So my ideal combo would be just moon and high, so I would set “1” and “2”. I have always wanted it. But also with the standard thermal protection that drops down to the highest safe level when it overheats.
FWIW, bistro lets you configure it for “moon, turbo” or “low, turbo”.
The start/end array thing is interesting, but it’d add some pretty awkward complexity and might cost more bytes than it saves.
Instead, I’ve been kinda wanting to make a UI where you choose how many modes and then set the brightness for each mode individually. Would be easier with an e-switch. However, I’m not sure it would really be useful to many people. It might just make the config even more awkward. Like, a few people would probably think it’s the best UI ever while everyone else sees it as way too complicated. The few who like it could get better results by changing a line or two of the code and then reflashing.
Anyway, I think my next real project is to make a new e-switch code base where the UI is defined by state machine tables and a few simple hooks instead of defining it directly in code. Data-driven code is almost always easier and more robust than intricate logic flows. Hopefully it’d make new interfaces easy to create without having to modify much code.
I’ve been procrastinating (badly) about that project for like a year, but it looks like some of the relevant hardware will likely be on its way soon due to this thread…
It’s not awkward or complex at all. Check out my code plan:
I moved the discussion here:
So this thread can stay on topic.
This thread has a topic?
I mean, how would you document the interface so that people can easily understand and configure it without reflashing? And how much code would it take to make a runtime config system for setting the beginning and end? Bistro already sets a mode group, so I’d imagine the code for that could be copied or modified to let it load/save/configure two integer options instead of one, but it might use more space than the few bytes it would save in the mode group table.
Looking at bistro now, I think this approach could potentially reduce the mode group table by up to 45 bytes by removing “0” entries and reducing the number of low/turbo entries and zig-zagging the values instead of putting them all in low-to-high order. However, loading and saving another config variable and adding another config step plus numeric selection mode would likely eat up more than 45 bytes. The configuration might also be a bit harder to explain and understand.
It’d be something like…
I’m not sure if that made sense.
In any case, it’s not the button press logic I’m concerned about; that would be nearly identical to what it already uses. It’s the other parts which seem awkward or complex.
User instructions:
Enter programming mode. It will flash once to confirm. Enter the first number. It will flash once to confirm. Enter second number. It will flash twice to confirm and save.
Choose your numbers from below:
1,2 = 1,100
2,1 = 100, 1
1,3 = 100,50,1%
3,1 = 1,50,100%
4,8 = 1,25,50,75,100%
8,4 = 100,75,50,25,1%
8,11 = 100,60,40,10
11,8 = 10,40,60,100
3,4 = 50,1
4,3 = 1,50
The real beauty is offering the reverse sets, and the reduction of low and high recurrences.
If I got a flashlight with a driver like that Josh, it’d go in the bin in a matter of minutes. Too odd, not anywhere near a normal way of thinking and I could never remember it vs all the other lights I own. So it’d go in the trash and an A6 or Bistro driver would go in the light. If it was an e-switch light, then ToyKeepers ramping firmware would do it for me. No setting of modes, no remembering modes, just press and hold til you get the amount of light you want, BAM! Easy peasy.
No offense intended, but simple linear logic or I can’t remember it. Like Dr. Jones stuff, in the bin it goes. (that’s just me and my hundreds of lights though… and the hundreds I’ve made for others)
^This
What I described is like guppydriver, with the goal of more selection on the same tiny chip. It’s not meant to be ‘programmed’ daily. You find your dream combo, mine is 1,100. Once it’s set you never screw with it. It’s just a way to pack the wishes of hundreds on to the limited footprint. It’s crazy to say you like entering 1 number on guppydriver, but 2 numbers is beyond comprehension. Geez. Don’t read the programmer’s talk if you are confused. The effect is just like guppydriver.
I don’t use guppydrv.
I don’t even use Hyperion, although I do like that light from Matt.
About the only things I don’t read are the things people don’t write.
Don’t get a poor memory and confusion mixed up, different things.
Lost me......
“Alright class. For last week’s quiz I gave everyone an index card with a number. You were required to copy it to a sheet of paper to pass the quiz. You all passed. This week the index card will have TWO numbers. Stop crying Dale and jhalb! I am giving you unlimited time, unlimited tries, and an online forum to ask for the answer on! I have faith in you!” :person_facepalming:
What is the answer?
PM me....
I'll get it right I promise!
But seriously. This needs to happen.
What’s the status of this?
I guess we’re waiting on a specific piece of hardware to chosen, or perhaps invented.
The basic physics appears to be, er, solid: http://i-hls.com/2013/10/star-wars-weapons-scientists-create-lightsaber-molecules/
I would think a decent reflow station or a bench power supply, if she does not have one. I build most of my drivers and I have neither and would love either!
Oh, no, we already know the category of hardware TK wants. Scroll back 2 or 3 posts.
Current status? It looks like there’s enough to cover everything on the list. You guys are way too generous.
Tom E made some drivers to send me, and the rest is still a bit fuzzy. I could especially use some tips on what kind of hot-air station to get, and how to aquire a bag of decent parts for drivers. And LEDs and resistors to put on tail boards. Digikey shopping cart maybe?
Mostly though, I’ve been busy trying to cook up the right combination of kernel and distro and tools to make a beaglebone black work with an acme power cape for work, and a little distracted by shiny sword things. As it turns out, building a custom BBB kernel is a bit of a pain, and so is physically organizing its spider-plant-like mess of floating circuits and cables. And by coincidence, SaberForge re-opened its custom saber shop a couple days ago so I put in an order. I can’t get quite the finish I was looking for, so it’s likely I’ll also end up learning how to anodize aluminum and then artificially weather it.
Anyone know a good hot-air station? (aside from broadcast television news )
