I think a BLF IS is a great idea, but a lot more discussion/tweaking is probably going to be needed. Regarding the above, I am not sure that a 15cm IS would be practical/useful, especially with some of the larger (and higher-powered) lights out there. Not to mention, I am guessing that 15cm is an OD measurement, so the actual ID is probably a lot smaller. For those not metrically inclined, 15cm is just a hair shy of 6 inches. You would probably even have issues trying to mount a meter to it. Not to mention, I think the port sizes (source and meter) need to be fairly small in relation to a sphere’s ID, which would be nearly impossible with a 6” sphere used for a variety of different size flashlights. Anyway, good on you for getting the ball (uh, sphere) rolling!
A couple more issues that might be worth discussing/addressing:
obviously the exterior must be coated with 1” thick titanium, how else could we be sure the sphere will resist compression forces from the zombie apocalypse
Great idea and I hope this really pans out.
May I suggest that you have some way to make the opening adjustable so that a light as small as a convoy s2 all the way to a acebeam k70 will fit.
15cm would work for small lights and lower lumens, but to use something like a SRK or a large head/High output light, the sphere should be larger. 40cm or bigger. I have seen actual integrating spheres for sale that were "designed for flashlights" and the size was about 12" in diameter, but it was for smaller flashlights. There is information about the size of the entrance port compared to the diameter of the sphere and there are some scientific rules about that. I would just have to go find the info out again.
As for the size, I will look for a bit bigger since that is being requested. But not only can I make white inserts to accommodate different sized heads, there’s the whole data point calibration. There’s no need for the data to be linear, which seems to be the fear of the small sphere with big lights.
IIRC (and I my not as I’m on my second coffee and not quite alive yet), the openings should not exceed 5% of the total inner surface area of the sphere.
