Heck that's got a big one !
5 posts / 0 new
VFMaddict
Last seen: 2 years 9 months ago
The longest pill known to man...........(Well the longest that I've ever seen)....Surprised
"You are making progress if each mistake you make is a new one."
Remember - Most great discoveries start with maki
Hikelite
Last seen: 1 month 4 weeks ago
That Small Sun looks like the ITP C6T.
The small sun wants to build big pills.
JohnnyMac
JohnnyMac's picture
It's probably still hollow all the way through.  Small Sun isn't known for quality goods.
VFMaddict
Yep, that's true.  But as long as it has at least some plate under the star it should be able to handle some heat.  There’s probably also room to fit some copper pipe down that center, possibly split and expanded to be a tight fit.   Its cheap enough to play around with as a mod host and the reflector is interesting at around 50mm.
agedbriar
Last seen: 1 year 9 months ago
Could this be a competitor to the UniqueFire HS-802 (R5)?
From the picture, the reflector seems to be pretty uneven, showing more jaggies than any SMO reflector I own. Not shure how much that might affect the beam quality, though.
Looking forward to a review...
