You can get a bit more than 3000 from the XP-L HI, while the 219C can almost reach 3000 OTF with a single 18650 due to the low vF, but it quickly settles down to 2500 or less.
well.my first build triple xpl with BLF A6 body is not happy idea…probably i need spacer for space between star with leds and the dropin…too much space there…
but the outpur is beatiful:)
do i need really a spacer for convoy s2 BLUE?
yes you need spacer for all convoys version or at least copper washers do the trick.
hm…which one would fit into blf a6?
my first modding is painfull:)))
How long is the stock reflector?
11 mm…
Then you would want the S2+ spacer.
question-how will fet driver blf working with the triple xpl?the same function? cos as i know,there is turbo timer.30 seconds or so.how will it work in this upgrade?
also-do we need longer wires,when we will use the spacer?
also-do we need cut the base of the carclo optic? cos they looks little bit longer,then we need…iam not yet sure…
for the convoy hosts you need longer wires,the optic dont need to be cut.the fet driver will work as before but expect on high to get near 10amps if you have good battery.
you mean this one?
Yes, that one. The wires included with any of my triples or FET drivers are long enough to use with an S2+ spacer without adding anything.
This is awesome. Can someone please tell me…someone that has never done this before…if there is a noob step by step guide to making a light like this, or similar to this. Would like to try this but have no idea. Thanks in advance.
question-do you give on optik also o ring?
No I didn’t.
so i bought one…anyway-the fet driver,i used from astrolux did this-after maybe 30 seconds it dropped from fourth-turbo mode to the lowest……i fought,it will drop to mid or high…is it normal? also -do you think,that the heatsink has sense? except the thing,that there you need something for the free space-under the star….
While I’m not sure about that exact driver, my triple does drop from 100% down to 25% brightness after 30 seconds.
And it does not sense temperature.
well,i will test it again and again.anyway-i bought two triple stars xpl from KD…neutral and cool…and-they are almost the same colour…unlike the astrolux 1A and 3D xpls…they are pretty different.this not…sadly.resume is,that i think,convoy s2 is better host for this legendary mod,than BLF A6 host.next week i will try another host…will see.anyway,my far most beloved edc now.LOVEE IT
https://www.fasttech.com/products/0/10002463/1311101-convoy-s4-diy-edc-led-flashlight-host
this could be also good adept for triple xpl modding?anyone tried?i think,this is better cooling…
please,can anyone,who has this spacer send details? parameters…thank you very very much
What parameters? The dimensions are listed on the page. Also, the S4 is not a great candidate for a triple because of the slots in the head
