Can you specify emitter type? Fasttech and ali sellers post that there is XM-L2 but looks like there is XM-L on photos.
Not for sure yet. Mfg specs say XM-L2. Photo may be older version. I would want XP-L anyhow. Waiting for reply, so probably a few days and maybe a long time, till everything is worked out. Often times it takes a long time to get language problems worked out.
I have had very good luck with Uniquefire lights… I think I would be interested in it as well. But, that driver must go!!!
Looks pretty decent on the outside
Can't get anywhere with the Mfg. I have contacted them 3 times for further detailed info and whoever is responding, just puts in the same stock answer each time. I'm done with it.
$22.23. Please take note that CREE is left out in description.
http://www.ebay.com/itm/Uniquefire-UF-C1408-3LED-T6-5-Mode-Ultra-Bright-1000-Lumens-Flashlight-Torch-QT-/161963084815
….and the leds in the picture are not Cree leds…
It would be nice to get it in host form as long as the driver size is common.
Reflector diameter: 34.3mm
Ledil Cute-3-SS Triple Optic Smooth Spot
Dimensions: Diameter 35mm
Hmm... I wonder what that pill looks like
You mentioned triple, I’m sure Dale will be here in a few…
I got mine today from AliExpress. Payed $23.98 incl. untracked shipping. It was intended to be used as a host for a mod from the beginning.
*The emitters are definitely xm-l (NOT xm-l2) , on a 32mm aluminum board, emitters seem genuine to me!
*Spacing of the emitters is identical to Noctigon 32mm triple board, triple emitter centering ring is included and fits on Noctigon.
*The (thick walled!) aluminum pill is just dropped in, not threaded. I am not sure I can trust the heat transfer to the body there!
*The aluminum triple reflector is screwed from the backside (like in my SRK clone). So the whole light engine is simply clamped between glass lens/bezel and body tube!
*Driver has strobe/hi/mid/low/sos/ mode sequence and HAS TO GO!
*It’s a 22mm driver board held in place by a retaining ring.
I’m planning on a mod including triple Nichia 219c on 32mm Noctigon and a BLF A6 driver…
All the necessary parts are already here (including high drain 26650, AR coated glass, 18AWG wires, Arctic silver, aso. But as there was not much information about this light available, some improvisation is still necessary!
So I am not sure how I can fit the 17mm driver to the 22mm cavity!
? Homemade spacer from a thin copper sheet?
? Remove all parts from original driver, drill a big hole in it, solder the small driver on?
? Any suggestions please?
Thanks and Cheers
Wolf
Maybe use something like this?
http://intl-outdoor.com/17mm-to-20mm-brass-ring-driver-adapter-2pcs-p-804.html
Thanks for the suggestion, actually I do have exactly this thing, but it doesn’t fit! 20mm is too small for the 22mm hole
Let me know if you find a driver suitable, as I am interested in buying this flashlight, now you mentioned that Noctigon XP32 fits in it…
But only if the rubbish driver can be changed…
There must be some sort of driver size converter around for 22mm…
How about something like these?
17mm inner diameter, 22mm outer diameter… Coppper, so good heat transfer… and easily solderable?
22mn Fet driver from mtn-electronics it will be….
Can it handle direct drive? 3x XM-L2 emitters would generate a lot of current draw.
Maybe something like this might be better?
http://www.kaidomain.com/product/details.S025086
4 groups… its quite tall though… would that fit?
Gonna resurrect this thread as with this now being available, could a triple xhp35 be on the cards with 500mah per led?
2900 lumens anyone?
http://www.cnqualitygoods.com/goods.php?id=2248
Might have to buy this as a host after all.
