Thanks! Order placed
Placed my order just a few mins ago. Thanks again!
Op, thanks for that GB !
Is it too late to sign up for two :question:
please more info about this project/D01 extension tube …
I’d like to get in on this if it isn’t too late as well.
Thanks! Just ordered
It is too late to sign up.
But gearbest have them already for sale, they (as far as I know) have 100 pieces in stock and since we have a confirmed 60 pieces there should be enough. I’ll send you the coupon code so you can order it.
Ordered thanks :+1:
Thanks! :+1: ordered two
Am I too late? I would like 2 pcs,
thanks
Thanks! I ordered a couple right away this morning. How many lumens will an XHP35 HI give at 1.5A? I’m guessing between 1300 & 1500?
1200 - 1300 lumens
(deduce from XHP50/70 djozz’s graph XHP50 = 1300 XHP70 = 1400)
You forget that the XHP35 is a 12V emitter, it would actually be equal to 3A in those LED’s.
Ordered, thanks!! :+1:
It should do around 2000 lumens at 1.5 if I’m not mistaking.
2 pcs
Already got them. Quick shipping from gearbest.
Forgot to mention (shame on me :person_facepalming: ) that the drivers dont come with a spring. So you have to solder your own spring on it.
What host(s) is everyone using theirs in? Mine have not arrived yet.
Can this driver utilise e-switch? because there is a soldering point with “Key” printed beside? (Presumably other lead would be soldered to ground but I am not sure, that would be 8.4V thru teeny tiny e-button)!
