Fenix will not sell spare parts without a valid serial number. Standard, as nobody will not take care of themselves first.
BTW, that looks like 20mm star right? Where can i get T6 or T5 NW LEDs? (3, 4 or 5xx tints are ok)
I only know illumination supply. KD has a WW 20mm star though for 10 bucks.
WTF - it costs $23 bucks shipped!
It's time for Ric to show up with an offer! It took sweet time to finally get a tk35 clone.
Ric seems to have some: http://www.cnqualitygoods.com/goods.php?id=1302
Just add one to your next order from CNQG :bigsmile:
Ok purchased NW 3C star. This light is worth it.
24L,65L, 240L, 540L so max in turbo mode only 540L?? far from stated on the spec??
what comes in the box? holster? landyard??
Kd have one too
42,47 usd
Link: http://www.kaidomain.com/product/details.S020017
You believe the spec of 130k cd from Fenix on the TK70 bro? You can check out the table i posted above. BTW, my figures are OTF.
Anyway, i guess it's not a spec per se, it's just straight from Fenix. Like if you buy a copy watch, would you believe the spec? (it's a bit different for flashlights, but the concept is there).
Cheaper by $2.50! KD could be fast could be slow....something like DX. But well if you are not in a hurry to play....it's alright.
Edit - actually cheaper by about 5.50 bucks because KD includes registered air mail for orders over what...25?
So basically this item doesn’t have the fenix output. I am expecting like 800lumens
I think if you change the driver, it can compete with tk35 one on one …
Yep, another "unfortunate" point for some i guess. There are few lights (same emitter/40mm reflector form factor) which i know of gets you over 800L OTF though. Not even the U80/980L. I don't have the TK35, so i can't give you relative readings. The 980L with 3.8A at the tail (maybe slightly lower with the switch) gives me about 66-67 lux reflected ceiling bounce and dives below 60 after 1 minute. This one is about 54-55 and holds there for a crazy 9 mins (and is able to sustain max output mode for over 1 hr - note i have done this 3X already once in 30 deg C heat not unlike your location in Padang/Indonesia and twice in 23 deg air-con environment). The T40CS gives me 79 lux. Even the FF STL-V2 gives me 72.
RRT-2 XM-L is 39.8L / rated 468 OTF (ANSI), it is 45 lux on my meter. TK70 is 218-220 reflected, rated 2200 OTF (ANSI).
Just some info from my experience. I don't 100% do manufacturer specs, but i do use it as an avenue for information....nothing more/nothing less.
Come with a holster???
Yeah, comes with an Ultrafire holster. Quite nice...somewhat hard cover for the flap. Don't think KD gives you one.
Also note that Ric usually stands by his pdts. He will not answer funny questions like if the lens is AR coated, if the coating is HA, what's the runtime, if this TK35 comes with a holster and stuff like that. Even if i ask him that he will not answer (you think that i get Super VIP preferential treatment, nope...think again).
But if your bezel is nicked, driver is faulty, lens is cracked, battery carrier is chipped, bezel is scratched replacement is instantly sent, no questions asked. (And these are true stories). Try getting a replacement driver, spare black silicone cap, replacement bezel coz it was scratched from other vendors.
Even for Manafont i had quite a bit of difficulty! It's not their fault though, i understand. (but it's also not mine man!)
Here in padang is hotter…
54lux… Is it the same as ultrafire C8?
I am very tempting with this clone, but my concern now is only the output…
BTW, the hidden SOS/Strobe modes, you need to double click on the mode button. And the Strobe is also Fenix style, ie alternating 10Hz and 20Hz. Same as my TK70.
My wife's with me in SG, but her hometown is on Pulau Tebbingtingi in Riau (3hrs speedboat from Pekanbaru and 4hrs from Batam or 2.5hrs from Tg Balai Karimun). I also try to visit Batam whenever possible. Yeah i guess coz SG is surrounded by sea and also quite a fair bit of greenery here giving cover. But from what i see on weather underground we are about the same in temp. We are close enough to be affected by the same weather system, these few days rain like crazy/heavily right?
My U80 is about 65 lux. I guess C8 is approx the same. Seriously i don't see no diff between the TK35 clone and UF-980L unless you side-by-side compare at a 20m distant object. In the room, your pupils close up if you stare at the hotspot, that 20% is not appreciable. You can register a bit of difference when tailstanding, coz the levels are lower. You the something like the DRY/TK70 or something that is > 2X in lux (eg FF STL-V2) to bulldoze through and make your brain register holy !@#%!@# yep that's bright alright.
BTW, the Shadow TC6 4C neutral white (I have the 2.5A version) gets me 57 lux reflected.
Here for less than 30$ http://www.powerwholesale.net/fenix-tk35-t6-flashlight-p-1584.html
Poor thing I do not like multicell lights
And yep, they are selling the real TK35 for 86 bucks. :)
Shipping will cost dearly. Let see...i have sent over an order for HK Post.
