Just glancing over it quick, I think you forgot to define “RED_PIN”.
Add:
I presume the “RED_PIN” came from Ferrero_Rocher.c? I’d suggest substituting “FET_PIN” instead just keep things clearer.
Add:
Ahhhh yes sorry, I’ve made that change but it needs some cleaning up which I will try to do tonight. Was a fix bodge during work.
I’ve made a few tweaks should be OK now if you want to give it a go.
I probably won’t be able to get to it till thursday evening. Thanks for working on it!
Hi PD68 - I rcv'd the 1.1z's. Not sure if I'm missing something, but on the 1.1 versions, if you want to separate the 7135 outputs from the FET, I thought you'd cut the trace at the white line, but I can't figure out how that would work, because the thru holes for the 7135 outputs go direct into the FET output pad.
Am I missing something, or was that the design intent?
That was the intent. Cutting at the line on the top separates the single 7135 from the rest. The six 7135’s on the bottom are still on the same output as the FET.
It was done this way so that it would also work with the Attiny13a as it only has two PWM outputs. You can leave the trace not-cut and you will have PWM on the single 7135, separate PWM on the six 7135’s on the bottom, and full on on the FET all to the same LED. If you do cut the trace, you get PWM on the single 7135 going to a secondary LED (like a red xp-e2), plus PWM on the six 7135’s and Full on on the FET going to the primary LED.
Ok - silly me... I totally missed the top mounted 7135 footprint there .
oh, yeah maybe I should start putting the little white outlines around it like other people do. Obviously the “cut trace” is under that 7135, so you’ll have to cut before reflowing that part. (and don’t forget to cut the center 7135 Pin)
I'm totally out of FET's, wait'n on a MtnE order to arrive, so can't reflow boards til maybe tomorrow anyways. Should have throw in a few on my Mouser order cause those are in. Think Richard got overwhelmed over the holidays for sure.
Pyro I was building one of these boards and sadly the code you posted gives a bunch of compile errors. Most of it was stuff a little over my head. The base firmware looks very different from what I remember seeing before. Is it 13a based, or is it for one of the bigger MCU’s?
You can see I have the mcu partially shifted off its pads. This was necessary in order to be able to flash on-board.
I’ll have another look at it tonight but no promises as firmware isn’t really my thing.
Wondering bout one thing I'm seeing on these new board designs - the missing grnd pad under the 7135's, and for the center pin. The extra connections are not needed for electrical contact because as long as you have some connection to grnd, its ok, but thinking more of a heat path. The 7135's do throw off some amount of heat. I think O-L sort of proved you need a good heat path. I believe he found performance issues with stacked 7135's as opposed to mounting them on a separate board properly heat sync'd.
Wondering if this was given any thought? Maybe this is ok considering we are not stacking?
For the firmware - not sure bout the firmware changes - what is wanted, what to be used as a baseline.
I just received my rev2z boards. I won’t be able to get to rhem for a while but I will be watching this thread closely so that I might be able to get a working firmware to power one xpl hi on one channel and two Nichia 219 on the other. I will need another board to add some extra 7135s to the lone 7135 on top. We will see?
Thanks for making these boards by the way!
Unfortunately, most of these designs require traces to run under the 7135’s in order to make everything fit, not allowing room for a big ground pad.
I will be making one change to the board as soon as I can. The ground tab for the 7135’s on the back is essentially part of the ground ring, and when reflowing it tends to “suck” the 7135 all the way out to the edge. I’m going to get rid of the traditional ground ‘ring’ and just add exposed parts of the ring in between the 7135’s
For the firmware, I use BLF-A6 as a starting point for almost everything, so that’s what I would prefer it to be based on. It’s what I’m most familiar with. Essentially we would just need TK’s “TURBO” shortcut to turn Pin3 on instead of just go to ‘255’ on Pin6, and of course make sure the turbo timer still functions. I believe that’s exactly what pyro attempted to do, but I got a lot of compile errors, and the base FW looks weird to me, like it was an Attiny25 version or something. (I’m still stuck on 13a’s). The compile errors looked to be coming from parts of the FW that pyro hadn’t touched.
Ohh yes, I've seen that happen as well - the 7135's getting sucked outward.
Ok on the firmware - I got the boards and all the parts now, and have worked with BLF-A6 before. Just dunno when I can get to it unfortunately - still not over this being sick thing (over 3 weeks now). Yep, I'm not doing much on 13A's now though but still need to support them. I think the base BLF-A6 firmware is super tight in code space, so might not be do-able without losing something.
If something has to be lost, you could probably ditch one of the strobes, those are probably the least-used modes in blf-a6. Personally, I disable all of the hidden modes whenever I use it. I just like it for the easy control of the PWM channels, the two mode groups, and the memory toggle. I don’t really like overly complicated things for clicky lights. Even the multiple mode groups I usually just use to essentially toggle ‘moon’ on/off. I’m going to order some 45’s to use in my dual-switch lights though.
Sweet, hopefully I’ll have time to give it a shot tonight
That’s for ATtiny13A, right? I thought three outputs wouldn’t work on the t13, or one wouldn’t be able to reflash without a high voltage programming device, wasn’t there something like that?
What we have done is re-purpose pin3 that was originally used for config stars.
Now its just on or off which controls on or off for the FET for TURBO
