Review - Xtar H3 Warboy
27 posts / 0 new
old4570
Last seen: 1 day 7 hours ago
http://www.xtarlight.com/05-chanpin/p-001-1.asp?styleid=370  = Product Page ...
 Lets get straight to performance :
On TURBO my light box gave me 1070 to 1100 Lumens
HIGH was 470L
MEDIUM 240L
And LOW returned 90L
Moon mode is so low my light box wont read it ..
Current Measurement :
Ok , this is simply what I was able to measure
TURBO was about 2.3A
HIGH was 0.95A
and MEDIUM 0.54A
with LOW giving 0.22A
Moon mode = To low to measure ...
H3 Warboy :
It is certainly a well made light , everything one would expect from Xtar. I simply cant find fault with the build quality .
Modes run Low , Med , High , TURBO .. ( With mode memory )
And to access Moon mode simply double click with the light on in any mode ..
To turn the light on just click once , to change modes click and hold , the light will cycle through the modes except for moon mode ( Remember , double click in any mode to access )
Now this is a 90deg light , and is designed to be used with a headband .
The headband is fully adjustable , and whilst Im not sure how big my head is , I did have to extend the head band as far as it would go . Which was actually very comfortable once opened as far as it would go . Do people have larger heads than me ? Yeah they do , so perhaps a slightly larger head band could be the way to go ( Perhaps an option to consider )
Back to the H3 , the on of / mode button is on top , battery goes in from the bottom , and its actually quite a small light for a 18650 as well as being rather light weight . Which is all good considering many will strap this light to their foreheads . And ever since receiving this light , I cant help but feel that it might make for an excellent bike light as well . A nice small trim figure 8 style handlebar mount for the H3 .
Back to the here and now :
Which ever way you look at the H3 , its a well made ( high quality ) trim and light weight light that puts out . ( Lumens that is )
Im really looking forward to it getting dark :
Beamshots !
I will see about trying for some video as well :
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
Edited by: old4570 on 08/27/2015 - 01:38
akoposilester
akoposilester's picture
Last seen: 11 months 3 weeks ago
subscribed… beamshots awaiting…
FL Newbie
Cula
Cula's picture
Last seen: 2 weeks 12 hours ago
What is the retail price for this headlamp and where can we buy it?
Thanks
old4570
Henk4U2
Henk4U2's picture
Last seen: 1 hour 58 min ago
Mine came yesterday (GAW on the other forum 0:) )
Only had time to play a little with it. It is a rather small light but it does not feel flimsy in any way.
Massive output for such a small light. Good mix of throw and flood. A good walking light, I guess.
There is no spring on the driver side. I think the “ring” on the driver side acts as a kind of inverse polarity protection.
Can’t confirm that this prevents flat top batteries from being used (had no charged flat top 18650’s available).
It is a good tailstander! First thing I thought off was reading in bed with my WarBoy besides me on the nightstand.
Talking about the bedroom: it has a moonlight mode that is so low you can look direct into the (LOP?) reflector.
So no fear of waking up everybody when you have the munchies Evil
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
TheBo
TheBo's picture
are you sure you can go over 1K lumen with just 2.3A?
Rufusbduck wrote:
Getting discouraged is normal but doesn't finish the job.
old4570
What I was able to measure ..
Too many variables ...
I would expect the light output to be near enough correct , but measured current ?
There is a very small rim , that is not anodized , so how well the MM contacts ?
Cos when the tailcap goes on , it has a much larger contact surface ...
old4570
Video attempt , used a dashcam , didn't work out too well
vēer
vēer's picture
Last seen: 2 months 5 days ago
Thanks for review!
Looks tempting, I have two of their smaller H2 lights on their way to me for close up work and Im looking for 18650 headlamp also!
This is, however, above my budget :D!
Oh and interesting that they dropped red emitter rom H3!
saypat
saypat's picture
Last seen: 1 week 6 days ago
1000 lumens for 2.9 hours? No stepdown mentioned? That can’t happen. Please explain, thanks.
old4570
saypat wrote:
1000 lumens for 2.9 hours? No stepdown mentioned? That can't happen. Please explain, thanks.
Obviously not , once the battery drops bellow a certain voltage level the light will drop out of regulation ...
The run time is for the mode , not the amount of light produced ..
The variable there will be the battery itself , and Im not going to get into all the battery variables that will affect run time ..
Take it as an estimation :  And they didn't even mention which battery , (?)
Henk4U2
Henk4U2's picture
Well, the question was not addressed to me but it made me curious and I dug up my DMM.
