asking about the post mod now. it’s really straight forward lol.
The s2 tailcap and switch do look sharp on the a6 though I must say.
I have most of the anodizing brushed off just leaving some blue highlights in the knurling and around the switch.
Ya will do. I went out today to grab some oven cleaner, got to Wallmart, spent $47, and came home without oven cleaner. D’oh.
So I put the wire brush on the dermal when I got home, just to give the oven cleaner a head start when I do eventually get it. I got a little carried away, and here we are.
There is a Omten switch in the S2+ metal switch assembly?
I just got an answer from Simon (Convoy), I asked him about the maximum current on the S2+ metal switch, his answer is 3A (no voltage mentioned, but I think it’s meant in the flashlight context).
I have a blue S2+ host on it’s way, so I will see…
I realized I could just move the switch over from the a6 and put it under the metal button in the S2 tailcap. So now I have the A6 switch inside the S2+ tailcap on the rear end of my A6.
Works perfectly.
Also I did some water testing of this hybrid tailcap. Without adding a gasket or doing any further modification, the tailcap with metal clicky and A6 switch appear to be waterproof on it’s own.
Granted I only filled my tube so didn’t get anywhere near the ipx-8 standard depth of 2 meters, but I did slosh it around and click it 40 or 50 times.
When I took everything apart I looked and there was no water ingress, so then I did the same thing but with batteries installed. Everything turned out fine.
When I took it apart after the second test I realized there is space to double up on o-rings on both ends
Is the coupon code for the unanodized version still kicking around? I think I may grab one of these in a cooled tint. This “3D” tint is pretty warm, like incandescent or warmer. I think they may have sent the wrong emitter in this light.
The sku says 3D but Idunno about that. This is the warmest light I’ve seen since my mini mag incandescent back in 1999, warmer even.
In some instances current up voltage down and vice versa. (A.C. transformers; multivoltage motors for example). But I can say that when dealing with 120v vs. 277v systems the allowabe wire ampacity does not change. 12 awg is still only allowed 20 (in general) amps at either voltage. What does change is the amount that equipment will pull. I.E. I can put twice as many fluorescent lights on a 277v 20a circuit as compared to a 120v 20a circuit. :)
I got already a lot of troubles with this light. Firstly the clip was totally deformed and the ring in the tailcap was not fixable. From the support I got a replacement but it took a lot of time.
Since about 2 weeks ago the moonlight mode does not work any more and the support from Banggood (Neils assistant) just don’t want to help me but wants me to order a new driver. WTF?
Firstly I don’t want do solder around on the light just because some parts are shitty and secondly I dont want so spend any more money on a product that was produced faulty. Where is the good support that everybody is speaking of?
Use the text editor. Delete the image file(basically everything but the words you typed)and reinsert it with the sunset icon. In that drop down box set size to 100%.
The SANYO B's are the same as Panasonic B's - you should not see any difference. If you want high performance, you really need to be using high performance cells, like the Samsung 30Q, LG HG2, LG HE2/HE4 or higher capacity 10A cells like the SANYO GA or LG MJ1.
That post was supposed to say 18650GA. I have some Sanyo 18650GAs on the way that I’m hoping to see some better results with. I’ll go back and correct it the post avoid any further confusion.
My step down from turbo is 55 sec., I’ve read it was timed not thermal step down. My main reason for mentioning this is my A6 doesn’t seem to go into “TURBO” level. I mean it steps up to the highest setting (level 7 and level 4) in each mode but it also only pull 3.2amps on the highest level (I mentioned all this on another thread) with an NCR18650GA which pulls 4.75 amps on 2 other DD lights I have. I have taken this light completely apart and cleaned and polished some contacts and it has made no difference. I was going to bypass the springs with some braided wire, but I don’t think that’s the problem since almost everyone else is pulling over 4 amps tail current without bypassing. Do you think touching up the solders on the components might help?
