When I said earlier that MPP-1 is better host, I meant in terms of "reflector design". Not the manufacturing quality. As I remember, older DBS V3 with reflector and old pill (EZ1000 with 1A current) did something around 30K lux/1m. MPP-1 uses also EZ1000 and moderate drive level (~1A) and it's doing over 50K lux/1m. If it could use deree pill with EZ900@1.5A that would be interesting.
So... Can you screw the deree pill to the MPP-1 and take the results "reflector Vs. reflector" ?
Sorry, i think someone else said as well that Solarforce P60s is better (CL1H V4 is P60). hehe... Well yeah, the DBS reflector version is only 48mm head diameter anyway, and the MPP-1 is 56mm. The DBS aspheric head is bigger than the DBS reflector head, not the same. I'll see what the MPP-1 holds inside the head.
Actually i just re-measured, the DBS aspheric head is 52mm. It's definitely smaller than the MPP-1.
PS. The Solarforce MPP-1 is probably not driving the LED at 1A. I am measuring 0.817A at the tail with the 2 batteries. With the same pair of batteries i am getting 0.760A for the DBS aspheric 1.5A pill.
Exactly - a more extreme example would be a LASER- the Lumens might be very low relative to a White LED but the "Lumens per square inch" could easily be 20 times higher in the LASER- a more concentrated spot of light.
I think the throw from the emitter will depend on two parameters, one is as you said the surface emitting area, and the second is the angle the dome is designed to throw the light.
"The brightest part of the beam controls throw because that's all that's left at that point."
I do not agree 100% with that, if it was true, the lens diameter would not be important, but it is.
The bigger the diameter, the more amount of light it can get to throw it.
Of course. Emitter surface brightness and lens/optic diameter are what throw is all about. However the question I was answering had to do with how could a XR-E throw further than a higher output XM-L so I was pointing out that the brightest part of the beam is all that’s left at distance.
As in… after a certain distance the less bright part of the beam will not be there and the brightest part is ultimately all that is left at that distance.
2 floors is wide? I think that's very narrow already. The distance is correct, 134m to be exact on the map but i am shooting downwards so it's ~ 150m away.
There is a misconception that an aspheric throws a laser-like spot with no spill, ie useless or just a flashaholic's fun toy nothing too useful in real life. That is absolutely untrue. Remember, the very best high-end rhodoium reflectors do lose at least 85%, and the spill is not "reflectored". In an aspheric, literally everything is projected forwards, the lens cuts 10% approx? This a lot of this light gets to the hotspot. In a ceiling bounce or integrating sphere, the spill light plus corona from a reflectored setup do account for quite a bit.
You can ask Saabluster the seller who does DEFT/DEFT EDC (his latest LED incarnation nets him 700k cd), he would tell you the same thing. If you compare apples-to-apples, the Solarforce Masterpiece Pro-1 has a a very slightly smaller hotspot (10% smaller?), but gets about half of that candlepower figure. Some may not believe it, but it's true.
2100, I feel with an aspheric lens there is a bigger loss than 10%, it is said it can be about a 10% with a common glass, but the thicker it is the more losses you will have.
It is your fault, I will end buying the DBS head to play with it, it is difficult to believe with a big hotspot like that you can throw it 600m, I understand it can win the masterpiece pro-1, there is more than one parameter to achieve a greater distance, and in this case, it might be how good the lens is designed in terms of the angle, the lens quality itself etc, but I think on a same lens quality it should always throw further the smaller hotspot it has.
Just one more thing, did you have the chance to play with the flydragon MS2010 aspheric to compare?
Maybe so, but if it's good quality glass it can reach ~ 10% range or even below. Even the normal achromatic telescopes or photographic lenses with very thick lenses do not cut that much. Lenses is not the same as glass.
Ok, just to set the record, i just measured it and it is about 16% cut. With and without lens measurement via bounce. It's probably not very accurate but just take it as a ballpark figure.
The CSM-360 Flydragon does not have enough surface brightness nor is the lens big w.r.t the big-ass emitter enough to out-throw this.
Ok, maybe let me break it down for you. We calculate distance via measurements. With 90k cd (very conservative figure measured at 55 metres), it is 300m @ 1 lux amd 600m @ 0.25 lux. The latter would be the ANSI standard. There is no guesstimation, hotspot size does not enter the equation. I am measuring at 55 metres, not at 5 metres, not even at 10m which most would tell you "hey, that's far enough for throwers". I use the same distance for my > 1 million cd throwers. Tatjamagic said there is a difference in the lenses themselves even, some give a lot of chromatic abberation (the purple fringing around the spot) and some less.
I posted these pix in my HID big host thread but didn't post the pix in this thread, here goes. 400m target. (Sorry for the light pollution, can't help it man)
The quality of the lenses is a lot, if we compare the lens of a telescope or a photographic lens that costs more than the whole flashlight, it might not be so fair, and the good photographic lenses have a really big diameter when they got a big zoom, or there are big aberrations on them otherwise.
I am not saying I do not believe the measurements you made, in fact as I said I am very tempted to get one DBS for your fault haha, it is just I like discussing about it to find out the reason it is performing so well to you.
I was told by a friend who has the Flydragon's head with an SST-90 DD with 26650 MNKE it throws close to the 1000m distance, but I cannot assure it as it has not been in my hands to prove it, nor there are luxometer tests at big distances as you made to compare.
The Flydragon head is just 80mm, with the SST-90 in direct drive mode of about up to 15 amps and with direct copper to LED bonding it is possible. 1000m is out of this world. You need 250k cd to do that for the target at 0.25 lux. If you look at CPF mod section there are very few folks who manages to do that, namely ma_sha, Saabluster and a few others, with huge lenses.
This is with a 110mm lens, SST-50 driven to 9 amps, copper heat sink with active cooling.
But with a 7 x50 bino (some light amplification) and a really dark site like in the desert, light at least 15m away to the right or left from the observer and a good target, eg a silver car, it is possible even with 100k cd @ 1000m. But that is not realistic.
In fact i rate my 3.8 million cd light to be good at 2km. That is 1 lux at target.
66mm lens with XM-L driven hard gives you 100k, that's the ballpark of this Dereelight DBS aspheric light. :)
Actually you could get even more lux with the XP-C driven to 1A
The die is 0.7mm x 0.7mm. EZ900 die XR-E R2 is 0.9mm by 0.9mm. EZ1000 XR-E R2 is 1.0mm by 1.0mm. The beam is quite narrow, so it is not useful even at 100m (handshake, causes the beam to dance around at target)
Thanks for the info 2100, I will ask to get some luxometer tests for the Flydragon head and SST-90, which I believe it was driven at 10A.
My plan as I thinks said before, is making a flood to throw with the DBS with an XM-L, by the time I get it I hope I can get a U3 (they are just about to be released).
With an XM-L U2 and a 38mm lens I got, I have managed to get around 400m throw "by eye" , do you feel the DBS will throw further than 400m with an XM-L?
I happen to have the T6 3C neutral white pill which has the same output as regular cold-white T6. I measured close just a wee bit over 50k for that. So that's about 450m throw for 0.25 lux. I guess you live at a really dark site plus you had dark-adapted eyes.
