If you want more output maybe a dedomed XPG2 would be a good option. I’m not sure about the exact XPE2 die size, but I think a dedomed XPG2 might have a similar beam size to a domed XPE2 and depending on the current it would be significantly brighter also.
As XP-G2 LED has been suggested, I’ve checked for dimensions.
The die have a size of 1.4mm x 1.4mm against 1mm x 1mm for the XP-E.
However I think that a de-domed XP-G2 (or maybe XP-G3) could have a similar beam angle than a domed XP-E/XP-E2. What do you think about that?
If it can be similar (or narrower) I will try to find someone to make the dedoming process because I cannot do it myself.
Thank you very much for that.
After some researches, XT-E seems to be quite similar to the XP-G2. Both have a dome radius of 1.53mm and both have an viewing angle of 115°. Thus I think that they have the same die size (I didn’t manage to find the die size of the XT-E). Tell me if I’m wrong.
If I’m right, the main difference is the output brightness.
In my previous post I spoke about XP-G3 but the die seems to be bigger than the die of XP-G2.
Yoann, unfortunately FastTech is not known to provide consistently accurate information about their products. When I need specific product information I log in on their website and make an inquiry about the product, their customer service usually works nicely.
Regarding your doubts about the product, check this out:
XT-E R5 bin is 139-148 lumens at 350mA, 85º. At 1'5A luminous flux is ≈3'08 times that, thence 441'98 average lumens.
XT-E R2 bin is 114-122 lumens at 350mA, 85º. At 1'5A luminous flux is ≈3'08 times that, thence 363'44 average lumens.
629 lumens? Flashy numbers, yeah. Maybe possible on a bin unheard of, a higher driving current, smoking some crack, and/or any combination of the aforementioned…
And please bear in mind that, in practice, you may find yourself somewhat hard-pressed to say an R5 is noticeably brighter than an R2; you'll notice a difference, yet it won't be as noticeable as you may think to the naked eye. I'd take the warm whites, and of course some could argue it is a matter of personal preference but, I am not the first to say the reason for the higher vision comfort with warm/neutral white light is in some way related to the low temperature of the available light sources at night which mankind has evolved with: campfires, torches, etc.
It seems that XT-E is a good tradeoff between a narrow beam and a bright beam.
The tint is not really a criterium of choice because it is not for a night vision but for a night lighting effect. It is why I looking for the narrower and brighter beam possible. Do you know which tint is the more visible into smoke or fog?
CREE XT-E should give me a larger beam than with XP-E because the dome is a bit larger. But output brightness seems more important at high current. As with XP-E/XP-E2, can I easily overdrive XT-E to increase brightness? For example up to 2A, 2.5A or more? (Of course with a good heat sink).
I didn’t manage to find plots representing relation current/lumens for the XT-E.
Yoann, with regards to the tint all I can say is the colour temperature of classic fog lights is warm white (≈3200K).
The die size of the XT-E is the same as that of the XP-E, “E” class…
If you really want a narrow beam you may want to invest on some lenses, but that'll add to the cost.
Overdriving the led? I do not think you'll end up getting a worthwhile performance boost vs the cost of the required cooling improvements (reflowing the leds onto copper DTP PCBs, etc). I'd (first) consider using a clearly higher output led (XM-L2…).
XLamp XT-E datasheet -> Page 24/38 for the relative luminous flux vs current graph.
It is a new version of the doc, I had an older one. The graph shows now 327% relative luminous flux at 1500 vs 350mA.
Hello I have XP-L leds that use the same die than XM-L2. However to obtain similar beam I need a very big lens at a more important focal length. Then I have a more important output but it is difficult to concentrate a large part of the beam (a lot of light is lost between the lens and the led). For now I have lens of about 22mm (diameter) and a focal length of about 12mm.
If I can find lens with 25-26mm diameter and a focal length 15-18mm I think it will be great for XT-E.
Thank you, but on AliExpress it is really more expensive.
For buying XT-E R5 1A it is more interested to buy them on FastTech (arround 5 USD for 5 pieces).
In fact datasheet specify S2 and S3 bin for the XT-E. It is for why I’m looking for a shop to buy S3 (else S2) bin.
I’ve found XT-E S2 1A on ebay but with a huge price (not acceptable) and I cannot ffind S3 bin.
Hello,
Just to give some information that may be useful for someone.
I’ve bought CREE XT-E LEDs and compared them to CREE XP-E.
Even if they have the same die size, I obtain a larger beam than with XP-E. The primary optic of the XT-E is bigger than the primary optic of the XP-E.
Then I tried tu re-use my XP-E Q5 (from flashlight). However, I obtained a strange behavior.
First I tried to replace the original flashlight driver but a simple voltage/current regulator in order to have only one mode (on/off).
For that I use this kind of power supply: Power supply
I’ve set it to limit at 3.2v and 1.5A, but when I connect the LED I can only mesure 0.2A…
By discussing on an other forum I tried to increase the voltage, when I’m arround 5 I’ve only arround 0.7A. After the LED burnt…
Does I miss something regarding the usage of these LEDs?
Yoann, with the limited information you are providing, can't really be sure what you're doing wrong… maybe those current measurements aren't accurate. Are you providing enough voltage leverage at the input?
You don't really need to mess with the voltage trimpot, leave it at full throttle.
Start with the current trimpot at a minimum/low value. Connect the emitter in series with an amperimeter at the output, or set it in series with a low value resistor where you'll monitor the voltage drop at its leads, so you can determine the current flowing through the load: V = I × R, thence for an R200 (0.2Ω), at 0.7A of current flow you'll measure 0.14V at the resistor terminals.
Mmm, wait, there's an R050 sense resistor on the board. Measuring the voltage at its leads will give you the current output value: 0.05V/A (I = V / R). As long as your voltmeter is accurate enough, that is.
Cheers ^:)
P.S.: please, @#$% with those “local” aliexpress links, please post only global site links. Not only I do not want to open despisable & clownily translated item links, it also happens the friggin thing starts to think I “like” such a crap by default, and it forces me to use the “Go to Global Site” link to restore normal operating conditions. Thanks.
