It works.
I modified the code and it works. The driver ramps down the light level without blinking.
Thanks a lot.
It works.
Thanks a lot.
Thanks for this post! I wanted to do the same kind of post, but my code (created by using Tido's as a reference) is much simpler and doesn't have the best EEPROM wear leveling (as Tido's seemed to write the same byte on each turn-on anyways, IIRC, unless I read the code wrong). However, looking at yours, I do see you doing true wear leveling, and it is quite ingenious! (well, it took me a while to realize how you did it - had to freshen up on my bitwise understanding)
The best I could come up with was changing a byte from 0 to 1 when doing the short presses while working through the bytes (one-click: 10000, two: 11000, three: 111000, etc.), and then clearing them all back to 0 when the current mode is saved. Not exactly the best, but better than wearing out the same byte on every short press. Yours is much better though, and using the 0x80 bit as the short-press indicator is pretty awesome - one of those "why didn't I think of that?!" moments. I'll have to find a way to incorporate your logic into my UI setups.
Yes, my driver on average does one erase/write cycle per cell and click. Wear levelling is only done on cells that may see more than one write when the light is on (click type detection and mode change sequences in newer versions). I tried using wear levelling the way DrJones does it, but it turned out to eat too much EEPROM and program flash space if I wanted to fit all the functionality I have now into the BLF-VLD. It is the same thing with cramming independent state information into one byte using bit operations. Sure, you have one less variable sitting in the EEPROM, but you pay for it in program flash because you need more instructions to access and store the information.
Anyway, the ATtiny's EEPROM is rated for a guaranteed durability of 100000 erase/write cycles. Even at a hundred clicks per day, it would last almost three years. And this is only the guaranteed minimum, the real durability is probably five to ten times that.
BTW, writing a zero to a cell is not just erasing it, it is a full erase/write cycle. If you just want to erase it, you can set EEPM1=0 and EEPM0=1 in EECR, but the erased cell will then read 0xff. To only write without erasing, you set EEPM1=1 and EEPM0=0. You can write multiple times to a cell without erasing it first, but you can only write zeroes (e.g. you can overwrite 0xff with 0xfe, but not the other way around). This will be less stressful for the cell, as it is the erasing that causes the wear, but you'll have to invert your program logic.
Thanks for sharing your code DrJones and thanks again Tido for planting the seed that made this all possible. Hopefully I will be able to share my dream program with everyone here soon.
Thanks for that info Tido!
DrJones,
Thanks for posting your program. I flashed a generic 3x7135 board last night with your program and it worked like a charm. Using the highest PWM frequency you have listed and a Q5 XR-E I was able to get light using a PWM setting of 1. The next driver I'll flash is an 8x7135 NANJG 105C to be used with an XM-L in a Trustfire T2, assuming everything fits properly.
Thanks again for writing this program,
Kris
Interesting. Maybe those 0.4 µs pulses are not sufficient for 8 AMCs, but for 3...
What fuses did you use?
To be honest, this was my first time doing any Atmel programming so I had just installed a fresh copy of AVR Studio 5 and didn't change any fuse settings. The chip on the board is a low voltage version (1.8V min instead of 2.7), an Attiny13V.
Perhaps with the stock fuse settings it defaults to a slower frequency? I'll gladly check the settings when I get home tonight if you'd let me know where I should check.
Kris
Yes, with stock settings you should get 2.35 kHz PWM frequency.
I think the timing should be off in your setting then; it was compiled for 4.8MHz CPU frequency, but it runs on 1.2MHz. How does strobe look? How long does the beacon take between two flashes? How long does the 5-min timer run?
Edit... Then again, I don't know what stock settings the driver has... the above mentioned are the stock settings for new bare ATtiny13s.
I just looked at the code again and noticed that you had the values for the low fuses listed after the frequencies. I'll try to find where to change the setting and make it 0x75 to run at 4.8 MHz, then try the tests you mentioned.
EDIT: I'm installing AVR Studio 5 on my work computer as I type this. I should be able to find where the fuses are set once it is installed.
Kris
I run mine at 4.8 as well, and set the fuses this way...
avrdude -c usbtiny -p t13 -Ulfuse:w:0x79:m -Uhfuse:w:0xed:m
Not sure if I got all of the fuses right, but it works :)
It turned out that my stock frequency was actually 9.6 MHz. I changed it to 4.8 MHz using the GUI in AVR Studio. This set the fuses to H=0xFB, L=0x71. I'm still able to get light at a PWM of 1, but it is quite dim. I can look directly at the emitter through an 8 degree optic.
I was able to test the other modes as well. The beacon is 10 seconds, the timer works out to a little over 5 minutes, and the PWM frequency seems to be ~8.5 KHz if the PWM is set to 1-31, and ~17 KHz if set to 32-254.
My multimeter doesn't like the strobe, so I can't give an absolute value for that. It did look pretty good though. If the rest of the timings are on then it must be pretty close as well.
If there's anything else you'd like tested I'll give it a shot.
Kris
I am curious if there have been lights whose EEPROMs have worn out, hrm..
C
I implemented ramping now; it's actually only 25 levels of brightness ramping up and down within 4s each (so you see it jumping); tap at the desired level and you get that mode fixed. It costs about 200 bytes, so it's getting full now... 880 bytes used (including timer).
It writes 25 bytes per ramp, wear leveling sure comes in handy here.
I'll play with it for some days and then post the code here.
Ramping, why didn't I think of that? So once it hits the right level, you turn the light off then back on and it goes to that level?
Yes... My mode order is currently
moon, mid, high, ramp, use ramped mode, strobe, beacon, timer
(can be changed of course)
I'd gladly test the brightness ramping code when you post it.
Kris
I'm currently not happy with it: Occasionally there's a glitch when trying to lock the ramped level; when unlucky, the power goes out while writing to the EEPROM, the erase cycle gets through, but not the write, resulting in a wrong PWM level.
I wonder if brown-out detection could help here (I didn't activate it).
I think I want to rewrite some parts of the code. Might even save a few bytes.
Well then, here's a new version with ramping. It's considered beta.
Download: luxdrv v0.21 with ramping
EDIT: Uh-oh, a bug... inhibited the correct mode change on fast taps when ramping.
Download: luxdrv v0.22 with ramping
Well, I used it for a while now and I like it, so I updated the 1st post.
I recently played with a light using an unmodified Nanjg105C - I guess I'm already too used to the smarter firmwares like Tido's or mine to be happy with that. ;)
I'd be happy to get some feedback from you.
