25R flat top no problem ; with it the output is slightly better than a nitecore rated for 1000 lumens with the same battery.
le: play with the 2 threaded rings,one outside and the one from inside ,you can adjust it .
PM replied.
And not to sound too negative, the tint is absolutely fabulous and the beam smooth and floody. Perfect.
Although the high pitched and loud whine is quite annoying on low and medium…
Some graphs. Fantastic!
I’m pretty sure that Rey did not measure the output of the light as-sold. First it is still not completely which led he used, he said 219B, then 219C, and now in the OP the 219C is not mentioned anymore, but you mention 84CRI, which does suggest 219+C. The numbers he got from me (2700lm at start-up, 2000 at 30 seconds) were from my triple 219+C mod, and it has bypassed springs and the ledboard soldered to the pill (makes just a little difference). If the light that he sells has 219+B+ high CRI leds, the output will be nowhere near that.
Which is all too well btw, I think I damaged the leds in mine by running it too long too hot, the output at startup is now under 2000lm. In an aluminium light I can easily feel on the outside when it is time to step the output down, in this titanium light the leds can cook before you notice much on the outside. even at the 1000 lumen output that you get you have to be very careful not to run the light at the higest setting for more than say 30 seconds. (it is not mentioned, but does Rey use a Noctigon in this light?) edit: the pictures show the use of a Noctigon alright
Sorry to hear about your unit.
On my unit, the flat top 30Q, NCR-GA and LG MJ1 all can work.
Swapping to 18350 tube, the AW IMR button-top and Keeppower flat top both can work, so most probably your issue is due to samples’ variation.
Regarding the tint, I compared the beam with my Sinner Triple 219B, and I notice the beam on my Reylight is whiter and slightly brighter than my Sinner, so I just takes the word frm Rey that the emitters are 219C.
I can hear the whine on low and medium modes, but it dissappears on Turbo
is there any visual difference between 219B and 219C?
Mine seems to heat up very quickly. Is this pretty common with this light?
Hi, can I still join this? Would like one option #3 if possible!
The heat is normal.
PM coming.
I’m interested in Option #3 w/9 ice blue/green trits alternating + green trit in tail.
Is this 219B?
Are issues all worked out?
What is the turn around time?
Thanks.
Yes.
219B - most are high CRI (90+ CRI), and 4500K. Color temperature is warmer than the 219C and color rendering is better.
219C - much, MUCH brighter than 219B, but typically cooler 5000K color temp and not high CRI.
Are there still any left? If so, I’d like Option #2 with a green Trit in the Tail cap.
Yes, available, PM coming.
Please PM me and let me know if these options are still available:
Option #3
- Ice Blue/Red/Blue trits
- Red in tail cap
Total cost to deliver to 93737 (California) and expected delivery time.
Thanks - MCT
PMed.
Mine made it in today! Not a triple, but still from Rey!
Found thru hole clips for them at a reasonable price as well!
Is that driver the one from this thread you linked ? The linked driver doesn’t look like it has the solderable stars called for in the firmware you used.
I got my triple from you and it’s very nice, but I want a moonlight mode and I’d like to confirm that the driver supports one before I start taking it apart.
Does that clip fit on the Tool? That looks like an “old-style” Preon clip, one that according to this discussion doesn’t actually fit.
It is 18650 flashlight clip, won’t fit any tool ti AAA.
Here is how to operate the driver, the moon mode is hidden, but it’s not low enough.
