Good to know.. now I need to make things sure.. I guess my lights are a mix between anodized and not anodized..
what should I get then?
@agedbriar: what youre referring to from DX, is silicone grease, and SPAMBOT is saying to stay away from that.
Who`s right?
@SPAMBOT: what do you prefer (Please dont give me some brandnames from the US. Im in Japan, and would prefer stuff from internet, but rather some DX, DD, KD, MF etc, thank you)
That's exactly what is happening with my blf tank e07. It was smooth and easy to turn before as it arrived lubed. Then when I use silicone grease (MF) it became gritty and black residue formed. I cleaned the grease off before continuing this post and the grittiness diminished considerably.
What is happening? Is silicone still advisable for anodized threads or silicone oil for all threads?
I've used many things in the past, but this works fine for me. You can get a dropper bottle from DX with a very fine tip or a syringe type blunt needle. These are great for applying small amounts of oil to the right places.
If you want something thicker something like SAE90 gearbox oil ought to do the trick.
On badly worn threads, I use plumbers PTFE tape - as long as the negative contact isn't through the threads.
Not sure which countries they are in besides the US, but the precision lube Radio Shack is some really good stuff for the price. I was finding silicone gel too thick before I read about this stuff.
i use the liquid version of super lube. It works great! Anodized or not it makes the metal glide across pretty darn well and with just using one or two drops.
I've been using the DX silicone oil I linked to for several months on anodized and unanodized threads and I'm quite happy with it. Of course, I use it sparingly. Even so, I've learned to not touch the lubricated threads when I drop the battery in my hand.
Another lubricant that worked fine for me, although somewhat thicker, was a silicone grease that scuba divers use. My son pointed me to that one, as it's standard among divers, but I would have to drive to the city to buy it, whereas DX delivers to my doorstep.
Nextorch "SL6" silicone grease, makes non-anodized threads "gritty" and produces grey/black crap that gets everywhere. Not recommended for bare threads. Works well for anodized threads tho...
Bare aluminum is inherently "dirty" so you are going to see some grey residue no matter what, your choice of lubricant can increase or reduce this however. Anodized threads are king since they are naturally much "cleaner". Deoxit is decent, does not produce "crap" nearly as fast as silicone oil and especially silicone grease.
I've used anything and everything ...having heard petroleum based oil isn't good for o-rings I opted for vegetable oil ,lip balm(bees wax) ,hand lotion,bear grease ,and finally silicone lube that I stumbled across in the garage . interesting to hear people don't like it very much ..my feelings on it are mixed as well . Next i'm going to try machine oil like Don ..if my o-rings only last 12 years I'm ok with that too ..
It would attack natural rubber O rings but should have no effect at all on silicone rubber rings. Most engine seals these days would be silicone rubber. Natural rubber is not cheap stuff, silicone rubbers are. It is possible that there could be some solvent effect with some lubricants and some O rings but I've never seen it. The only unwise lubricant I've used was heatsink goo (AKA cutting paste). Though I'd not recommend highly flammable ones or WD40.
I use the same bottle to oil the hinges of the horror film squeaky door just outside my office which gets opened hundreds of times a day as it leads to the wards.
Thinking that the o-ring was probably silicone anyway, I lubed the spindle of a top-leaking water tap with common petroleum grease, as that was the thickest I had and I didn't have a proper replacement o-ring on hand. The effect was that in a few days the o-ring swelled (natural rubber, evidently) and the leak stopped, but I don't expect it to last.
