Ordering a watch case back removal spanner wrench from Amazon that goes up to 60mm, 3 point, that should do the trick.
Yeah Amrytech have the best anodization that i have seen, unfortunately Barracuda V2 is maybe the most mod unfrendly flashlight in existance
The besel isnt glued, it just have kinda thicker o-ring and lotsa sillicone on the threat…just wait when you start removing the reflector …mine came glued to the mcpsb……insane eh?
The one cell option is great and it should give arround 3-5-3.8 tail amps, after dedome mod, spring and wires its as good as M2x
It could be a good flashlight if it wasnt so hard to get it open and mod cause by default its nothing special realy, yet the ano is great
Another great Armytek V2 thing is its AR glass: lovely
Mitko, is your reflector polished mirror smooth? Mine shows the machine lines from when it was cut, big time, which totally kills decent throw.
And with one cell, it simply won’t do worth a darn. In my light box it CAN show 483 lumens but it will only flash it, then immediately drop to 265. It works fine with 2 cells, gotta figure this out on the one cell thing. Something’s not right.
Also, do you see a parabolic curve to the reflector or do the walls seem cut fairly straight? It’s such a deep reflector it’s difficult to get it to show in a picture…
Hello,
i had Predator XP-L HI a few days at home. Output was terrible for max, around 600 lumens I guess. PD35 Tac flashed out Armytek although they are such a different flashlights. Sure, throw was much more spotted with Armytek, but the brightness wasnt good. Finally, Armytek stopped working, output went down to zero point and finished. Thats just a small comparison. Great potential of XL-P HI, but a lot wrong with flashlight. Big disappointment.
MOD it! :bigsmile:
Dang sure thing that’s what I’ll do if I have any more issue with it, I’ll put an FET driver in it and make it SING!
Hm, strange….mine worked fine at 3.6 with a single cell, i actual got 3 on a promo localy ( bought them for 50% of their retail price)
The reflectors came perfect, not even a single machine line or even a single dust particle: i opened it with a number 41 socket wrench which in my case fitted very nice- on 2 of them, the third had a bit smaller ring so i left if for future tunning… your post actualy surprice me greatly, well i was thinking that Armytek are hard to mod but always have great quality…it seems it aint true, or maybe you have a different revision…or i dont know what exacly
I still got one for myself( i will mod it when i have the time) and will keep it mainly for the anno and the reflector plus its lovely green AR glass
Since yours are kinda different revision lets hope the reflector isnt glued to the PCB- if i didnt saw this myself i wouldnt believe it
I just tried an amperage reading and got 2.31 at the tail with 2 cells, stuck the single cell tube on and tried again and got a whopping 6.19A!!! It stepped down to 5.33A within about 20 seconds after going completely off then blinking a couple of times.
...Thanks God. I received my Armytek. They even provide a CREE Color Chart on da banana box.
I love Canada brand !
HERE IS MY BEAUTIFUL DOBYMANN XP-L HI (LimiTeD EdiTion R)
Lovely...
I put it on the lightbox while taking a tail current reading. It only did 1090 lumens while pulling 6.33A at the tail. Messed up stuff right there, at that tail amperage it should be making 1600 lumens easy. It’s over riding that high current, stepping down quickly. If I put the tail cap on and try it, it flashes a high but immediately drops output.
Sorry, I use a good Clamp Meter with a 12 Ga Turnigy wire for a loop. It’s accurate.
Perhaps you should slow down on the coffee….
Hmm it doesnt seem right, maybe somehting is shorting the driver out
JungleCoffee sounds like someone that had a very bad time with that brand
Keep us updated pls, it seems you have a different V2
...I think, they should "slow down" on their bla-bla marketing crap.
Dale? What happen to human kind? How such a huge and ridiculous amount of merchandising bullshit can be just accepted as a standard?
Well. Let's focus on politically correct topic. Led and Flashlight...
SB4 or 5B1? Is the V6 really that better than the V5? Is this possible to fry eggs on 20x 8C3 feed on 300A?
Its Friday night and I’ve had a couple of beers and a glass of wine, but this thread has me beat! I’m not sure what’s going on anymore. Jungle coffee is not helping tbings .
I know, right? ANSI ratings and all that, ArmyTek is SUPPOSED to be a top brand. I’ve wanted a Barracuda for a long time but wouldn’t pay full price. Finally, Black Friday gave me the opportunity, and now this. The reflector is just ridiculous, never seen it’s like even in a cheap budget light. The machining lines, ugh. And now it won’t function properly on a single cell either. I don’t know if I should return it or mod it. But the big attraction is in the driver, it’s supposed constant current capability. I guess I’ll talk to the supplier and see what they have to say.
Well, I’m not really into frying eggs on a light, but some of them can de-solder connections so that’s plenty hot to do it!
I like white light, neither blue nor green nor fire orange. That’s just me. Show me that emitter and I’ll stock up on em…
OH yeah... 99% transparency, so you can spot that awesome best in the World finish
33 1⁄3 rpm microgroove vinyl record Reflector style... Throwing crap...
Oh... I guess it's some limited edition vintage stuff...
Well, i am looking at the one that left here and its reflector is good( took pics, the best i could)
It seems that either that torch has several levels of quality or just you both are quite unlucky…or maybe yours are the US edition …since you are close to Canada( its birthplace) its suppoced for you to be kinda patient for its disatvanrages…JK ofc
Sorry, but your pictures show some low quality surface finish.
As you can notice all around the net, too many people get low quality reflectors (and other issues) from Armytek.
Damn. Look at Fenix product (just 1 example)? A cheap E20 can accept within 5mn a new emitter mod, without any donuts hole and 33 vinyle's style beam.
Well, Fenix, and many others DO NOT package themselves as some HiluxWesternCountry owned manufacturers. Hope you get that point.
I have nothing against Chinese manufacturers. I do not appreciate bullshit bla-bla-figures.
It should not be more than 8% of variations on such range of product.
72,000 Candelas... Jaa ja... not even 50k... 540m OMG! Revolution in AT 40mm head manufacturing process lol 400m with good lens. Thanks
Enough of such bullshit marketing/packaging.
Of course, some may not be agree with my point of view about business... They may prefer bring some, ortografk issue...
I just measured it:dual cells, 92 000 cds( dedoming doubles those)
Yeah i took that photoes with my S6, its a phone not a camera so they aint good
Olight Triton got like 90 000 as log as i can remember
For me its main issues is removing the reflector, why the hell it was glued to the mcpcb? helping the cooling prolly?
About your V2s…well, it seems they have issues, maybe a bad batch - if i were you i would return those, especialy if the reflector is that bad
Well I’m glad you guys got armytek out of my system.
Have you thought of PMing them and asking them to comment on this thread?
