Somebody design a driver that pushes amps no matter what the forward voltage. Threshold voltage? Pfffff! I’m a driver not a designer! Direct drive? Do you think I’m building it?
Laugh all you want, most of what we do is science fiction from a very short time ago. I hope it keeps happening
I hear you about the burn in. That is something we used to do with SST-90 emitters and it actually worked. I have attempted it with XML2s and it has no effect.
What RMM was saying about the spark gap thing is just because the new (U4 bin XML2s can only handle about 4.5A. Once it a while you will get all the way to 5, but I've not had any live beyond that.
RMM,
What is the typical VF your getting with XML2s ( for example at 4 amp)? What change do you typically get after a de-dome?
Same question about XP-L and XPL-HI in top bins if you have tested any of these?
Thanks also to everyone else who has commented. Your input is valuable to me.
At least with my basic understanding of electronics, that constitutes a boost driver, and some sort of feedback to measure the Vf. Not exactly the easiest thing to get to work, much less at high currents.
Not off topic at all. Just now I did a test of the output as well. Last year I performed a series of controlled tests in order to calibrate my sphere and to determine the usefulness of the XHP-35. I happened to have a control test of one of RMMs original U4s which I had reflowed to a 1"x10" copper rod.
Lights used for calibration 8/10/15
Measured FC
multiplier from FC
Shorty mag as tested by Ti-force 875 lumen
2710
0.322
4sevens X10 640 lumen
2000
0.32
4sevens Quark AA2 280 lumen
914
0.306
Test #2 Shorty mag 875 lumen
2710
0.322
Multiplier used for testing below .32
All emitters were reflowed to copper MCPCB and to solid round stock.
Cree XM-L2 U4
Measured Lumens
Cree Chart
1000ma
432
459
1500ma
620
629
2000ma
793
824
2500ma
900
3000ma
1100
1122
3500ma
1238
4000ma
1369
4500ma
1478
Just now I re-calibrated my sphere to be sure, which as it turns out was within .0011 of where it was at before.
Cree XML2 U4 in question for VF and output 1/27/16
reflowed to copper rod as before
Calibration. Shorty mag .347 47s X10 .324 Quark AA2 .311 Average .327, multiplier used .33
1000ma
415
3.2v
2000ma
739
3.6v
3000ma
1032
3.9v
4000ma
1267
4.1v
Its impossible to tell for sure since I had only one test of the previous emiter, but it appears that the ones I have now track almost exactly one bin lower.
At this point I think more info is still needed to be sure this is the problem though since even emitters in the same bin can gap about that. RMM is going to send me some results from his testing later.
Well thats strange, so far i have never ever met a single xml2 emitter that aint capable of running at least 4.5 amps easy,those u3 0d that i do love so much lately are running at 4.7-5amps on a fresh HE2 battery yet they are as good as U4 1C considering the lumen output, but the tint when dedomed is good
The best of those that i have found so far are both KD ans IOS V6 1A: easy hitting 6amps with a good 26650, a localy picked V6 2c-2d( same as above, IOS one aint that good ) , ofc V6 0D from IOS( they all hit 5.5amps, i bought 20 of those) and FT V6 0D-yet the tint here aint that good, prolly nto a true 0D but kinda 0C more or less
The one thing that is strange to me about V6 bins in thay they dont dedome that easy as the old ones
My bench power supply. I just took a short piece of heavy lamp cord (about 2ft) and wired it to the supply.
Is this the right way?
Beyond this I have been coming up short on current/lumens else where with these.
One example is an 18650 pocket light. Original tested at 1080 lumen @ 1 min. With this latest batch of emitters I was only able to get a very best of 960. And the 960 was after I over sized the wire, copper braided the tail spring, and progolded the clickie switch. All 3 of which I did not have to to in the roll out.
I do my testing with a similar branded bench supply. I dont use the readouts on the power supply itself but measre at the led as there is a slight difference between readings. The readings on my power supply are as accurate as my DMM's.
