Wide-beam 3AA or better under $40?
11 posts / 0 new
alexdi
Last seen: 8 years 9 months ago
I’ve been going through threads here and I’ve been a little overwhelmed, I hope you guys don’t mind another novice.
I’m looking for the following flashlight:
  • 3AA or better. I have piles of Eneloops. Ideally with the option to move to lithium later, though this is not a requirement.
  • Wide beam. 5’ wide or more at a 20’ foot. I see a lot of lights here with tremendous throw, but that look like pinpoints. I want something I could take on a walking trail, set to a middle brightness, and have a good idea where I’m going without having to scan the ground with the light.
  • Bright enough to illuminate to, say, 75’ with that wide beam on the highest setting. I’m just making up a number here, correct me if this is ludicrous. My existing light is a 2AA Rayovac with a 1W LED. It’s probably 75 lumens. Usefully bright with the narrow beam sweep, but not wide enough, and not much throw.
  • Multiple brightness settings. Top setting should last an hour, middle setting at least five.
  • <$30 best, max $40
  • Modified? Not modified? Is this all plug and play, or does changing out LEDs and so on require skill?
Does this exist?
Edited by: Anonymous (not verified) on 08/23/2012 - 16:12
nekdo12
Last seen: 7 years 10 months ago
3xAA/26650 light with C8 size reflector.
fishinfool
fishinfool's picture
Last seen: 2 years 5 months ago
Aloha and welcome to BLF alexdi!
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
alexdi
Can you order a large reflector separately? Where, and would modifications be required to make it fit? Greetings to you as well. Smile
fran82
Last seen: 1 year 1 month ago
There is a thread talking about these aurora/ultrafire 3x AA
http://budgetlightforum.com/node/8803
They are 4 lights with same body but different brand and LED
Aurora XM-L 29$ http://www.dealextreme.com/p/aurora-sh-3aa-cree-xm-l-t6-800lm-5-mode-mem...
UltraFire XM-L 28$ http://www.dealextreme.com/p/ultrafire-sh-3aa-cree-xm-l-t6-800lm-5-mode-...
Aurora XP-E 25$ http://www.dealextreme.com/p/aurora-sh-3aa-cree-xp-e-q5-245lm-5-mode-mem...
UltraFire XP-E 23$ http://www.dealextreme.com/p/ultrafire-sh-3aa-cree-q5-245lm-5-mode-memor...
If I am not wrong there is a review here on blf about the XM-L one….
This post/thread "may" contain referrals, a little contribution I "earn" in form of points ONLY if you buy the item. The purpose is to redeem items using the points and then making reviews of them in the forums to shar
how2
Last seen: 1 month 1 week ago
I know that your maximum is $40 But I suggest you spend $45 and go for the cyclone
Here is the review by foy
SashiX
SashiX's picture
Last seen: 7 years 9 months ago
Great thread.
The friend of mine want a good (budget) XML light but without switching to li-ion.
Fran, those links to Aurora (both) doesn’t work Wink
fran82
Yeah, they removed the items, that´s why “page not found”
alexdi
The UltraFire XM-L and Cyclone C88 look very similar. Is there a reason to spend $10 more on the Cyclone? How’s the beam width compare? I noticed some digs against DX in the other thread, I wonder if that should be a factor.
raccoon city
raccoon city's picture
Last seen: 23 min 5 sec ago
Welcome to the family, alexdi!
Best0270
Old-Lumens
Old-Lumens's picture
Last seen: 5 years 1 month ago
alexdi wrote:
I've been going through threads here and I've been a little overwhelmed, I hope you guys don't mind another novice. I'm looking for the following flashlight: * 3AA or better. I have piles of Eneloops. Ideally with the option to move to lithium later, though this is not a requirement. * Wide beam. 5' wide or more at a 20' foot. I see a lot of lights here with tremendous throw, but that look like pinpoints. I want something I could take on a walking trail, set to a middle brightness, and have a good idea where I'm going without having to scan the ground with the light. * Bright enough to illuminate to, say, 75' with that wide beam on the highest setting. I'm just making up a number here, correct me if this is ludicrous. My existing light is a 2AA Rayovac with a 1W LED. It's probably 75 lumens. Usefully bright with the narrow beam sweep, but not wide enough, and not much throw. * Multiple brightness settings. Top setting should last an hour, middle setting at least five. * <$30 best, max $40 * Modified? Not modified? Is this all plug and play, or does changing out LEDs and so on require skill? Does this exist?
SAiK SA-305  Inexpensive, spray the reflector with Krylon Clear Acrylic, makes wide beam that will be smooth and even. Could be modified and still be under $40. Someone could walk you through it if you wanted to learn, or someone could mod it for you. Plenty of modders here. Even with an XM-L T6 and a linear driver, it's still below $40. Not a bad light as is, if the reflector is sprayed, to even out the beam.
Here's a small Flood to Throw I haven't tried it, but it's the long and thin style 3AA. Should be fairly bright as is and the beam is adjustable.
Might want to search for a source other than DX. They are still hit or miss with long shipping times.
Welcome to BLF
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
