I’d like the PK26 BTU code when you get it Mr Max. Thx!
I’ve been fighting that same issue for over a year now, if you find a fix please let me know
Astrolux MH10
Cree XPL HI 18650 1000LM USB Rechargeable Outdoor LED Flashlight
the first 100 get a free 18350 batterytube
Features:
1. Built-in temperature control module, automatically adjust the brightness according to ambient temperature working status of each output in order to achieve
the best working condition
2. Tip overheated housing
In the lighting state case temperature reaches 55 degrees, LCD display will flash rapidly to alert temperature symbol with dimming to ensure the user's comfort,
so as to prevent excessive heat generated by the discomfort.
3. Low battery indicator
when the battery voltage is lower than 3.1V, LCD will display (the frequency of 30 times per sencond), battery symbol flashes to prompt the user to replace the
battery or charge it in time.
4. Aerospace grade aluminum, Army regulations three hardened wear-resistant surface treatment
people with the "wholesale problem" can write a mail to contact wholesale@banggood.com
tell them you are a private customer - no wholeseller and ask to remove the flag.
i hope that helps!
Martin,
Please pm code for BTU PK26. Thanks!
as soon as its available :)
Ordered an Astrolux MH10. I’ll be broke after this month.
A shame that the PK26 is HD and has a hold to turn on/off UI.
Like the look of the BTU mini titanium.
Pity it doesnt come with the extension as well, like the PK26 does.
Exactly, I like the extension tube as well!
Can I get the code for the Skilhunt H03 (NW) please. Thanks for your time.
Suppose as its titanium, the longer tube increase the cost of the flashlight considerably…
Whereas the PK26 is ALU, so is cheap to bundle a longer tube.
That Lumzo angle light looks so bizarre and interesting, sadly it doesn't come with grooves for using as a headlamp so I guess it is more of a work lamp.
It says 1.1hr runtime on turbo which probably means no step down!
Should I order now or there will be better price with the coupon?
Edit: what I have read so far about the GH10 in a chinese forum:
-Shortest 18650 flashlight in the world at just 80mm
-Only takes unprotected cells
-AR glass and aluminium reflector
-Unibody construction
-PWM-free driver
-Copper DTP MCPCB
-Max 1,190lm min 0.5lm
-Unclear: steps down to high after few minutes
-Low voltage cutoff at 2.8V
-Single click turns on/off, hold for modes
-Copper springs
The specs are ridiculously good for only $30...
PK26 code will be available after HI Version is added ;)
let’s get that hurried up please
sadly it doesn’t come with grooves for using as a headlamp
The bumf on Banggood says it comes with a headband.
KEWEISI 3V-9V 0-3A
USB Charger Power Battery Capacity Tester Voltage Current Meter
Code: 5ed456 brings it to US$ 3.99 (shipped from .cn)
3000mAh Unprotected Button Top 18650 Battery
code:a59300 price: US$ 9.99 for Button Top
3000mah 20A Power Li-ion Battery for Samsung
code:M4D30Q price: US$ 8.49 for Flat Top
Hi M4X, where can I buy 18650 cells? BG doesn’t ship to my country, Philippines…
dealextreme and fasttech might ship to your country
but pay attention not to get fakes
If you don´t already have one of this kind of thingies, I could recommend.
Very easy little thing to get Rough estimates for example how much Your several different cellphone chargers put out Amps in reality
…and at what point of the charging procedure…
You can also easily get a rough estimate, of how much your cell takes in. Cannot say anything about losses and science & stuff but at least you get a ballpark reference