On a de-domed U4 1C in my modded Convoy L2, I measured 5.47A at the tail using my new clamp meter on a Basen 26650 4500 cell @4.22v, and DD FET driver.
On a modded BLF Lucky Sun D80 on a 30Q @4.21v: 5.15A tail (DMM), 5.36A tail (clamp), lumens: 1812 @start, 1744 @30 secs, 52.5 kcd (taken at 5m)
Don't have the exact #'s but on a XM-L2 T6 4C FET+1 driver Warsun X60 mod, I measured bout 6.5A tail on a DMM, and over 7A at the tail on a clamp meter. This is with an EFEST 4200 26650 or the new Basen 4500 26650, both at about 4.21v or 4.22v..
You should be getting between 5.0A and 5.5A on a U4 1C with a decent DD FET driver using a clamp meter (the UT-210E). As shown above, a clamp meter will always get a higher reading on a DD driver. On the high Vf U3's, I get in the range of 4.0A to 4.3A with a similar setup.
Your amps measured are consistently lower, so I'd suspect either the measuring method or higher resistances in the circuit (driver, host, wires, possibly MCPCB/LED, etc.).
Just now I did as you suggested and measured the VF with my DMM using the same test emitter as before. I got 3.99 @ 4 amps. The PS reads 4.1v so I am getting a slight variance there.
TomE,
Thanks for chiming in.
Where you said
"You should be getting between 5.0A and 5.5A on a U4 1C with a decent DD FET driver using a clamp meter (the UT-210E). As shown above, a clamp meter will always get a higher reading on a DD driver. On the high Vf U3's, I get in the range of 4.0A to 4.3A with a similar setup."
That is fairly close to what I was getting wtih the U4s until recently. I dont have a clamp meter but I use heavy custom leads for my DMM. On a 26650 light I was averaging 4.4-4.8A on 26650 lights and just a little under that with18650 lights. These new ones wont squeak out anything above 3.8.
Yea, not sure, we could be splitting hairs. My heavy gauge DMM leads soldered direct into the banana plugs does fade over time. I found treating the banana plugs w/NO-OX-ID gave me a bump, refreshing the solder tips of the heavy gauge wires also gave me a bump, then NO-OX-ID on those solder blobs helps more.
I havent' seen a dramatic drop in U4 1C's, but can't be sure when the U4 1C's were bought, or what batch - got some from MtnE and maybe IOS, both fairly recent though. The U4 1A's from Cutter I believe perform in the same range - only tried one and blew it out in the BOSS1, but probably went over 5.5A.
I'm just glad others are chiming in. Especially since you also have very similar results with the U3 bin and the higher VF. The more and more tests I do, and the more information I get here the more I suspect that I was shipped U3s by mistake.
I think if RMM gets results from his stock that reflect my original test results I will just end up order new emitters from him.
Think'n that could be correct - performs like U3's...
I've only found out very recent how low the U3's are compared to the U4's - had no idea. Really very disappointing for me because I just bought recently qty 10 of U3 3D's from IOS, and still have a bunch of U2 3D's thinking the U3's would be better. Like the tint but but being 1.0 to 1.2A lower than U4's is an additional penalty for that tint.
Barring the evidence we apparently have, why and how could there be such a significant difference in the U3’s? After all, isn’t the U3 just a bin they assign after manufacturing? Were the U3’s all from a single batch that somehow got messed up with a higher Vf and Cree just deemed them good enough for rated spec?
Yes - I'm finding the U4's brighter than V6 XP-L's. Umm - diff in U3's? Well, newer T5's, U2's etc. are also low amps and high Vf like the U3's. U4's on the other hand seem to be different.
The bin assignment was theoretically that: pull the LED's off the line, test them, throw them into the appropriate output bin. But, we don't really see this - within a given time period, what we are allowed to buy, released to our somewhat gray market, is very specific tints in very specific bins. A bin though is a wide range, so maybe the CREE manufacturing process is so precise now, you don't get diverse bins spreads.
