MechEngVictor, Gearbest is ordering the 100 drivers so there should be enough.
I did some testing, keep in mind that my test setup was a little sketchy however the numbers do look great.
I did get a 1.5A on high. It started around 1.35 and it went up to 1.49 in a couple of seconds. Not sure if thats the driver or my test setup.
Medium is around 0.3A and low around 0.03A.
Mode memory works, the lights has to be off for approximately 1 sec to memorize the mode.
The driver does get warm/hot, though I haven’t tested the thermal stepdown.
It is too late to sign up.
But gearbest have them already for sale, they (as far as I know) have 100 pieces in stock and since we have a confirmed 60 pieces there should be enough. I’ll send you the coupon code so you can order it.
