Are you guys really in write only mode? Check the video a couple of post before… Buck driver pulls what the led needs. If the voltage sags the amp will be higher, if voltage does not drop under load the amps will be less.
Yes I know I will phrase my question differently.
This is my question.
2 cells, one weighs 100g, has over 4500mah, resting voltage of 4.18v. & gives a tail cap reading of 5.4A
The other cell weighs under 90g, has just over 4000mah, resting voltage of 4.15v & gives a tail cap reading of 4.2A.
Which is the better cell ?
Is it the 4.2A cell as it is giving more voltage hence the lower tail cap reading ?
The second cell is advertised by the manufacturer as an improvement on the first cell.
Yes. Check my post .
It al has to do with power (watt), amperage only isn’t saying a lot.
We can’t say for sure based on your measurements, it takes a lot more testing to know what battery is better. Though I think that the lower weight cells has a lower internal resistance so you can draw more amps while maintaining a higher voltage. That doesn’t mean it’s better, it’s just capable of delivering higher amps. While the other has a slightly higher capacity.
Steve Martin once did a skit about being an audiophile. Starting with a little AM transistor radio and moving up to FM Stereo, you want more and more and more, soon enough you have a 10,000Watt system and have to go to the Moon for best hearing experience.
The more lumens we get, the more we want. It’s an never-ending avalanche of incoming lights. Pocket book forewarned.
does anybody know which exact type/bin of the XHP-70 is used in the Thorfire S70? I´ve heard there are different ones, N4 or P2…
Also, I´m curious if a simple spring bypass without the “solder blob” driver mod would also slightly bump the amps of this light?
I´d want a little more “juice” from my S70 but I don´t want 8 or 9 amps, I´d like the light to be still practicable, not a pure “show off” light. I don´t want to shave the LED since I really like the floody beam.
The bin isn’t specified anywhere but it’s a cool white.
Doing both spring bypasses will increase the current a little, bridging the solder pad’s will obviously increase it much more.
I did all on mine and I’m getting:
Efest 26650 purple 3500mah on turbo – 8amps at the tailcap.
MNKE 26650 3500mah on turbo – 6.5amps at the tailcap.
So it’s not just about the bypasses and solder blob, you can actually choose the battery type to vary the amount of current that’ll be drawn.
Even with my light drawing 8amps on Turbo you obviously have low, med, high and turbo so I just switch it to medium to conserve the battery and now and then switch to Turbo and then back again to medium.
Hi, I have my s70, I want to modify adding resistance r100 same as convoy L6, does it work? Where should I put up resistance? In third free slot or on the two r92 stack? Last is stable the mod, or burn controller? This is addictive !!!
Shit, that was the light I was referring to in my post.
Awesome deal at $40 shipped!
And I have an L6 as well and don’t need this light one bit, but I have two extra protected Keeppower 26650’s just sitting in my drawer waiting to be used, might as well add another monster light to the collection… right? lol
I’m gonna keep the S70s stock and mod my L6 into a thrower. Well, as much a thrower as possible. It should go from 550 meters stock to 800 meters modded. That’s not too shabby. Then use the L6 for work and keep the S70s for home. That should work.
