very thorough review! thanks!
looks like a promising host
green protected Panasonic NCR18650B (longest cells i have) do fit
btw:
i can imagine cyclists will love the behaviour that no mode change happens after short disconnection of the cell
i have to verify by slamming the lights a bit
These look like nice little lights for the group buy price, but I would like to see them add a tailcap magnet.
just pull the spring and glue one in
there is space
Thanks for the review!! The side Clicky doesn’t appear to be water resistant?
it is!
Thanks for the review. I might be able to work with this ui and mode spacing.
It’s a bit wacky like people have said, but since they didnt require you to hold switch to turn on, I’m gonna give this one a try.
Thanks! I suppose we could layout an OSHPark driver to fit, with the holes for the vertical board. Looks like the vertical board is supported well by the side slots in the pill area of the body, so pressure on the switch won’t bend/break the board. Not the easiest to mod, but possible with a custom driver board. They certainly could have used a more standard design to make modding easier…
Can you measure parasitic drain?
as stated in the review…
i tried, but the light came back on high when i connected my 400 mA fused DMM
in Amps config it barley toggles 0.001 - 0.000A
Ooops, yep. I think the Olight S15 or S1 I measured at 0.001 mA - that was the lowest I’ve seen.
Forgot to ask - looks like nothing is holding down the driver on the spring side? So is it loose or just press fit in place, and counting on the end of the battery tube to hold it down and make the electrical connection for the batt- signal?
correct
the driver is fixed and contacted by the batterytube alone
Is the led genuine? Looks a little weird in the photo’s.
Thanks for the very nice review!
First I was very curious about this light, but now “low” mode (around 40-80 lumens) and no low voltage protection is a definite no-go for me.
Martin some of the picture won’t appeared, or is just my isp blocked it?
It appeared now when i use apn
The clip is on the head And there is no low battery protection :-/
Thanks M4D M4X, great job!!!
About projection beam, I think it’s very similar to my Zebralight SC62w:
Sorry, still confused about this. Not sure what you mean by "Amps config". You should be able to operate the light, and turn it off from the side switch while having the DMM connected for low amp measuring - this should then give you a true parasitic drain measure in mA. Sometimes the e-switch firmware will delay or pause a few seconds before going into full sleep mode. In my version of e-switch firmware, I delay a full 10 secs before I drop into sleep mode. I've measured Olights, a NiteCore MH20, and a SWM C20C this way, plus a few others. The MH20 measured about 0.027 mA, while the SWM C20C was about 0.009 mA. The Olights were lower at 0.002 and 0.001 mA.
if the light is ON while you loosen the tailcap it memorizes that mode
i was on high (near 4A) when i unscrewed the tailcap to connect my 400mA fused DMM
brzzzzzzz
clear now?
