He states that the video is not a review.
Because he sells at https://www.selected-lights.de/ he does the videos just to show the products on camera and any revues will be done by members of http://www.taschenlampen-forum.de/.
Ahh, ok, didnt speak the lingo so what he said meant nothing to me.
Still, if I was trying to sell something Iâd try to show off what it can do a bit more.
Hopefully a proper review comes along soon which gives a better overall impression.
I downloaded the manual from the link provided in the first post. The light will NOT operate in turbo mode without the proprietary battery. Everything else apparently will function with a regular 18650. Obviously, this means putting another powerhouse battery in the light will be counterproductive.
Turbo mode is good for 15 minutes of runtime.
Nice find! with a normal 18650 the highest mode would be 1350lm for 4minutes, bummerâŚ
http://flashlight.nitecore.com/html/uploads/ueditor/image/product/TM03/TM03_UM_EN.pdf
Anyone want to know more about the âproprietaryâ cell? The expensive Nitecore TM-03 battery that is âhigh drainâ and âhigh capacityâ?
I bought a back-up directly from the âNitecoreStoreâ. It came in today, before the light made it. And whoâd a thunk what I found inside? A simple little ol Panasonic PF! Thatâs right, with circuitry top and bottom making it proprietary! Figure Iâll take the circuitry off and attach it to a Samsung 30Q and see what happens.
Yep, I paid $20 for an old Panasonic PF with a circuit on it (that now wonât work in the light it was made for!) Wish me luck on the 30QâŚ.
Do you have an article about batteries explaining those nomenclatures?
I did think those panasonics are the best.
Wow Dale⌠I seriously did NOT expect that. I was expecting a 30Q or HG2, since Nitecore made so much fuzz about this âspecial high drain batteryâ. I hope you have made it work with the 30Q.
Iâm also surprised on how wrongly used is the âIMRâ chemistry term.
Many years ago, probably true. But for todayâs standards the PF does not even compare with a medium-drain.
We donât have articles explaining nomenclatures, we have tests: (actually I think we do have such articles but a test shows it better)
The orbtronic 18650PD is based on the panasonic PF cell as per [HJKâs review](Test/Review of Orbtronic 18650PD 2900mAh (Black) | Candle Power Flashlight Forum.
That applies for 3400mha too?
Whats considered med and high drain?
The PF is/was a decent cell, but lower internal resistance cells took over by allowing much higher currents in our FET driver based lights. Cells like the Efest Purple 35A, LG HE-2, HE-4, Samsung 30Q, there are quite a few these days that outperform the PF series from Panasonic. Even their own BD has higher capacity with better current capabilities.
To the best of my knowledge the circuitry is a protection circuit for over-discharge and low voltage protection, weâll need someone more familiar with electronics to verify what that circuit is. Thereâs no components at the tail.
There isnât a fixed definition but for our use a high drain is a battery rated to supply constant 10A, or a triple XP-L direct drive setup. If the 3,400mah you refer to is the panasonic NCR18650BD than that is a very low drain cell.
Med drain:
-Sanyo GA
-LG MJ1
-Samsung 35E
High drain;
-Samsung 30Q
-LG HG2
-Sony VTC5/6
Thanks Dale and Will34, Iâm newbie with that
Those high drain cannot come with protection circuit?
I bought those too: http://www.banggood.com/4PCS-3_7V-2600mah-Button-Top-Protected-18650-Lithium-Battery-For-Samsung-p-913785.html
How many amps those can push?
Wow very unexpected, but nice find Dale. I really hope you are able to wire up that 30q.
And if you do, who knowsâŚwe may possibly see 3300 lumens!
Iâm actually surprised you purchased this light in the first place. What made you want it?
Would have thought u go klarus g20 or olight r50 route or acebeam ec50 version 2 ?
WOW
nice find Dale!
The stock output are already exceeded 3300 lumens though around 3500, check mhanlenâs review.
I can vouch for his accuracy, as i also have this light and have proper means for estimation.
I look forward to putting the TM03 in the lightbox with the stock specialized cell and hopefully a Samsung 30Q variant, will be interesting to see if thereâs an output difference. My TM03 is on the wayâŚ
im really hoping the 30q works, and that it pushes the power for the strobe mode because it is waaaay under performing right now in stock form.
Not sure how you can take that stance, it far exceeds what any other 6V emitter does on a single cell.
But yeah, my goal is to see what can be done to push it. lol I donât know where I got that idea, I mean, whoâd do such a thing?
<â- walks away whistling
i was only referring to strobe mode. i think i measured no more than 1000 lumens.
but yea , on turbo mode, this light kicks ass at over 3000 lumens.
i was really hoping that the strobe mode would also be 3000 lumens, which would have made it nice for a self defense situation, i was pretty dissapointed about that.
I would imagine that the Boost driver has spikes that would end up frying the emitter if used in full power on strobe. Something like that, anyway.
I am curious, as well.
PM with the price, please?
