on the datasheet it says the max rated is 1200ma (if I’m reading that right) but only offers configuration directions for 1000ma. I might see what a 1k resistor does…
I’m not making a new PCB (though I might in the future) but im currently piecing together a little charger that uses 2 of these boards in parallel. My hope is to have one at 800ma and one at 1200ma. I’ll have a switch to toggle if I’m just using one board or both. 800ma for 14500’s and 18350’s, 2amps for 18650’s.
Hm, almost no one connects NTC to these TP4056 boards (NTC placed in/on cells itself) to get thermal protection for free.
TP4056 datasheet:
“TEMP (Pin 1) :Temperature Sense Input Connecting TEMP pin to NTC thermistor’s output in
Lithium ion battery pack. If TEMP pin’s voltage is below 45% or above 80% of supply voltage VIN
for more than 0.15S, this means that battery’s temperature is too high or too low, charging is
suspended. The temperature sense function can be disabled by grounding the TEMP pin. ”
Is that in-parallel dual engined charger working nicely?
I’ve sometimes wondered if these boards could be used in parallel without the risk of one of them banging some @#$% volts on the other… :DRUNK:
According to reviews, around 850mA of charging current were delivered with 1’2K resistors.
I bet you’ll (probably) get slightly above 1A with a 1K one.
Boards are @#$% cheap, I’m waiting for two of them (with protection) with have costed me $1’17, and I’ve seen even cheaper… O:-)
Slam a BIG heatsink over the chip, use a 500Ω resistor and… please report!
Yes, this works fine. They most probably won’t terminate at the same time because of tolerances, but this is not a problem. Charging is finished when both boards report “finished”.
I've recently retrofitted a homemade powerbank I had done with a board from FastTech (SC-0176B), which uses a TP4056 as charging engine:
The thing now has an additional charging board, and it works neatly. However, it is for a friend and his phone PSU only supplies 1'2A at most, whereas this now pulls 1'7+A.
Has anyone tried to connect these boards to weak supplies? I presume he wouldn't want to see magical smoke coming out of his cellular charger… LOL!
im not sure tbh
what i do know is mine (the tp4056 chip) are getting really hot while charging, you cant tuch it for more then 1 sec,
the chip itself is a mosfet with some other hard coded functions in to it,
i dont know but i think that a cheap mosfet would overhit more then a good mosfet.
other then that, yea they working good, how good? no ones know lol
im useing few of them on few differetn applications, few for 18650 chargers, one for my 10440 charger, one build in to my headlamp wich have 2 X 18650 inside.
so far they work well, i have a small heatsink on top of the tp4056 chip but it still get very hot,
the thing that worries me the most is if it will fail some day and will overcharge the batterys and then fire! lol
oh and BTW, all of my boards are showing about 4.5V output , no load… but still while charging they all cuting off at about 4.18V so im not sure how good this test is, i bet the chip need to have some resistance in order to activate its volt limit function
That is weird. I said what I said because in a cheap flashlight with USB micro-B charging (gotten via GearBest, though) I once noticed a no-load maximum charging voltage of ≈4.46V, and got a full refund. Of course I already knew the no-load maximum voltage on these TP4057 charging powered torches was ≈4.2V. Got a few TP4057 chips and repaired the thing at a later date. Seems the quality control on these is iffy.
Are these little TP4506 circuits still the most compact design for usb charging a decade onwards? I’m looking to add usb C charging to a light and reckon I could just take one of these boards and wire a USB C port to it Looking at these with 6 pin connectors
