You can get better diodes for D1 than what I listed in the BOM. Somewhere on this forum I think I posted guidelines for selecting the best diodes. I apologize, but I don’t currently remember exactly what specs to look for - I’ve had a long hiatus and that knowledge is out the window for now. I suppose you need voltage tolerance of around 2x your supply voltage and you need the lowest possible Vf for the diode, plus at least a few mA of current handling. Say 20mA+? If you really want to get into that stuff someone else will chime in for now.
Note that the 22k resistors I recommended in those BOMs may not be the greatest idea in the world. Toykeeper shared some test results in post #552 demonstrating that the 19.1k resistors were much better. RMM confirmed in post #564 that for 1s use especially it’s really important to use 19.1k rather than 22k. Either way the firmware should be properly tuned to get good LVC. ToyKeeper provides a test firmware for doing the calibration. If you keep reading a few more posts from the ones I’ve just mentioned, TK will bring up calibration procedures herself.
As far as board versions… v024 works for your application. You may also want to look at v044 - I don’t think I’ve built that version myself but it sounds like others have built enough of them.
With the 7135’s, you could stack to control what was fed to the LED, be it a pocket rocket, or an EDC.
Am I reading right, that this driver does not have the capability to control the input?
I use this exactly this for D1.
If you can not buy from this source search for “RoHm 0.5A/20V Schottky SOD-323, RB551V-30 TE17” on eBay or Aliexpress.
For C1 I use a 10uF cap size 0805.
I would recommend to first try to build a single cell verson of this driver and than modify another for two cells. Firmware can be a little tricky for two cell drivers.
I have some SD103AWS SOD-323 diodes from another project but i’m going to order these you mentioned .
Just ordered also all the other components including pcb …
Correct. It is for maximum output that is only limited by battery selection and quality of components. If you do not have at least one light with one of these you should try it. The biggest drawback is as the cell fades so does the output whereas the 7135 drivers did not do that until they fell below voltage. Both drivers have their place but for sheer max lumens the new DD drivers cannot be beat
Well, this is good timing. I took a little time off to pursue other things, and not only is there a plethora of new hardware and firmware out there (the 1K limit has finally been breached!), but Wight is back. Welcome back, and THANK YOU for putting us down a fresh path in driver land.
All is right with the world.
PS Ordering Attiny 25s and 85s and can’t wait to see what I can cram in them.
I have another silly question….
Is there any ready-to-flash firmware available in this forum after i build this driver (for attiny13a) ? in about 2 weeks i’ll have all the components needed , so it’s time to search for a good firmware.
For an FET only driver I would start with STAR firmware or one of ToyKeeper's firmwares. You can find them all in ToyKeeper's Repository under JonnyC and ToyKeeper. For ToyKeeper I would start with starry-offtime and with STAR I would start with STAR_off_time. ToyKeeper's BLF A6 is also an excellent firmware, but it is geared towards FET+7135, and while you can convert it to use with FET only I would try some of the others first.
I need your help 0:)
Can i do a zener mod on the driver , so i can use it with mt-g2 ?
can someone describe what diode to take , and if i need to remove something else ?
i have pcbs v044
The second part is picking R1/R2 resistors for a usable voltage divider. Tom E or someone might chime in here with good info for you. The values Matthaus linked to above are not correct for this. Maybe 19.1k and 2.2k with a re-calibration?
Again: recalibrate the LVC I think. ToyKeeper provides a test firmware for doing just that!
FWIW, RMM posted a spreadsheet you can use to experiment with resistor values, with an approximation of how those should appear to the MCU:
So, for example, if you wanted a 3S light… tell it to estimate the values for 3*2.5V and 3*4.4V (7.5V and 13.2V) and adjust the resistors until they produce useful values. You probably want the results to be between 32 at 224, spread across a fairly wide range.
I don’t really know what I’m doing, but I gave it 48000 and 3300 and it produced 3S values from 111 to 196.
