If they did a good design and uses the two main contact pads are the thermal conductors then the center pad should not be really needed. ( i guess most of us are used to having the center-pad on Cree emitters to match Noctigon stars, and like to over-drive LEDS to near burn-out. as long as the die, substrate, and two thermal/contact pads are designed well, and we have a good noctigon designed for these LED then where won;t be a problem.
So, if there is a dielectric layer under the electrical traces, how will a Noctigon help? This will be just like all the old Cree boards that have lesser thermal characteristics. The heat being dissipated through the trace pads will still have to go through the dielectric layer and as such, will be slowed down. This is ok if you don’t overclock, not at all conducive to most of us modifying flashlights.
Yeah, DTP stars are pointless if you’re not using the DTP! Best bet would be to make a board like djozz showed, with thick and large copper pours, and use the fancy nano dialectric layer that supposedly has a high thermal conductivity.
To simplify, 1D thermal resistance is a function of conductivity, layer thickness and conducting X-section area. If we’re stuck with using dielectric and copper, we can control 2 of those three variables.
Mitigate thermal bottlenecking by designing positive/negative copper pads as thick and wide as possible, instead of narrow traces. Heat flux can flow through larger cross section of dielectric layer.
Bottom layer is copper and thinner than than +/- pad layer.
For given dielectric layer thickness,
Larger X-section of dielectric -> smaller thermal resistance of dielectric layer -> smaller ∆Temperature across dielectric layer -> cooler temp @ LED die. It won’t ever be as good as true DTP but depending on PCB size it could approach DTP performance. Also, if it works well with 16mm board it will only do better at 20mm.
BeO has safety risks but a similar safer ceramic might suffice. I’m guessing this is a cheaper-easier way for Nichia to reach their efficiency goals within their stated usage parameters. That would be a good business move for an emitter manufacturer, but maybe not for us flashlight people.
It is well to remember that we’re just riding along with the emitter manufacturers- we are not driving the bus. If the emitter business slows due to market saturation or whatever maybe they’ll spend some time designing things just for us. Until then bursts of brilliance followed by dim blue haze (sometimes followed by blue air) will be our baliwick and bane but it shall not stop our relentless pursuit of more and purer lumens! Onward and forward! Full speed ahead! :+1:
FastTech blows goats for half price, once again my order got delayed 12½ days later, they don't seem to be able to get a hold of these alu-nano plates. I'm on the verge of ordering a Sinkpad and be done with it.
Here’s where I get a little confused with electrical arrangements in LEDs.
A common 5.6mm laser diode-can, can be powered over the ground pin, which is sometimes (-) and sometimes (+). As an example, 405nm diodes use a boost driver, 18650 for power, and the body would be negative just like a flashlight, with a diode vF of 5-6V. OK, it’s common practice to solder the negative and ground pin together on the same wire, positive pin on other wire of course. Clearly the driver still has to complete the circuit for power to flow. Why can’t an LED resolve the same outcome? Where negative could be your DTP. :question:
Anyways, I would certainly love to try these two LEDs. It’s incredible what the 219C is rated at on the spec sheet (326 lumens, I think), vs what it can actually output. Just think about the possibility of the other two then, when cooled correctly. The 144AM rated at 1300-1400 lumens at highest bin; I could only imagine a single mono die LED with moderate CRI potentially unleashing 3200-4000 lumens under a smooth reflector.
- Emitting area: 4x4mm (16mm2) - same configuration as a XHP35 (with lower forward voltage)?
- Aluminium Nitride substrate (285 W/(m·K))
Gold contacts
Alumininium nitrite looks like the way to go creating a board for mounting these… it should be reasonably cheap to have someone make a bunch of 16 and 20mm disks… then glue two pieces of copper sheet to the top to act as electrodes. Done.
That’s more like an XHP70 actually (which has 2mm² “XM-L2” dies), yet made as a monolithic die of course without the spaces.
That would be good! XHP70-like output, no window frame=no donut hole.
If we’re talking about what-ifs, this company is placing Cree dies into cylindrical LASER style cans! (I can find the company again if anyone actually wants to know who.)
Of course I would still love to know the reason why negative could not be body-grounded for heatsinking if positive was isolated.
Already made several MCPCB specially designed for this one! You can crash test the LEDs and the MCPCB (I got several CCTs) after Maukka spectral tested them all ;)
The samples took off the factory in Japan in 160829. Don't know how long until they get here.
I created a thread HERE (copied from my thread in CPF), because I didn't know you did it first Worth take a look for some comparison with popular CRI90 Crees. Well, at least spec by spec in the high 90CRI domain, it's superior than comparable XHP50 (colour and performance).
Most, if not all, flashlight led drivers regulate the current to the led by the low side. This means the led's positive lead is directly connected to the battery anode, and its negative lead goes down to the driver, while at the same time the flashlight body, and thus the led's thermal pad, is at battery cathode potential.
And this is the solution, for y'all to see:
Installing the batteries in reverse, we would set the thermal pad and the led's positive lead at anode potential: both leads can get unified. In this way, we would only need to isolate the led's negative lead to the driver. However, this requires a slight led driver PCB redesign to shift their boards polarities: battery cathode connected from the underside central pad, anode through the driver sides/pill and, well, through a positive wire coming from the led MCPCB (lower resistance connection, fellows).
Did I put my foot on someone's mouth? Where's my prize?
We would have to know if both pads are doing the heat transfer to the star.
if so, one could solder the LED on 2 half circles of copper and then put electrical isolation between it and the pill.
That way you have direct thermal path to the star and a big surface with maybe kapton film and some goo on the star.
This way you can avoid the fuss of re-designing the host flashlight.
[EDIT]
Just learned that 90% of the heat transfer is through the cathode.
But i think it’s a good option to isolate the star from the pill, not the LED from the star.
[/EDIT]
