Gearbest gone Ebay now?
Hi, thanks for reminding me.
I didnāt read the āebayā word on the title/subject.
Iāve deleted my post
I received the one order from here. It looks like the same as yours. The good thing about this C8 is that it takes standard C8 pills. It can serve as a good cheap C8 host.
Got mine in and it is an OK little light for $4 shipped. Seen much worse. Original tint has bluish color, but much whiter than I would have expected. Reflowed a Nichia 219A from FastTech onto the aluminum board and it makes for a nice Warm White little lightā¦ a good improvement for less than $1 with the new LED. The pill is hollow, it is the middle section and the driver and LED are press fit from their respective sides. There is plenty of wire to pry the LED out and desolder it for reflow. If I get in any blank noctigons, I may file one down to this diameter, but the stock one is not running hot at all. The driver is one mode, but looks pretty good and runs no problem on a 3.2V LiFePO4 AAA with a noticeable improvement in brightnessā¦ Good find cajampa!
Plastic lens, but Hugsby XP1 lens fits, needs an Oring up front tooā¦
Nice thanks for the update
Good idea to use the Hugsby XP1 lens, i have two broken mod casualties here that gladly will donate some parts when i get mine.
Do you have any recommendation for the best LiFePO4 AAA? Unfortunately HKJ dosenāt test much LiFePO4 so i have no idea what to get.
And get some 10mm sinpads instead of noctigons, those are dropins on most small lights like these.
I have the Soshine ones from FastTech, they seem to be good, I do not know if they are the best though.
The 10mm sinkpads are too small for these, there is only a shelf and they would need to be about 2-3mm wider, thus the filing down of the 16mmā¦ Either way, good little light, even stock, for the moneyā¦
Correction, THESE are the LiFePO4 10440ās
Aha good point, i didnāt think about the shelf, but you right then starting from 16mm is the only way.
EDIT
I will probably pick up some of those Soshine cells next time i order from fasttech, do you know any small cheap good chargers for them? I can use my opus but i am thinking for gifting.
No, that is the only problem, for LiFePO4ās there are no good small cheap chargersā¦ Perhaps the Nitecore D2? Or the Xtar WP2H
I updated the post above, the first ones I linked were the 3.7V, I have the second ones, the 3.2V
That is to bad, i will search for one.
For 4.2v 10440 we have the cheap and excellent Xstar MC0, i hope one for LiFePO4 will turn up.
Mine has a gap in the key chain eye, so they gave me a full refund.
I just ordered one of these for US $3.44. I figured that a Nichia upgrade might be all this needs.
It looks kinda like a 14500 version of the Sharp Eagle ZQ-SH-05
Or a SingFire SF-361 clone.
Once you receive it, can you let us know if it takes 17mm driver or 14mm driver? Thanks.
Assuming I have the seller right, and Iām pretty sure I do, 4-cn922 sent me one with an lb emitter, but solid pill, driver seems decent, switch seems nicer than others, too. Nicely finished c8.
I bought two C8s from securityingstore (http://www.ebay.com/itm/331455918001?\_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT). The best thing is that they take the standard UF brass pill, e.g., the one sell by FT. It will make a very good host for the cost (<$5).
I think they are the same as yours.
Thought that TomTopās 18650 might turn in the vein of Hugsbyās, alas it did not, waste of money, made pictures of it, in short - plastic reflector, dirty lens, two bright blue LEDās on each side of the switch, didnt try out charging feature(bought it for slightly above 5$ with car and wall charger, without them it costs below 5:money_mouth_face:, battery tube fits my red Convoy S2+ and cheap C8 with deep reflector, came with pocket clip which scratches light easily, scratched my Convoy too, has rust to it, took it apart, surprise - LB star with probably fake XP-E, sits on a shelf.
Pictures - http://1drv.ms/1O3BVxS
Iāve been reading this forum quite a bit today and joined. Iām curious, I read that as of earlier this year the LB knock off emitter lights began to severely outnumber the amount of genuine cree (and sometimes possibly rejected cree emitters) on the $5-10 lights on Ebay / Aliexpress. Is it pretty much impossible to find actual Cree flashlights now in this price tier? So far itās been like looking for a needle in the haystack, some Ebay listings itās easy to tell, most it isnāt since the Ebay sellers use fake stock photos of the light in use. Note that Iām primarily looking at 18650 battery flashlights.
Look into buying a Convoy (S series/C8). A bit more than $10, but vastly superior in every other aspect. No worrying about fake emitters.
Yeah, was looking into that, looks decent, apparently Simon is the main dealer to go to for those? Iām pretty new to all of this besides some lurking here and there. Will have to think about that one.
I was mostly glancing at the <$5 18650 lights (I extract cells from laptops from time to time) figured it might be neat to try some out and maybe modify. I noticed people tend to change out the emitter and driver with something else and just use the shell as a host.
I just skimmed through quite a few pages of Ebay(US) listings and come up with around 30ish variants of different lights at $5ish and under shipped. I would link them all but it would be a bit too cluttered / spammy. So hereās a link to a paste of them, note that there could be a few duplicates in there.
These in particular seem to be very widespread online in different knock off brands from what Iāve noticed:
http://www.ebay.com/itm/3000LM-Vander-CREE-XPE-Zoomable-Focus-Aluminum-3-Mode-LED-Flashlight-Torch-BJ-/161914559394?hash=item25b2dc1ba2:g:NWgAAOSwNphWah4T
Also ran across a āC8ā type.
http://www.ebay.com/itm/Multi-purpose-Black-300Lm-CREE-Q5-LED-5-Mode-Bright-Flashlight-5-Output-Levels-/271860326044?hash=item3f4c235e9c:g:ZS0AAOSweW5VSCvc
I would avoid those named SkyWolfEye or Vander. Quality might be to bad to be of use. E.g. those tubular ones (āS5ā) have a loose pill, very thin tubes and poor threads. Models with side switch are often not that easy to modify. You should decide if you really want a zoomable light, it sounds promising but those cheap ones have their downsides. Even if you buy it only as a host, below 5$ itās hard to find decent quality. Those C8 with an older Cree XR-E could be worth a try. Emitter and driver swap should be easy and deliver what you want.
