M4D M4X deals - Astrolux WP1 and WP2 LEP
people with the "wholesale problem" can write a mail to contact wholesale@banggood.com
tell them you are a private customer - no wholeseller and ask to remove the flag.
i hope that helps!
Martin,
Please pm code for BTU PK26. Thanks!
as soon as its available :)
Ordered an Astrolux MH10. I’ll be broke after this month.
A shame that the PK26 is HD and has a hold to turn on/off UI.
Like the look of the BTU mini titanium.
Pity it doesnt come with the extension as well, like the PK26 does.
Exactly, I like the extension tube as well!
Can I get the code for the Skilhunt H03 (NW) please. Thanks for your time.
Suppose as its titanium, the longer tube increase the cost of the flashlight considerably…
Whereas the PK26 is ALU, so is cheap to bundle a longer tube.
That Lumzo angle light looks so bizarre and interesting, sadly it doesn't come with grooves for using as a headlamp so I guess it is more of a work lamp.
It says 1.1hr runtime on turbo which probably means no step down!
Should I order now or there will be better price with the coupon?
Edit: what I have read so far about the GH10 in a chinese forum:
-Shortest 18650 flashlight in the world at just 80mm
-Only takes unprotected cells
-AR glass and aluminium reflector
-Unibody construction
-PWM-free driver
-Copper DTP MCPCB
-Max 1,190lm min 0.5lm
-Unclear: steps down to high after few minutes
-Low voltage cutoff at 2.8V
-Single click turns on/off, hold for modes
-Copper springs
The specs are ridiculously good for only $30...
PK26 code will be available after HI Version is added ;)
let’s get that hurried up please :slight_smile:
The bumf on Banggood says it comes with a headband.
KEWEISI 3V-9V 0-3A
USB Charger Power Battery Capacity Tester Voltage Current Meter
Code: 5ed456 brings it to US$ 3.99 (shipped from .cn)
Hi M4X, where can I buy 18650 cells? BG doesn’t ship to my country, Philippines…
dealextreme and fasttech might ship to your country
but pay attention not to get fakes
If you don´t already have one of this kind of thingies, I could recommend.
Very easy little thing to get Rough estimates for example how much Your several different cellphone chargers put out Amps in reality :slight_smile:
…and at what point of the charging procedure…
You can also easily get a rough estimate, of how much your cell takes in. Cannot say anything about losses and science & stuff but at least you get a ballpark reference :slight_smile:
Olight R50 Seeker code PM only
KEWEISI i just what I was looking for! Thanks!! Ordered.
They say an Optimist sees the glass half empty, and the Pessimist as half full.
I consider myself a Realist - I figure that sooner or later, I’m going to get stuck washing the glass.
Martin, I think you are an Optimist.
I sent the note, as you suggested, and got the following reply:
I have replied that my account SHOULD NOT BE a wholesale account. I think perhaps the next thing I’ll try is to demand a “wholesale” discount. Perhaps I can get an idea of how many of a thing you need to order to trigger the wholesale flag. It may have been the (30) 30x70 mm printed circuit boards I bought to teach soldering to some middle and high school students.
