As I saw the components are the same as the old driver.
Is there any changes in schematics on PCB or it is absolutely same as old one.
Sorry about my novice question.
It will be nice, but do not belive it is possible. Even 90k is difficult with this reflector size.
Actually I have two moded flashlight with XP-G2 diode. Convoy C8 has 160k and Eagle Eye X6 has 110k candela.
Perhaps the 35 and 50 work out too close together on paper, but this is a good reason there isn’t a grouping that has 35 and 50 in it at the same time. 50% was a half power option for those wishing to have decent output with low heat and prolonged cell life. Tit for tat, as it were. 35% fills the bill in spacing where more modes are being used.
In the C8 where I added 5 chips to the driver, 35% yields 662 lumens where 50% yeilds 693 lumens. So the output is quite close, but the 35% is used as a half step between other modes in the groups it’s used in. The target was to be more pleasing to the eye in the size of the step. It is, after all, the end result that really matters regardless of the particular numbers used in getting there.
So basically respected and honored author of this firmware did it as a fun project free of charge (that’s how I understood his post, I may be wrong thou, english is not my native language)!
and Wildcat confirmed that hardware is identical (color is not important at this time)
(this sounds to me more like a confirmation than estimation!).
Finally, question: Is this fw available for download in hex format (really important is that it does not lock mcu for future flashing) or as a code (AVR Studio will chew that up and spit hex file) so I could try out this new fw and decide if I like it or not I am indifferent?
Yes, ToyKeeper did this at my request for Convoy for which Simon and I are both extremely thankful.
ToyKeeper’s work is open source meaning free for all to use and yes the hex code is downloadable as well.
The hardware is certainly very similar if not identical aside from the color which was changed mostly to distinguish which drivers have the new firmware already loaded. None of us have the new driver quite yet so I can’t say with 100% certainty that it will be completely identical but if there are changes they will be very small I’d imagine. This firmware should work on many Attiny13a/7135 based drivers including almost all of Simon’s older drivers.
You can download it at anytime through Toykeepers firmware repository.
