Unfortunately I don’t know how to achieve that on a technical level, my apologies. But I agree it was kind of a big ugly blob in the middle of the panel, so I added a “rudeness” label inside the meter and removed the big title.
Ah, I didn’t realize that it’s become a religious war. That explains why just the other day I ran across a complaint about that on a technical mailing list, and I wondered what the big deal was.
For those who don’t mind using a browser extension, you can paste this in to limit the maximum nesting level of quotes. Use the “import” feature in the “Stylish” extension.
I am really liking the new “rude button” feature. It levels the field for all members.
Rude is rude whether one is a seasoned BLF member, a one day old new person, or anywhere in between.
Since this feature was implemented I have noticed there has been an almost immediate change in the posting behavior of some in all three of those categories.
[ I would fall into the “in between” member myself…… in between seasoned and new. ]
I like the fact that each individual can see their “rudeness quotient”. Even though it has shrunk to super small, I hope it does remain visible to the individual.
I think a “thank you” or “+1” button at the bottom of a post would give others the option to acknowledge a post they wanted to without necessarily having to quote it and reply. Thus keeping threads cleaner.
I also think this should be unique to each post and not combined for a cumulative total or go toward karma points.
That only has the potential to turn things into a circus and / or a popularity contest.
These are my thoughts on the matter. YMMV
Also, what pilotdog68 said below sums it up perfectly…….
I use my tablet a lot when on BLF. Real easy to accidentally hit that button then because of touch screen feature and small size. Maybe make the rudeness button a two stage design. After you hit the button asking are you sure you wish to use this feature?
I continue to think this is a silly and unnecessary addition for a forum. I notice how silly it is every time I see the counter that shows 0 rudeness/10 rudeness. lulz!
At the risk of sounding like a brown noser, the above is perhaps a definitive description of someone who makes a good moderator. As with politicians, anyone who actually WANTS the job, is probably not the right person for the job. This system (the ‘Rude’ button) that you have set up, offloads a little bit of the burden onto the rest of us, and reminds ALL of us to keep our attitudes in check.
I strongly disagree with those who claim that “labels like “rude” and “troll” are used to silence those who choose to dissent from majority opinion”. While they certainly CAN be used in that way, an objective observer can see through throwing labels around. On the other side of the same coin, dissent can be (and in fact MUST be, to be taken seriously) expressed clearly WITHOUT the use of rude and trollish behavior.
