Test/Review of Efest IMR18650 2600mAh (Purple) 2016
6 posts / 0 new
HKJ
HKJ's picture
Last seen: 5 hours 11 min ago
DSC_3134
Official specifications:
  • Rated capacity: 2600mAh
  • Nominal voltage: 3.6V
  • Voltage at end of discharging: 2.0V
  • Max. charging current: 4A
  • Standard charging current: 2A
  • Max. continuous discharge current: 30A
  • Pulse discharge current: 40A-60A
  • Charging temperature range: 0°C ~ 45°C
  • Discharging temperature range: -20°C ~ 75°C
  • Internal resistance: 8mOhm
  • Cell size: 18.30mm x 65.80mm
Efest%20IMR18650%202600mAh%20(Purple)%202016-info
DSC_3133
DSC_3135 DSC_3136
DSC_3137
DSC_3138
Efest%20IMR18650%202600mAh%20(Purple)%202016-Capacity
Very nice curve, the batteries match perfectly and the capacity is fairly stable up to 20A.
These curves are made with my new 4 terminal rig, this means the voltage at high current discharge will be higher than in the old test. I do also expect better matching between curves at high current (With good cells), because connection resistance is not included anymore.
Efest%20IMR18650%202600mAh%20(Purple)%202016-Temp-15.0
How hot do the cells get during discharge? I have added a termo sensor to my test stations and will show temperature traces for high current discharges.
They will only show the temperature raise, not the absolute temperature, the actual cell temperature is 25° to 30°C higher. If the cell gets too hot I will stop the discharge to avoid melting my battery holder.
The temperature sensor will always be a bit behind the real battery temperature.
Efest%20IMR18650%202600mAh%20(Purple)%202016-Temp-20.0
Efest%20IMR18650%202600mAh%20(Purple)%202016-Temp-30.0
Here the cell gets to hot a few seconds before it is empty and I terminate the test (It is automatic).
Efest%20IMR18650%202600mAh%20(Purple)%202016-CapacityTimeHours
Efest%20IMR18650%202600mAh%20(Purple)%202016-Energy
Efest%20IMR18650%202600mAh%20(Purple)%202016-PowerLoadTime
Efest%20IMR18650%202600mAh%20(Purple)%202016-TripCurrent
Efest%20IMR18650%202600mAh%20(Purple)%202016-Charge
Conclusion
The battery has very good performance, but it gets very hot at 30A.
Notes and links
The batteries was supplied by Efest for a review.
Improvements to test stations
Compare to 18650 and other batteries
light-wolff
Last seen: 3 days 13 hours ago
Great to see you upgraded to a 4-terminal rig – it was about time Smile
Makes your results even more valuable, stable, reliable, comparable.
And even better: you added temperature measurement. Wow.
Do you plan to compensate for contact resistance in old data from the 2-terminal rig so that it’s better comparable in the comparator? I see it’s not so easy because you’d have to assume some resistance, e.g. 10mOhm, and apply this to all measurements, at least to the discharge curves for the comparator.
As for the tested batteries: they look excellent, unprecedented matching (good part of this attributed to the new rig).
cabfrank
I wonder what these are, underneath the purple wrap. Thanks, as always, for the review.
chouster
Last seen: 10 months 1 week ago
VTC5? Quite sure…
HKJ
HKJ's picture
light-wolff wrote:
Do you plan to compensate for contact resistance in old data from the 2-terminal rig so that it's better comparable in the comparator? I see it's not so easy because you'd have to assume some resistance, e.g. 10mOhm, and apply this to all measurements, at least to the discharge curves for the comparator.
No, I do not like faking data. Instead I mark the new tests with *
But do not expect everything I publish from now is with the new rig, I have many tests from the old rigs that is not published yet.
CrashOne
Last seen: 4 hours 42 min ago
chouster wrote:
VTC5? Quite sure...
I also think they're VTC5, see http://lygte-info.dk/review/batteries2012/Common18650comparator.php
