yup.but that 13 incher really caught my attention too.wish they would sell it on a per piece basis. btw is its 55w h3 bulb same in intensity as a 55w h4 bulb?
Astronomy is more fun than flashlights :)I’ve done it in a relatively inexpensive way. I started out with 80mm refractor and then went to 8" reflector and now I end up using the 80mm refractor and 15x70 binoculars most of the time.
I don’t have any motorized gear and I locate things just by “star hopping” and by referring to a software program on my PC. What kind of telescope are you planning to get?
I've been interested in trying to check out the heavens since like 15 years ago but i still haven't started work then so stopped. Then 8 years ago i wanted to get one but i figured that i need to drive to a secluded place to ob so too much work/time (need to work the next day!). Just last year i wanted to start again but stopped, now want to start again. hehe.... I just moved to my place 2yrs ago which has a rooftop garden so it's going to be quite easy for me, i don't have to walk > 50m from my apartment. But there are turnstiles to negotiate so no SCTs or big mounts.
Going to use on a Twilight II Alt-Az mount. No Goto, so keep it easy by star hopping.
I figured that 2kg for the CF is not a lot of savings, but i'll be using this for quite a while, and due to the local tropical weather = lots of clouds, i need to be very fast. The CF looks good too.
The problem is the focusser as it slips a bit after a few minutes if you get in a heavy > 20 oz EP there, i guess for me starting out it's not an issue. When i was doing bird photography i had a setup which is not very ideal too (just a 486RC Manfrotto ballhead) but i managed somehow. I am not a very particular person, but i do appreciate some quality. But an upgrade to a Feathertouch or Moonlite is gonna cost!
Stellarvue has some good scopes with good focussers, but $$$...sigh. I think optically it's not going to make much of a difference esp with the ES at 127mm.
Now thats one hell of a reflector! if that thing throws close to a maxabeam we have a winner here. a pricey one at that. are your spare ballasts h3 or h4? this is a h3 bulb light so a h4 swap would need some modding.
I have like 30 over H3 bulbs 55W.... :D Purple, pink, blue, 30k, 3k, 4.3k, 5k, 6k, take your pick. Very cheap, 11 bucks shipped. I went bonkers last time with HIDs. They are also not "very dim" but i think they definitely wear down quicker than Philips/GE bulbs. But so far no failures (I don't use them that often anyway) It's hot, like XM-Ls i don't think anybody guns past 20 mins anyway....
But 75W I have only 1 pair of 4300K and 100W also 1 pair of 4300k.
I estimate 6 mil PBCP tops and 4 mil minimum with the 100W bulb (5mm arc length). It should beat the original Maxabeam, no doubt about that....which is at 2.3 mil.
Yes, 2km is using the international searchlight standard. If we were to use that standard to describe stuff like the Solarforce Masterpiece Pro-1 XR-E in a 50mm plus head, it'd be something like 223 metres range only. Or it's 4km range if we use LED flashlights standard.
I just wanted to see how large the spot was at 100M but if you want to do 2KM, that's fine too LoL. I"m not sure I'll be able to compare it to anything though if you tried to do it that far away...
Shucks, what a let down, the beam quality is pretty bad, the hotspot is sort of a star instead of circular like the SM5200 or Amondotech 3152. Of course such big SMO reflector HIDs are not really for even 10 metres white wall beam shots because seriously it would like real bad. On the lux meter it is just slightly below 2X the lux of the SM5200. I need to go out to 50 metres and measure (beam focus phenomenon)
At 2X the reflector diameter, theorectically it should get 4X the lux. Because of this "star pattern" hotspot, quite a fair bit of the hotspot is not focused at one point but spread over a star. So that's wasted light.
The funny thing is that the reflector is perfectly smooth and structurally it looks seamless. But the beam comes out like that.
It can do about 1.1km visibly and definitely is a upgrade over the SM5200 when compared side by side, but 2km is not possible. DAMNT IT! It's something like a Fenix TK35 vs a Crelant 7G5.....rather than a Fenix TK35 vs a SR90.
I tried playing with the focus for the past few hrs. No go.
From what i see, this is only for the most hardcore HID/big host enthusiast, with spare bulbs/ballasts of different powers to play with. It's really too expensive for the parts/engineering or even compared to similar HIDs though they are smaller, but then i like the bulk.
Coz if you want any more throw you'd have to go the usd 2k plus route for portability. The Vector 192 being the other monster sized HID (but ballasts are mounted outside plus you need Li ion pack to be inside in order to power the 2 x 100W ballasts, so it's pretty ugly)
This is actually the Sunca CS-2206CX model. There is a Sunca CS-2206 model which is proably about 7". They just hooked out a bigger plastic cavity housing and do up a bigger alu reflector. The good thing is that the internal cavity is very big and lots of space to swallow a 100W big sized ballast. :)
The smaller brother.... Sunca CS-2206. The CS-2206CX is the new 13" one.
Are you just shimming the bulb in and out of the reflector? I had the same problem with my Professional's Favorite. Well, mine looked more like a "Plus" symbol than it did like a star, but my problem was that i needed to move it in all 3 axis to focus it (not just in and out).