Based on a fresh loaded Olight 3400 mAh (4.19V):
TURBO was 2.56A
HIGH was 1.10A
MEDIUM was 0.54A
LOW was 0.21A
Moon mode = I guess less than 0.01A
Just for the record ……
edit: As I have no sphere nor a pipedream contraption I can’t give you lumens
TheBo
TheBo's picture
Seems to me that to make out those 1.1klm otf should be above 3.2A…imho
old4570
TheBo
TheBo's picture
exactly, doing some maths, and taking some numbers i got that for u3 bin (cool white, which is the best in output lumens) I get, with 2.5A (it’s obv. lower at 2.3) considering an average of 340 lm at 700mA (between 320 25°C and 364lm 85°C) at a curve a multiplier factor of 2.8 (roughly) that gives me 952 lm at best, not considering losses, and the circuit efficiency, and these are LED lumens not OTF lumens.
But i surely will be wrong, I’ve never been that good at maths…. Sad
@old4570 i thank you for reviewing this headlamp, I, in no way, intended to comment the review itself, it’s the opposite, i’m glad you took some measurements, I was just thinking out loud about the xtar specs. Sorry if i offended you in some ways, i’m a n00b and i would never do that to an *old*(forum-member)4570
old4570
For comparing light levels , the camera does not show true output ...
old4570
TheBo wrote:
exactly, doing some maths, and taking some numbers i got that for u3 bin (cool white, which is the best in output lumens) I get, with 2.5A (it's obv. lower at 2.3) considering an average of 340 lm at 700mA (between 320 @25°C and 364lm @85°C) at a curve a multiplier factor of 2.8 (roughly) that gives me 952 lm at best, not considering losses, and the circuit efficiency, and these are LED lumens not OTF lumens. But i surely will be wrong, I've never been that good at maths.... Sad @old4570 i thank you for reviewing this headlamp, I, in no way, intended to comment the review itself, it's the opposite, i'm glad you took some measurements, I was just thinking out loud about the xtar specs. Sorry if i offended you in some ways, i'm a n00b and i would never do that to an *old*(forum-member)4570
No offence ...
1070L was the lowest reading I could get ..
It is in no way a direct relation to measured current .. Measured current is simply what I was able to measure ...
With the tail cap in place I would expect far better current flow ..
And lets not forget those terrible variables ...
The cree chart @ 2000mAh , = 776Lumen @ 85Deg C as the minimum output for this emitter .. )  Minimum  (
Cree does not like to speculate about maximum because of the variables , so they bin there emitters by minimum standards ..
Now 320 @ 700mAh  ( 85deg C )
364 @ 700mAh ( 25deg C )
Generally these are minimum ...
SO what happens if your emitter is above the curve  ?
Remember emitters are tested and binned on making the minimum grade , so if it exceeds the standard ?
Anyhow , all I know after all these years , Is the Variables .  Yes you can look at the numbers all you want , you can punch numbers into a calculator ..
But you cant factor for the variables when it comes to the emitter itself , or how well or badly it runs .
Oh for a 10 thousand dollar light sphere ...
Or even access to one , so you can calibrate your own light box or measuring tool ... ( PVC pipe or what ever )
I simply use a light of know output to calibrate my lightbox , and then measure ..
Its proven to be close over the years , very close .. ( SO I tend to trust the lightbox more than measured current )
Simply because if you reach for the calculator , current does not match output ..
Those super high current drop ins :
Years ago Manafont sold some XM-L P60 drop ins that could pull 5A or better .
Thats huge !!
Now if you got out your calculator , and started crunching numbers , you would see huge output figures :
Unfortunately reality bites hard ! Really hard !
With the emitter ice cold ( Winter ) I saw a 1300 Lumen start in my light box ..
Unfortunately heat related sag was almost instant , the output dropped in seconds to 1000 Lumen , then down to 900 Lumen and then 800 Lumen , and the longer you ran high the more the output dropped .. I saw around 400+ Lumen after a minute or so on high ..
These drop ins were crazy ! , the emitters simply could not sustain output at such high current ..
I started putting in 1.4A and 2A drivers into my XM-L builds because the emitters could sustain the output really well at these current levels .
So if I had a light that did 580Lumen , it would do it until the light fell out of regulation .
The pills drawing 5A would sag way bellow this output in the first minute , and probably damage the emitter .. ( So sure its great to brag about 5Amp )
So what was the actual point ?
And did output match current = No ...
But if you crunched the numbers , the paper output was insane , which was not really matched by reality ..
Emitters have gotten better , much better , more output at lower current ..
I have a XP-L V6, and a XP-G2 R5 , and will be building some drop ins , to test the emitters .
Both may be run with 2A drivers or 1.4A drivers ( Not sure yet )
I was thinking of dropping the Xp-L V6 into one of my Manafont P60 XM-L drop ins ( could be insane )
bibihang
bibihang's picture
Last seen: 17 hours 19 min ago
Quite a nice headlamp you got there, thank you old4570 for the review.
old4570
So many Variables :
If you were around for the SSC P7 , oh boy !
