Welcome to BLF 007,these batteries are excellent cells based on the panasonic ncr 18650,same as redilast although the cell is the same,protection circuit is different and takes longer to trip due to a higher current drain.See HKJ's review https://budgetlightforum.com/t/-/6745, good stuff from a battery guru.Pila charger is great,which is what I have and love it,anything with a cc/cv charging capability is good.In short,yes these are good and using a multimeter before and after charging will usually red flag any problems.
IIRC, those cells arent that good in single cell lights, because they discharge pretty steady down to.. 2.8V or something while most other cells give most of their energy down to 3.6V.
Thanks for your feedback, but my understanding is that the cell is based on a Panasonic cell, and the cell determines the discharge charecteristics rather than the PCB or anything else, so I am a little unsure why the cell would have different discharge characteristics to an AW or Redilast cell which are also Panasonic cells?
Are intl outdoor 18650 protected good or not .. I'm reading all this and i understood that they can be discharged down to 2.8 , and not sure in anything now :) My English is not perfect, so after all this, I'm confused about those batteries.
And what is with that discharging below 3V and charging after that. Somebody said somewhere.. its dangerous. Why ?
The IO batteries are fine. All 2900mAh and 3100mAh batteries can be discharged down to 2.5 volt. This limit varies with actual LiIon chemistry in the battery, on most other LiIon batteries it is between 2.8 and 3 volt.
Discharging a bit under that limit and immediately charging again will not damage the battery, but storing it or discharging below 2 volt will damage the battery. It looses capacity and might be dangerous to charge.
They can be discharged down to 2.5V, no danger that's how NCR18650A are built. They are good protected cells. However what some members try to say (but don't actually finish saying it) is that if you would buy a protected cell based on the Sanyo UR18650FM you would get the same or more runtime with flashlight that use only one battery.
You should not worry about discharging, that is the purpose of the added protection to cope with these over-discharges, over-charging, short-circuits possible.
so .. for example .. i can take 1x or 2 x 18650 flashlight .. fill it with int outdoor protected, switch it on and leave it until batteries are completely discharged (light dies) .. based on what you all said i assume that protection board will at some point (2.5V or close to that) cut off current i.e. stop discharging batteries and when that occurs i can immediately put them to charger.
Good summary of battery options available =)
Glad I stuck with the Sanyo UR18650FM for my Fenix 1x18650s!
Btw, anywhere else to get cheap Sanyo UR18650FM's besides Intl-outdoors that also ships from the US?
Seems like everyone's selling the Panasonic NCR18650A's instead.
