PD, can you run the 26700’s in this? I can run the Imren 26700’s in the Jax X6 and L2 with the new 2x26650 tube with out those copper washer’s. They pull .8 of an amp more then the Efest 3500 and 4200 in the L2 XHP50 4300k for 8amps, according to the Fluke 36. Get rid of the inner lead holes, around the mcpcb and have a full shelf. It would be nice to know if the reflector is the same size as the Jax X6, I have a couple extra mint smooth reflector’s. Thanks PD!
The internal shelf is right where the head starts to narrow down to meet the section that holds the button. There are 1 or 2 deep fins there, the deepest fins on the light.
Thanks. I don’t have anything on my radar at the moment, so I think I will get into that group buy if it happens. I haven’t gotten involved in one of those in a few years.
I don’t have the Javelot, but my understanding is that they are totally different lights. The Javelot is more of a dedicated thrower, whereas the S70 is more of a mid-range light with a wide beam profile. I believe the S70 is much bigger than the Javelot as well.
Does this light require button or flat top cells (or either) ?
Also as I will have to buy new cells for this light as I presently don”t own any 26650”s any recommendations on good cells.
Thanks for that pd.
Any recommendations on a cell.
If the Cometa group buy I am in also takes button tops then I will need to buy 4.
As both lights have low voltage warning & cut out features I imagine I don”t need protected cells.
Thanks for the info pd, they will be my first 26650”s also as at present I just have lots of 18650”s but would like to run the S70 & Cometa on 26650”s for the extra capacity (run time).
Unfortunately I am in the UK & think postage will probably kill the deal although I will have a look.
From what I can see good quality 26650”s are quite dear in the UK, probably the equivalent of around 14-18 dollars a cell !
EDIT:
Just checked shipping & the cheapest is over $50 dollars so it is a no go.
