Looking for 1 x 26650 host flashlight EDIT: host for 3 x AA battery carrier
13 posts / 0 new
Ouchyfoot
Ouchyfoot's picture
Last seen: 10 months 3 weeks ago
I'm looking for a good host (1 x26650). I want to put a 3 x AA battery carrier in it. Something solid with good heat displacement (integral pill would be nice). Enough room in the pill to play around with various drivers.
Once I find the host, im hoping the mod will appear in a dream.
Edit: I was just informed that 3xAA battery carrier is too large for a standard 26650 torch. I just assumed, and should have checked first. Any ideas?
Edited by: Ouchyfoot on 12/17/2015 - 05:35
pinkpanda3310
pinkpanda3310's picture
Last seen: 2 days 21 hours ago
Throw or flood ?
bugsy
Last seen: 5 years 5 months ago
Have you considered the big kahuna?
thijsco19
Last seen: 3 weeks 5 days ago
Convoy X3?
vex_zg
Last seen: 3 years 6 months ago
i think you need 32650 host, 3xAA are larger in diameter than 26mm.
Lumintop sd10 for example.
Ouchyfoot
Ouchyfoot's picture
I just checked, and your right. I think there are some lights out there that offer 26650/AAA interchangeability, that’s why I assumed they’d fit.
I have some nice 3S AA battery carriers that I figured would give me more driver/emitter options when loaded with 14500s. Now I need to rethink things.
Ouchyfoot
Ouchyfoot's picture
pinkpanda3310 wrote:
Throw or flood ?
Once I find a host for the carrier, I’ll decide. (3S 14500) single, triple, flood, throw. The mod depends on the host.
Werner
Werner's picture
Last seen: 2 years 3 months ago
There was once a “saik” which had a 3xAA carrier….long ago
Ouchyfoot
Ouchyfoot's picture
I saw that one. It’s not available any more.
pinkpanda3310
12v emitter I take it?
3Tronics
3Tronics's picture
Last seen: 11 months 1 week ago
Convoy X3
26650, and also will fit x3 AA/14500 with the battery carrier
Custom builds | Modifications | Powder Coating
Gallery: Instagram
DBSAR
DBSAR's picture
Last seen: 2 days 40 min ago
Most lights that can use D-batteries or a 32650 will be large enough to mod to a 3-AA carrier. SD10, Mag-D, Defiant-D, etc.) 3-AAA carriers diameter fit the 26650 lights.
Ronin42
Ronin42's picture
Last seen: 2 years 2 months ago
Not true.
I bought a SAIK SA-305 on ebay.
Built it up with an XHP70 and 3s 14500“s DD
FACT (6V emitter, 12v carrier) and it works (the carrier is the weak link). The voltage drop from the XHP70 probably pulls it down far enough. They are tough emitters and are hard to kill one with 14500 cells. Will be more cautions when I get good cells is it.
It goes pretty good. I am waiting on good cells before I push it.
I need a “good” 3s 14500 carrier so if you have extras let me know!!!
OL’s first build was the SAIK SA-305.
The two weak points that need to be addressed are the hollow pill and the plastic lens, but other then that, it is a solid build and nice form factor light. It would make a great custom in series triple.
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
