Yesterday I received my exchange long(er) body tube from Banggood (Thanks!), it was a long wait, but it actually helped - less force needed to make contact and even wall thickness.
But for a second run tube I’m a little astonished, there was a lot of burring of the aluminum inside one end, actually at first it was difficult to insert a cell before I removed the burr.
Hi,
you’re right that I have not posted much here, but I am quite active in the sister forum (TLF) an read quite a lot here.
The flashlight is great but as was already mentioned quite a lot the quality differs a lot between each light.
I told them and I think after about 3 or 4 emails the agreed to send the driver, when I mentioned that I have read the whole thread and tried everything that was written here. I even went to a friend with much more advanced soldering skills than mine who had a look on the driver and resoldered the 7135, but with no effect.
Currently I hope that I will get the replacement head quite soon, because I really miss the moonlight and battery level function.
That sounds like the 7135 chip is flaking out sometimes. It may be fixable by re-melting the solder joints on that chip. It’s the one with three pins on one side and one big pin on the other side. It only takes a quick touch to melt, and you should melt the two outer pins plus the big one on the other side.
I’m guessing, if you’ve moved the driver, that you can solder.
I’ll definitely try that. Thanks for the help ToyKeeper! :bigsmile:
UPDATE: Issue fixed! I’m so happy!
Starting work on post #2
Off the subject…… I ordered parts from RMM to mod one of my a6’s into a triple! Everyone in my house will need 8) . Richard has already shipped my parts and I’m pretty excited to say the least. I already went and stocked up on some flux and solder as I need to complete some more spring bypasses as well. :party: :bigsmile:
I love this light but I’d love it more if it had more throw. Is there a drop-in reflector that would help in this regard? A less-than-perfect beam pattern would be OK given a great hotspot.
Not looking to go into any ‘heavier’ changes, this light is nearly perfect as-is in every other way. Just wanting to get it closer to what my C8 does.
Phil
Probably not going to happen, due to the size of the light, specifically the diameter of the head.
I’m no reflector expert but there is a link for a tir lense in the op. I’m not sure what the hotspot is like with that lens. But I think someone did put it in their light. Maybe you could find a smooth reflector in the same dimensions.
The current reflector is approx 20mm in diameter by 12mm in depth.
dudunphy,
Infreakingcredible thread…. This thing just keeps getting better… Your time and dedication on this thread are doing many people much good in helping with not only the BLF A6 lights, but any others they may have problems with…
The problem is never the problem, SOLVING the problem is a always the actual problem, and this thread is a huge help…
Wouldn’t be possible without some of the organizers/developer’s showing up here! Standing on the shoulders of giants as they say! Thanks RemanG!
I don’t think an optic will give a tighter spot but a smaller emitter should. It’s possible there’s a deeper reflector with the same OD but the head might not screw on all the way.
I think I’ll try that TIR lens and look for a SMO reflector, or maybe a longer head and reflector I can lego on. This is my first 18650 tube light and there’s nothing else about it I want to change in the least way. I’m not the kind to put a moustache on a Mona Lisa :bigsmile: If I go further in this direction I’ll get another host. Thanks to all!
Phil
(Adding- I just noticed Dudunphy is collating the spread-out info into the early part of this thread for easy access- that is MUCH appreciated!)
I found an optic that nearly doubled throw, but it was quite a chore making it fit in the A6. Smaller emitter would help most, be easiest to accomplish, but only the XP-G2 would be feasible as this is a direct drive light and an XP-E2 would fry. So a de-domed XP-G2 would be about the best you could hope for, throw being an element of die size combined with reflector/optic diameter the small tube lights just can’t compete.
I’d rather alter an added part than the light itself and IIRC you posted about that here so I’ll check it out. I’m not quite up to speed with mini-electronics without the proper tools, eyesight, or bench setup for that yet so I won’t try an emitter change till I toast a few cheaper lights and parts as I learn. This one deserves a better fate than that and I have a work rule I follow religiously: If I am not very very sure that I can make it better, then I’ll leave it alone since I might make it worse trying. It’s been a decade since I tried doing fine soldering and I’m rusty at it. No sweat with drop-in parts though, those can always be as easily changed back if I screw up.
Yeah, I do understand the diameter limiting what can be had (as does the reflector length and die size). I’m not expecting a C8 style throw, just wanting more of a defined hotspot in the middle even if that takes a little from the edges. It won’t take a lot to make me happy and besides, who is ever completely content if there’s a decent chance for more or better? :bigsmile:
Phil
Putting a new emitter in this light is actually quite easy. The shelf the emitter sits on is right up top, not down in a hole, so it’s very easy to get to when the bezel is off. Get a de-domed XP-G2 from Richard when he gets back, on a 16mm Noctigon, and simply swap it out. This just takes a touch on the pad of each wire to release them with the soldering iron, put the new one in and again touch the wires to solder em on. Done. Not a skill set there. I mean, yeah, you have to be somewhat careful not to smash the dome or something, but it’s not ittty bitty stuff or really tedious. Pretty sure you can do it and it doesn’t entail taking the driver out or anything.
Give it a go!
Had to post quick. O.m.goodness I’m nerdin out here. I got my stuff from Richard today. Did some finagaling and got my triple a6 together. Holy crap what did I check first? The amps! 12.7a and climbing! Then pzzzzzffffp. It melted the negative off of the star and the carclo lens legs. (Probably not the best heat sinking going here….) But holy heck it was cool while it lasted! D.B. had mentioned to me how cool the first triple would be and it’s really fricken fantabulous. I’m not sure what else I fried…. Will update soon and hopefully get some beam shots.
:party:
Well…. Still having heat sink issues. I had ordered a copper spacer from mtn. But those are for a convoy and I couldn’t bring myself to hack almost 9mm off of it to fit in the a6. (nor do I have the tools at home) So I had coiled some solid #12 wire up to make the spacer. I’ve since melted the positive off of the star and again the negative. So I may have to bring my spacer to work tomorrow so I can get a nice straight cut on it.
Goes to show why heat sinking is so important and I believe we’ve also found a new method of thermal protection! Albeit permanent for those who don’t solder.
Fwiw it made the ui pretty funky. Lost strobe and after one cycle bike mode goes to moon. Hmmmm.
Could you describe the funky UI in a bit more detail?
I’m investigating some issues which only happen at high power, and I’d love to know if what you’re seeing is the same.
@ToyKeeper. Yes I believe first and foremost timing was changed. Super fast clicks would cycle forwards but erratically. I could reverse to turbo but reversing again to the hidden modes was tricky. I got it into battcheck mode quite a few times. Only once was I able to get into strobe but it was very slow I let it sit there for a while just to make sure it wasn’t batt check. I could get into bike mode with the right click timing but it would cycle back to moon on its own. It would also jump lower or flicker once I got to mode 4 or 5. Getting into config was very difficult - however a series of very fast clicks would get me into it. But it seemed that it had almost put itself into 4 mode sometime before I ever tried to config it. I also reinstalled the old led and it was working fine. One thing I want to try is a weak laptop pull but that seems to defeat the purpose of a triple.
So changing the Vf or just the heat involved by doing this messes with timing? Also seems to mess with pwm?
What were your issues?
