sent
sent
Please send me a second round code. I want to buy one for a friend
That Lumzoo looks old-school and great!
Hey Martin, you are really doing a number on my bank account!
Shit, i have to get that BTU light in desert tan when the price is good.
@ Lumzoo : wth? :laughing: its like a tomahawk, i like strange looking lights.
yesss tomahawk
I’d like the PK26 BTU code when you get it Mr Max. Thx!
I’ve been fighting that same issue for over a year now, if you find a fix please let me know
the first 100 get a free 18350 batterytube
Features:
1. Built-in temperature control module, automatically adjust the brightness according to ambient temperature working status of each output in order to achieve
the best working condition
2. Tip overheated housing
In the lighting state case temperature reaches 55 degrees, LCD display will flash rapidly to alert temperature symbol with dimming to ensure the user's comfort,
so as to prevent excessive heat generated by the discomfort.
3. Low battery indicator
when the battery voltage is lower than 3.1V, LCD will display (the frequency of 30 times per sencond), battery symbol flashes to prompt the user to replace the
battery or charge it in time.
4. Aerospace grade aluminum, Army regulations three hardened wear-resistant surface treatment
people with the "wholesale problem" can write a mail to contact wholesale@banggood.com
tell them you are a private customer - no wholeseller and ask to remove the flag.
i hope that helps!
Martin,
Please pm code for BTU PK26. Thanks!
as soon as its available :)
Ordered an Astrolux MH10. I’ll be broke after this month.
A shame that the PK26 is HD and has a hold to turn on/off UI.
Like the look of the BTU mini titanium.
Pity it doesnt come with the extension as well, like the PK26 does.
Exactly, I like the extension tube as well!
Can I get the code for the Skilhunt H03 (NW) please. Thanks for your time.
Suppose as its titanium, the longer tube increase the cost of the flashlight considerably…
Whereas the PK26 is ALU, so is cheap to bundle a longer tube.
That Lumzo angle light looks so bizarre and interesting, sadly it doesn't come with grooves for using as a headlamp so I guess it is more of a work lamp.
It says 1.1hr runtime on turbo which probably means no step down!
Should I order now or there will be better price with the coupon?
Edit: what I have read so far about the GH10 in a chinese forum:
-Shortest 18650 flashlight in the world at just 80mm
-Only takes unprotected cells
-AR glass and aluminium reflector
-Unibody construction
-PWM-free driver
-Copper DTP MCPCB
-Max 1,190lm min 0.5lm
-Unclear: steps down to high after few minutes
-Low voltage cutoff at 2.8V
-Single click turns on/off, hold for modes
-Copper springs
The specs are ridiculously good for only $30...
