They will have used one of the standard optics, they removed two of the legs to make room for the screws. [modder’s perpective] I bet if you solder the board and leave the screws out you can use the 4-legged Carclo [/modder’s perspective]
This is non standart optics. Had anybody seen it before?
Difference between optics OD and diameter of round where leds centers are laying is other (carclo optics is not cutted by each tir in center), if this optics have same 24mm OD this means that leds are laying closer to each other.
That’s like asking us to go back to incan’s- AIN’T gonna happen! :smiling_imp:
If the optic is good this will be another ‘must have’ light, and if they offer both tubes like with the S1 they’re going to sell like hotcakes. Even with just the short tube I like it already.
If the led-spacing and optic are unique in this light there will be a demand for replacement optics because that is the most vulnerable part of this light.
Yes, twisty.
If tailcup and tubes are same with A6, they already have contact ring and modes can be changed without switch. I suppose that several changes in tail producing could be cheaper than rare 18500 tubes.
Also I’m not sure in good long work of small swithes at big currents, twisty tailcup may be best solution for those who like big Amps.
