I wonder how it works. Seems expensive for just an LED light no matter the wavelength.
The link you listed says “near infrared”. Maybe the device has an infrared sensor to detect the veins, and then uses an internal computer to translate that to a visual image which it then projects into the square. If that is how it works: computer processing with a projected display, then unfortunately this is not the kind of thing you’ll be able to build yourself.
I think you identified the device RobertB. The nurse didn’t seem to want to let the device out of her control, but it looked very much, if not exactly, like the device you named.
Hmmm, that does seem like a distinct possibility. You’re right, that would be out of this modder’s league.
It’s definitely in the price range of IR cameras. And given that they show the veins in different colors, some with the veins darker, some with the veins lighter… I think Firelight2 nailed it. Otherwise their output would all look the same.
Yeah, it does look that way. Didn’t occur to me at the time, but I see that now. That would explain why what I have seen DIY’d online doesn’t look anything like what I saw at the hospital.
Yes, that seems the only logical, plausible explanation. There’s no way skin is going to reflect visible light differently based on vein placement or even temperature.
Of course you could simply use one of DB Customs high lumen lights and enlighten your hand from behind. If it doesn’t get vaporized you should see everything in between.
She’s doing much better and recovering as good as could possibly be expected. Thanks for asking. The whole team at the hospital seemed first rate and I am so grateful.
Now this screams for an app.
I have no Iphone of Iwatch
But the heartbeat sensor or screen sensing many levels of pressure must allow of a 3d scan of what happens under the skin. Then via augmented reality show it to users.
Now that would be an awesome app.
What memories I have of those X-ray spec glasses I lusted for as a kid. But who had a dollar much less the 25cents for shipping??? None of my buds that’s for sure. Ahhhhh……the late 50’s thru early 60”s. :money_mouth_face:
I’ve used one of these before. The one that I used was a wheeled unit and had the green light. The new smaller one seems to use the red. The larger green one I had used a DLP projector to put the IR map onto the skin. I haven’t used it in years but I do remember putting a gloved hand under it and it seeing through the glove without any problem. One time I used it and was able to get a line started on a patient that had nothing that I could feel or see. I got it right away and was pretty amazed. Interestingly, there was a setting for hairy. In actuality the hairy setting was the best for everybody in my experience.
You get to the point where you know the tricks and you sort of sense how to get it and don’t miss. But that said, I sure am glad that there are tools and devices that can help.