The big variable with this emitter was the vf ( or voltage forward ) ...
It ranged huge .. Anywhere from 3.4v to 3.8v or even over a larger range ..
Most drivers of the day were set to 3.7v to the emitter ...
If you were unlucky you got an emitter with a vf that was high ( very bad ) , and the emitter ended up being very average to be kind .
Or you may have got an emitter with a low vf , these emitters pumped hard !
Now the SSC P7 was not a cheap emitter , and to get a good one , you needed to buy a decent lot , like 5 to 10 emitters to get one or two outstanding ones , that was rather expensive .
I got about 6 or so all up , and only got one outstanding emitter .. and a lot of very average ones .
+ They were a PITA to utilize ... ( Mod with )
To cut a long story short , the XM-L buried the competition ...
And in the old days , getting a really good emitter was like winning the lottery , the XM-L changed that .
I played with almost all of them ..
SSC P4 - SSC P7 - MC-E - XR-E - Osram Diamond Dragons , and there was another one ( forgotten its name )
And they were all some what iffy , you may have got a good one , and maybe a bad one , paper numbers were ?? .
I had a diamond dragon that could do near on 300 Lumen , but it was fragile and I had to keep playing with it till I killed it ..
I had 3 Diamond Dragons and only one of them was good , the other 2 were very average .. Barely able to pump 200 Lumen ..
I recently found some Osram emitters fitted to bases , I will see if they pump or fail .. ( Dont know if they are dragons or not )
So , I dont know what more to say , except you get what you get ..
And there are just to many variables that affect out the front lumens , and one can only do the best one can .
old4570
can wrote:
and one "can" only do the best one "can" . Were you talking about me? Just kidding, thanks for the reply. I was not around for those old emitters except for one mce from an old stock light which I replaced with mtg2.
No - just a general thing to say about trying to be as accurate as one can ...
vēer
vēer's picture
Im gonna ask this question in 3 reviews on H3, mine exluding :D!
So, the question is – does the thermal stepdown works on yours?
Seems like it doesnt on mine, it always stays on turbo even when the light becomes scorching hot!
Turning it down to high doesnt help either, the light still stays hot, hot, hot!!!
old4570
vēer wrote:
Im gonna ask this question in 3 reviews on H3, mine exluding :D! So, the question is - does the thermal stepdown works on yours? Seems like it doesnt on mine, it always stays on turbo even when the light becomes scorching hot! Turning it down to high doesnt help either, the light still stays hot, hot, hot!!!
Wow , I have used the H3 quite a bit ( with headband ) , makes for an excellent work light .
But I use the lower modes ( less reflected light ) , I dont think I have run mine on high long enough for it to get hot at least not in the headband where it gets 90% of its use ...
And turbo ( or as high as it will go ) is just a little too bright , and I find I have little use for it ..
Hmmmm , I'll see if I can get it to do the thermal control thing , but even on turbo , I never noticed it getting more than lukewarm .
I guess you must be running it for extended periods ...
vēer
vēer's picture
But regardless it should step down and step back up only when the temperature is acceptable, on mine it doesnt do that, it stays super hot when on turbo and really hot when ran only in high mode, it takes a little while for it to warm up on high, but it gets there.
Emma
Emma's picture
Last seen: 5 years 5 months ago
The moonlight just 1lm?what the size of this light.how long you bought it?
Running like a man!
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 12 hours 38 min ago
you know its Australia when you see the hills hoist lol
old4570
I ran mine for 10 minutes , and it got very warm in the head , but it was not sizzling hot . I was quite able to pick it up and hold it .
+ After 10 minutes on turbo , my guess is the battery voltage would be such that output would be dropping ...
It never dropped into safety mode
Room temp is 23 Deg C
will34
will34's picture
Last seen: 2 days 18 hours ago
I just tested mine:
Turbo mode, ceiling bounce, no cooling of any kind:
0:00 – 81 lux, ambient temp
2:00 – 79
3:00 – 79 uncorfortable to hold, starts dropping slowly
4:00 – 51
5:00 – 65
6:00 – 78 back to full brightness
7:00 – 45
8:00 – 38 lowest low recorded, then raises
9:00 – 78 stays here for a couple second then drops again
After the whole body gets to an uniform temperature it ramps from 38<->78 constantly. I guess it works?
Conclusion: it will drop to approximately 50% output and then raise to highest again. This is a “dumb” regulation, a smart regulation would find the correct brightness and stay there, not jumping back and forth like this which is very noticeable if you’re in outdoors and 1,000 lumens becomes 400 in a short while.
