Jeansy, the Balder BD-4 is confirmed a shelf queen. It is the best looking of the lot, and the most solid of the lot i think. 420g of aluminum! Crelant 7G5 is 390g. When you hold it, there is no mistaking it for the STL-V6.
Jeansy, you made a good decision. This light not only has greater built quality in every aspect, that the STL clones. It has also much deeper reflector and it's driven harder. It also lets you to use 2x18500 in short version.
amraspalantir, you are OK to use 2x18500 imr. They won't fry the light, since it has step down converter. Just be careful about over-discharge of the cells, because this light probably hasn't any over-discharge protection and I presume your 18500 imrs are not protected.
Oh... and while talking about robust construction, I think Catapult is more heavy duty than BD-4. It's heavier and made from alloy, that is ~60% stronger.
I know they're based on M31/M3X ...But they're so heavy inspired, even in internal design, that for me, they are clones. Good ones, but clones. Pity, that they couldn't clone non-PWM circuit.
Although, I didn't know about extension and ability to run on 18500. If not that horrible PWM, I'd probably buy one :)
From the guys who have ordered, does intl-outdoors send a shipping notification…?
EDIT: So i received my shipping notification just now, although it says status as “Delivered” and not shipped
I think it's quite reasonable price, taking into account competition prices, overall output and throw :)
And yesterday, I made runtime test with 2x17500 AW cells, that I use in my Fenix TA30. The cells are 2 years old (maybe little more) and are rated 1100mAh. The runtime on high was 00h:31m.
The current draw is very high, so voltage sag is also high. The protection circuit kicks in, when there's still some juice left. I put these depleted cells in TA30 and it ran additional 10 minutes on high. So in short version, a good pair of 18500 would rock .
The Catapult V3 is listed as 390g and BD-4 is 410g so that's a hair heavier. But that's 7075 goodness (I read that there are even some variations in this alloy) so yeah that's also a toughie. But i guess in reality they are all very close and there are more impt things to consider. :)
The STL-V2 can run with the Dereelight DBS/CL1H bodies, and my Ultrafire U80. So you can even use 2 x 18350. The BIO/powerwholesale IMRs are good. So it would be a X9 kinda length thrower.
Aluminium alloys are in Metals >Non-ferrous Metal section. According to maunfacturers, a good quality brands use "6061 T6" or "7075 T5" alloys. DX stuff is probably random... The cheapest stuff from DX use probably the cheapest alloys available (certainly not 6061 T6). I once hit the metal pipe with X2000 flashlight. The battery tube broke apart where the thread ends... And it wasn't even hard hit.
You break my heart coolperl, should have ordered the Catapult V3 to be part of the collection instead of the Balder BD-4. I probably browsed/cursorily came across through the info, but did not think about this in detail.
