Whats the right voltage setting for charging nimh? The stock setting is 1.65V and I think it’s a bit too high, I set them to 1.55V instead and got ~2450mAh capacity from a pair of eneloop XX. Haven’t touched any of the other settings as I’m not very familiar with ni-mh chemistry. I’ve been using a maha 9000 in auto setting for the last 5 years and it seems to be doing ok.
Correct, if you look at my reviews there is no charge voltage for -dv/dt charging.
Voltage can be used to stop the charge, instead of -dv/dt, but this will usual mean that cells are not filled completely.
Hi all,
I’m new to this forum and joined in the hope of getting some help with my SkyRC MC3000 charger.
There are semi circle metal plates under each slot that appear to be sensors.
My unit arrived from GB with one of these metalic clips dislodged (from slot #3) .
I only noticed it because it had gotten stuck in the slider section for slot#1.
Carefully I placed it back where it dislogged itself from. It seems a bit loose.
My question is:
What is this metal part for (I’m guessing individual battery temp sensor)?
I’d like to know in case I should return to GB.
P.S. The temp sensors for each battery seem to work
The metal plate transfers battery temperature to the temp sensor for that slot, a missing plate do not disable the sensor, but simply means the coupling between the sensor and battery is a bit more loose, i.e. the temperature difference (Between real and measured temperature) will be larger.
Thanks HKJ so much for the reply.
Like I said the plate came loose and I put it back in so at least im not missing any parts.
I did notice some themal paste on the tip of the sensor in the slot hefore i replced the metal plate.
The other plates are all in place very solidly.
This one seems a bit loose.
Do you know of the plates are meant to be be glued or soldered in place?
From what I can tell they just clip in place and come into contact with the thermal paste tip.
Im hoping that even though it feels loose i might just be able to remove and bend it a bit then replace it again.
I really dont want to go through a warranty claim if its working ok.
From my observations temp reading in slot 3 seem very close to the other slots even with the plate feeling a bit loose.
Since temp readings are used in programs Im a bit uneasy with the problem even though its minor …. Just my OCD cant let it go
Thanks again for the advice.
For EU folks: NKon.nl has it now 97,75€ plus ship (around 10€).
Could’nt resist :person_facepalming: . Now the short wait… (guess 4 days)
EDIT: So I had it for two days now … and I already love it!
It is not difficult at all to make programs for it, I have used up the 30 slots!. Well I forced myself to leave a few slot numbers for acute needs.
I gave it a re-calibration (easy done also - can also be found on YouTube) as it was a little off on the last digits. Well it is now exact according to my Fluke 179.
BUT!
I think the MC3000 Charger Manual is really difficult to read i.e. the usage of the abbreviations TOV (Total Overview), SOV (Slot Operation View), SPV (Slot Programming View), DDV (Diagram Drawing View) and GSV (Global Setup View) throughout the manual.
These abbreviations make the manual almost unreadable and should not have been used. I am going to remove them in my written manual and write the real meaning. I think the time used will be earned back quickly.
As a rail in my MC3000 seemed loose when I retracted the negative bracket I decided to look inside.
I immediately saw that the ends of the thin plastic spring posts in slot #3 and #4 were tilted backward because they were broken at the base and the springs pulled the pins forward at the other side of the PCB as much as the hole allowed it to tilt. It could just be a matter of time before the springs would slip the broken posts (as reported by CPF members) and I made a fix that seems to hold.
What worries me is that the good spring posts in slot #1 and #2 look solid enough when they are supported by the PCB hole, so I suspect that the damage to slot #3 and #4 were done at factory assembly time. If the rails are operated without the posts being supported from the PCB then the thin posts could easily snap. On CPF there is a member who collects S/N numbers of MC3000 with broken posts trying to identify a problematic production batch.
Perhaps a member of both forums could help him with my S/N which is 000908555, bought may, 2016.
BTW. A new Firmware v1.11 (and a new manual) has been released. Reportedly it should be safe to upgrade on Windows 10.
I have got 2 broken spring posts in my unit, #1 and #2. Happened while charging 71mm long protected cells, they suddenly just popped off. First I thought the batteries overheated and melted the spring post, but it’s just because the post is extremely thin and weak.
Fixed it myself by attaching the spring to the hole in the PCB using a small ring. But now it’s a bit loose and won’t charge 16340 without a spacer… Not a big deal really since I only use it for measuring the health and capacity, not for regular charging.
My unit was brought just after release, could be the very first batch.
Actually this happened a long time ago, I didn’t realize this problem was so common and didn’t bother to talk about it because I got it fixed in 15 minutes.
@will34
Thank’s for reporting. If you want you could mention your S/N here. I think that sooner or later ‘TinderBox (UK)’ will see this thread and can utilize our numbers in his statistics.
@atbglenn
As HKJ said:
“Even with all the above issues I can only call it a very good charger, but it is not for everyone”.
A buyer should be willing to invest a lot of time and obviously some mechanical and programming (updates) knowledge in this ‘hobby project’.
Many issues have been fixed with firmware upgrades, but I have not tried it.
There is a MEGA thread on CPF about the charger where a guy has collected all the issues and ideas for improvement, then marked them when they where fixed/added.
The boxes are identical as far as I can see. The easiest way to tell the revision is to check the bottom of the charger. If there’s a sticker in a rectangular indent in the center, it’s the newer version. Mine is one of the first newer versions and its serial number is 000978966.
This thread somewhat died last fall..... Does anyone know if these concerns have been addressed in the current version?
It is required to remember the program numbers or press a key, on the initial screen there is no hint on how the selected program works.
Default time on LiIon is 3 hours, this is to short.
When terminating on time or capacity, no capacity information is saved.
Break_in shows charged capacity, not discharge capacity.
Backlight always requires a keypress to turn on, putting a battery into the charger will not turn the light on
Factory calibration do not match specifications.
The PC software requires a high screen resolution
NiMH charge curves looks messy on PC, an option to hiding measuring pauses would be nice.
PC software saves csv files at wrong location.
It is not possible to copy programming from one charger to another, people with more than one charger (That will be me) must enter each program on each charger!
The Bluetooth software is not stable and do not work on all phones.
Strange coding on the usb output, why not use a chip to automatic get the best coding?
